DEMOFLEXISJMSD  schematic
3,188 次查看
PO220
Hello
I'm looking for DEMOFLEXISJMSD and the demo software of this page
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=DEMOFLEXISJMSD&fsrch=1
Can you confirm me that the hardware for this part is the same than the hardware described in DRM104 "SD Card Reader Using the M9S08JM60 Series"
If not, where can I find the schematics for DEMOFLEXISJMSD. It's not easy to buy it in France...
Thank you in advance.
2,067 次查看
peg
Senior Contributor IV
There are a couple of links that should go to a pdf of the schematic of this, but the PDF seems to be broken.
Right click on the link and download it as a text document. When you have it on your machine change the extension to pdf and now it works!
Message Edited by peg on 2009-08-28 07:19 PM
2,068 次查看
peg
2,067 次查看
PO220
Thank you very much
2,067 次查看
J2MEJediMaster
Specialist I
Thanks for the workaround, peg. It looks like maybe the MIME type or file extension is messed up on this file. I am reporting it to IT to get this corrected. You folks should not have to resort to minor rocket science to obtain the schematic.
---Tom
