IIC/I2C code from HCS08QRUGSW.zip for the HCS08QG4/8
2,420 次查看
TimS
I'm testing out the IIC code provided in HCS08QRUGSW.zip but even when the IICS_IICIF (interrupt flag) is set the code will not jump to the interrupt routine (interrupt 17 void Viic_isr).
Any ideas?
Tim.
Message Edited by TimS on 2006-08-17 10:55 AM
标签 (1)
1 回复
1,067 次查看
agnesim
The IIC code will jump to the interrupt routine if the Global interrupts are enabled and the IIC interrupt is enabled once a matching address with the IICA address is received trough the IIC bus.
Have you verified your Global interrupts, and the matching address in the bus (maybe using oscilloscope)
