DEMO9S08QE8UM Demo Board
1,603 次查看
DavidoBG
With DEMO9S08QE8UM kit, is it possible to put MC9S08QE8 with 16 pins package on daughter board?
thanks
david
964 次查看
Ake
The daughterboard for the 9S08QE8 is a 32 pin device and P&E has used more than the minimum number of pins to hook up the USB interface to it.
So to be able to use the BKGD pin, you will have to buy either the USB Multilink or the Cyclone Pro to do it.
Ake
