CodeWarrior Build error
443件の閲覧回数
Julian99
Every so-often I get a build error:-
mingw32-make: *** No rule to make target Dropbox//Projects/\Project_x/\Project_Headers/\../\Sources/\Events.c',                     needed by `Sources/Events_c.obj'.  Stop.
The file Events_c.obj does, of course, exist, but the usual remedies do not work. I tried a Clean build, I deleted Events_c.obj', I deleted the whole Flash folder, I tried shutting down and re-starting but nothing worked. I ended up creating a new project and cut and pasted the source file content. This problem occurs once every few weeks and on a couple of occasions, after the computer was "sleeping", the problem cleared itself.
379件の閲覧回数
luis_maravilla
Which version of CodeWarrior are you using?
Does the Clean build that you tried is by using the commander>Clean (All)?
When you move to a new project it works and after a few weeks happens again?
Probably your make files doesn’t match according to your directory.
Please try this to clean and make a re-creation of the make files
On the Project view>Clean>Select your project to build
Also, as a recommendation do not use the Dropbox folder, kindly change to a local path and add it or change it in the build directory.
Please refer to this post for more information No rule to make target | MCU on Eclipse
Best Regards, Luis
380件の閲覧回数
luis_maravilla
Best Regards, Luis
405件の閲覧回数
Julian99
Thanks, the sync issue makes sense, but it will be a few days before I can try it.
%3CLINGO-SUB%20id%3D%22lingo-sub-2404542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECodeWarrior%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%99%82%E3%80%85%E3%83%93%E3%83%AB%E3%83%89%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%87%BA%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3Emingw32-make%3A%20***%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E3%81%99%E3%82%8B%E3%83%AB%E3%83%BC%E3%83%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20Dropbox%2F%2FProjects%2F%5CProject_x%2F%5CProject_Headers%2F%5C..%2F%5CSources%2F%5C%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1.c'%2C%60Sources%2FEvents_c.obj%60%20%E3%81%A7%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%E5%81%9C%E6%AD%A2%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20Events_c.obj%20%E3%81%AF%E7%A2%BA%E3%81%8B%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AE%E5%AF%BE%E5%87%A6%E6%B3%95%E3%81%A7%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Events_c.obj%20%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Flash%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E5%85%A8%E4%BD%93%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%80%81%E3%82%B7%E3%83%A3%E3%83%83%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%E3%81%A8%E5%86%8D%E8%B5%B7%E5%8B%95%E3%82%82%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%BD%95%E3%82%82%E5%8A%B9%E6%9E%9C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E7%B5%90%E5%B1%80%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%86%85%E5%AE%B9%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%EF%BC%86%E3%83%9A%E3%83%BC%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E6%95%B0%E9%80%B1%E9%96%93%E3%81%AB%E4%B8%80%E5%BA%A6%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E6%95%B0%E5%9B%9E%E3%81%AF%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E3%80%8C%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%80%8D%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%9F%E5%BE%8C%E3%81%AB%E8%87%AA%E7%84%B6%E3%81%AB%E8%A7%A3%E6%B6%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%20Build%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%90%8C%E6%9C%9F%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E7%B4%8D%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E8%A9%A6%E3%81%9B%E3%82%8B%E3%81%BE%E3%81%A7%E6%95%B0%E6%97%A5%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%9D%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%20Build%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF.obj%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A8%E3%81%84%E3%81%86%E3%82%88%E3%82%8A%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E8%87%AA%E4%BD%93%E3%80%81%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20Makefile%20%E5%86%85%E3%81%AE%E5%8F%A4%E3%81%84%E3%81%BE%E3%81%9F%E3%81%AF%E4%B8%8D%E6%AD%A3%E3%81%AA%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%83%91%E3%82%B9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82Dropbox%2F%2FProjects%2F%5CProject_x...%20%E3%81%A8%E3%81%84%E3%81%86%E3%83%91%E3%82%B9%E3%81%AB%E5%A5%87%E5%A6%99%E3%81%AA%E3%82%B9%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%A4%A7%E3%81%8D%E3%81%AA%E6%89%8B%E3%81%8C%E3%81%8B%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%8CDropbox%E3%81%A8%E5%90%8C%E6%9C%9F%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%8B%E3%82%89%E7%9B%B4%E6%8E%A5%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%81%AE%E5%90%8C%E6%9C%9F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E9%9A%9B%E3%81%AB%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%2FMakefile%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82Dropbox%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AE%E5%90%8C%E6%9C%9F%E5%BE%8C%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AFPC%E3%81%AE%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E8%A7%A3%E9%99%A4%E5%BE%8C%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A7%A3%E6%B6%88%E3%81%95%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81Dropbox%2F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E9%AB%98%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2406337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CodeWarrior%20Build%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3ECodeWarrior%E3%81%AE%E3%81%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E8%A9%A6%E3%81%97%E3%81%9F%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%83%93%E3%83%AB%E3%83%89%E3%81%AF%3CEM%3E%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%EF%BC%9E%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%EF%BC%88%E3%81%99%E3%81%B9%E3%81%A6%EF%BC%89%3C%2FEM%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E7%A7%BB%E3%82%8B%E3%81%A8%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8F%E3%81%AE%E3%81%AB%E3%80%81%E6%95%B0%E9%80%B1%E9%96%93%E5%BE%8C%E3%81%AB%E3%81%BE%E3%81%9F%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%81%8C%E8%B5%B7%E3%81%93%E3%82%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AEMakefile%E3%81%8C%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%A1%E3%82%A4%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E5%86%8D%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E3%81%8A%E8%A9%A6%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CEM%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%93%E3%83%A5%E3%83%BC%E3%81%A7%20%26gt%3B%20%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%20%26gt%3B%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E9%81%B8%E6%8A%9E%3C%2FEM%3E%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorluis_maravilla_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22luis_maravilla_1-1787091476012.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22luis_maravilla_1-1787091476012.png%22%20style%3D%22width%3A%20240px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394883i36189A2448C4EC2F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22luis_maravilla_1-1787091476012.png%22%20alt%3D%22luis_maravilla_1-1787091476012.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eluis_maravilla_1-1787091476012.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E6%8E%A8%E5%A5%A8%E4%BA%8B%E9%A0%85%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81Dropbox%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%9B%E3%81%9A%E3%80%81%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%91%E3%82%B9%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%BE%E3%81%9F%E3%81%AF%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%A9%B3%E7%B4%B0%E3%81%AF%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3CA%20href%3D%22https%3A%2F%2Fmcuoneclipse.com%2F2012%2F03%2F12%2Fno-rule-to-make-target%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E3%81%99%E3%82%8B%E3%83%AB%E3%83%BC%E3%83%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20%7CMCU%E3%81%AE%E3%82%A8%E3%82%AF%E3%83%AA%E3%83%97%E3%82%B9%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%95%AC%E5%85%B7%E3%80%81%E3%83%AB%E3%82%A4%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E
