BeeStack - memory size constrain
2,234件の閲覧回数
cosaka
I'm working with Freescale's BeeStack and if I want to setup the desire profile (ZigBee Stack Profile: Security with mesh routing, NVM enabled, etc) there is not enough memory avaliable in the MC13213. I listed a few things that I think is unnecesary: leds, keyboard, most part of the user interface, identify cluster request, reporting of attributes requests, UART, group and scenes requests, and ZTC....
I'm trying to assembly a DimmerbleLight Device (Coordinator or Router) inside the "Home Automation Profile" and the "ZigBee Stack Profile".
Could you give me some support since you already know the issue about memory?
Thanks in advance.
cosaka
1,303件の閲覧回数
Alex_RUS
This stack realy very big using futures security+mesh routing.
How I see this problem:
Now freescale trying to create new 32-bit based chip for zigbee whith big onboard flash and ram. This chip will apear in dec-07... BeeStack will be successfully ported to this new chip:-). When this new chip apear users will study new stack very well, thus new products will be able vary soon in 2008.
MC13213 will only be good for end devices or for smac-projects, not more:-(
This is a marketing.
PS: in CodeWarrior: how can I find out output code size before loading it to the board?
