CW for HCS08 V.5.1
CW for HCS08 V.5.1
2,334 次查看
Truk
New source Files.
If I take "NEW TEXT FILE" and store the file with extension xx.A08 the file shows the defined colors - in my opinion - it is accepted as a source file.
The problem is that the new files will not be shown in the project window in the source file group.
I have tried with
MAKE
FIND AND OPEN File
to solve this problem but I had no success
How have I to do this?
Truk
1,508 次查看
alex_spotw
Hi:
You have to RIGHT click on the source file group, and then select the ADD FILES option, which opens a dialog window where you can browse and select the files to add.
Alex
