CodeWarrior Build error
482 次查看
Julian99
Every so-often I get a build error:-
mingw32-make: *** No rule to make target Dropbox//Projects/\Project_x/\Project_Headers/\../\Sources/\Events.c',                     needed by `Sources/Events_c.obj'.  Stop.
The file Events_c.obj does, of course, exist, but the usual remedies do not work. I tried a Clean build, I deleted Events_c.obj', I deleted the whole Flash folder, I tried shutting down and re-starting but nothing worked. I ended up creating a new project and cut and pasted the source file content. This problem occurs once every few weeks and on a couple of occasions, after the computer was "sleeping", the problem cleared itself.
418 次查看
luis_maravilla
Which version of CodeWarrior are you using?
Does the Clean build that you tried is by using the commander>Clean (All)?
When you move to a new project it works and after a few weeks happens again?
Probably your make files doesn’t match according to your directory.
Please try this to clean and make a re-creation of the make files
On the Project view>Clean>Select your project to build
Also, as a recommendation do not use the Dropbox folder, kindly change to a local path and add it or change it in the build directory.
Please refer to this post for more information No rule to make target | MCU on Eclipse
Best Regards, Luis
419 次查看
luis_maravilla
Best Regards, Luis
444 次查看
Julian99
Thanks, the sync issue makes sense, but it will be a few days before I can try it.
%3CLINGO-SUB%20id%3D%22lingo-sub-2404542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECodeWarrior%20%E7%89%88%E6%9C%AC%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%81%B6%E5%B0%94%E4%BC%9A%E9%81%87%E5%88%B0%E7%89%88%E6%9C%AC%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3Emingw32-make%EF%BC%9A***%20%E6%B2%A1%E6%9C%89%E8%A7%84%E5%88%99%E5%8F%AF%E4%BB%A5%E5%88%9B%E5%BB%BA%E7%9B%AE%E6%A0%87%20Dropbox%2F%2FProjects%2F%5CProject_x%2F%5CProject_Headers%2F%5C..%2F%5CSources%2F%5CEvents.c'%60Sources%2FEvents_c.obj%60%20%E9%9C%80%E8%A6%81%E6%AD%A4%E6%96%87%E4%BB%B6%E3%80%82%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%E5%81%9C%E6%AD%A2%E3%80%82%3C%2FP%3E%3CP%3E%E6%96%87%E4%BB%B6%20Events_c.obj%20%E5%BD%93%E7%84%B6%E5%AD%98%E5%9C%A8%EF%BC%8C%E4%BD%86%E9%80%9A%E5%B8%B8%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E5%8D%B4%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E5%85%A8%E6%96%B0%E7%89%88%E6%9C%AC%EF%BC%8C%E5%88%A0%E9%99%A4%E4%BA%86%20Events_c.obj%20%E6%96%87%E4%BB%B6%E3%80%82%E6%88%91%E5%88%A0%E9%99%A4%E4%BA%86%E6%95%B4%E4%B8%AA%20Flash%20%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%8C%E4%B9%9F%E5%B0%9D%E8%AF%95%E8%BF%87%E5%85%B3%E6%9C%BA%E9%87%8D%E5%90%AF%EF%BC%8C%E4%BD%86%E9%83%BD%E6%B2%A1%E7%94%A8%E3%80%82%E6%9C%80%E5%90%8E%E6%88%91%E6%96%B0%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%8C%E7%84%B6%E5%90%8E%E5%89%AA%E5%88%87%E7%B2%98%E8%B4%B4%E4%BA%86%E6%BA%90%E6%96%87%E4%BB%B6%E7%9A%84%E5%86%85%E5%AE%B9%E3%80%82%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E6%AF%8F%E9%9A%94%E5%87%A0%E5%91%A8%E5%B0%B1%E4%BC%9A%E5%8F%91%E7%94%9F%E4%B8%80%E6%AC%A1%EF%BC%8C%E8%80%8C%E4%B8%94%E6%9C%89%E5%87%A0%E6%AC%A1%EF%BC%8C%E5%9C%A8%E7%94%B5%E8%84%91%E2%80%9C%E4%BC%91%E7%9C%A0%E2%80%9D%E5%90%8E%EF%BC%8C%E9%97%AE%E9%A2%98%E5%B0%B1%E8%87%AA%E8%A1%8C%E6%B6%88%E5%A4%B1%E4%BA%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%20Build%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%E5%90%8C%E6%AD%A5%E9%97%AE%E9%A2%98%E7%A1%AE%E5%AE%9E%E6%9C%89%E9%81%93%E7%90%86%EF%BC%8C%E4%BD%86%E6%88%91%E9%9C%80%E8%A6%81%E5%87%A0%E5%A4%A9%E6%97%B6%E9%97%B4%E6%89%8D%E8%83%BD%E5%B0%9D%E8%AF%95%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%20Build%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E5%90%AC%E8%B5%B7%E6%9D%A5%E4%B8%8D%E5%A4%AA%E5%83%8F%E6%98%AF%20.obj%20%E6%96%87%E4%BB%B6%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%96%87%E4%BB%B6%E6%9C%AC%E8%BA%AB%E6%9C%89%E9%97%AE%E9%A2%98%EF%BC%8C%E6%9B%B4%E5%83%8F%E6%98%AF%E7%94%9F%E6%88%90%E7%9A%84%20Makefile%20%E4%B8%AD%E5%AD%98%E5%9C%A8%E8%BF%87%E6%97%B6%E6%88%96%E6%A0%BC%E5%BC%8F%E9%94%99%E8%AF%AF%E7%9A%84%E4%BE%9D%E8%B5%96%E8%B7%AF%E5%BE%84%E3%80%82Dropbox%2F%2FProjects%2F%5CProject_x...%20%E8%B7%AF%E5%BE%84%E4%B8%AD%E5%A5%87%E6%80%AA%E7%9A%84%E6%96%9C%E6%9D%A0%E6%98%AF%E4%B8%80%E4%B8%AA%E9%87%8D%E8%A6%81%E7%9A%84%E7%BA%BF%E7%B4%A2%E3%80%82%E6%88%91%E4%BC%9A%E6%A3%80%E6%9F%A5%E9%A1%B9%E7%9B%AE%E6%98%AF%E5%90%A6%E7%9B%B4%E6%8E%A5%E4%BB%8E%20Dropbox%20%E5%90%8C%E6%AD%A5%E7%9A%84%E6%96%87%E4%BB%B6%E5%A4%B9%E6%9E%84%E5%BB%BA%EF%BC%8C%E5%B9%B6%E5%B0%9D%E8%AF%95%E5%B0%86%E5%85%B6%E7%A7%BB%E5%8A%A8%E5%88%B0%E6%9C%AC%E5%9C%B0%E7%9A%84%E9%9D%9E%E5%90%8C%E6%AD%A5%E7%9B%AE%E5%BD%95%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E8%AF%B7%E5%B0%86%E5%87%BA%E7%8E%B0%E9%97%AE%E9%A2%98%E6%97%B6%E7%94%9F%E6%88%90%E7%9A%84%E4%BE%9D%E8%B5%96%E9%A1%B9%2FMakefile%20%E6%9D%A1%E7%9B%AE%E4%B8%8E%E6%AD%A3%E5%B8%B8%E7%89%88%E6%9C%AC%E6%97%B6%E7%94%9F%E6%88%90%E7%9A%84%E6%9D%A1%E7%9B%AE%E8%BF%9B%E8%A1%8C%E6%AF%94%E8%BE%83%E3%80%82%E5%A6%82%E6%9E%9CDropbox%E6%96%87%E4%BB%B6%E5%A4%B9%E5%90%8C%E6%AD%A5%E6%88%96%E7%94%B5%E8%84%91%E5%94%A4%E9%86%92%E5%90%8E%E9%94%99%E8%AF%AF%E6%B6%88%E5%A4%B1%EF%BC%8C%E5%88%99%E8%BF%9B%E4%B8%80%E6%AD%A5%E8%A1%A8%E6%98%8E%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8Dropbox%2F%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F%E7%9A%84%E6%97%B6%E5%BA%8F%E9%97%AE%E9%A2%98%E4%B8%8A%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E6%BA%90%E6%96%87%E4%BB%B6%E6%9C%AC%E8%BA%AB%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2406337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%20Build%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84CodeWarrior%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%B0%9D%E8%AF%95%E7%9A%84%E6%B8%85%E7%90%86%E7%89%88%E6%9C%AC%E6%98%AF%E5%90%A6%E6%98%AF%E9%80%9A%E8%BF%87%3CEM%3E%E5%91%BD%E4%BB%A4%26gt%3B%E6%B8%85%E7%90%86%EF%BC%88%E5%85%A8%E9%83%A8%EF%BC%89%3C%2FEM%3E%E5%AE%9E%E7%8E%B0%E7%9A%84%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%BD%93%E4%BD%A0%E8%BD%AC%E5%88%B0%E6%96%B0%E9%A1%B9%E7%9B%AE%E6%97%B6%EF%BC%8C%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%EF%BC%8C%E4%BD%86%E5%87%A0%E5%91%A8%E5%90%8E%E9%97%AE%E9%A2%98%E5%8F%88%E5%87%BA%E7%8E%B0%E4%BA%86%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%8F%AF%E8%83%BD%E6%98%AF%E4%BD%A0%E7%9A%84%20make%20%E6%96%87%E4%BB%B6%E4%B8%8E%E4%BD%A0%E7%9A%84%E7%9B%AE%E5%BD%95%E4%B8%8D%E5%8C%B9%E9%85%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E6%AD%A4%E6%96%B9%E6%B3%95%E6%B8%85%E7%90%86%E5%B9%B6%E9%87%8D%E6%96%B0%E7%94%9F%E6%88%90%20make%20%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%3CEM%3E%E2%80%9C%E9%A1%B9%E7%9B%AE%E2%80%9D%E8%A7%86%E5%9B%BE%E4%B8%AD%20%26gt%3B%20%E2%80%9C%E6%B8%85%E7%90%86%E2%80%9D%20%26gt%3B%20%E9%80%89%E6%8B%A9%E8%A6%81%E7%89%88%E6%9C%AC%E9%A1%B9%E7%9B%AE%3C%2FEM%3E%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorluis_maravilla_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22luis_maravilla_1-1787091476012.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22luis_maravilla_1-1787091476012.png%22%20style%3D%22width%3A%20240px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394883i36189A2448C4EC2F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22luis_maravilla_1-1787091476012.png%22%20alt%3D%22luis_maravilla_1-1787091476012.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eluis_maravilla_1-1787091476012.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E5%BB%BA%E8%AE%AE%E4%B8%8D%E8%A6%81%E4%BD%BF%E7%94%A8%20Dropbox%20%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%8C%E8%AF%B7%E6%9B%B4%E6%94%B9%E4%B8%BA%E6%9C%AC%E5%9C%B0%E8%B7%AF%E5%BE%84%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%85%B6%E6%B7%BB%E5%8A%A0%E5%88%B0%E7%89%88%E6%9C%AC%E7%9B%AE%E5%BD%95%E4%B8%AD%E6%88%96%E8%BF%9B%E8%A1%8C%E6%9B%B4%E6%94%B9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%E6%AD%A4%E5%B8%96%E5%AD%90%E4%BA%86%E8%A7%A3%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fmcuoneclipse.com%2F2012%2F03%2F12%2Fno-rule-to-make-target%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E6%B2%A1%E6%9C%89%E8%A7%84%E5%88%99%E5%8F%AF%E4%BB%A5%E5%88%9B%E5%BB%BA%E7%9B%AE%E6%A0%87%20%7C%20Eclipse%20%E4%B8%8A%E7%9A%84%20MCU%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%E8%B7%AF%E6%98%93%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E
