[68HC908GZ60] Using MMDS and EML08GZ. Changing VREFH
3,077 次查看
RChapman
This message contains an entire topic ported from a separate forum. The original message and all replies are in this single message. We have seeded this new forum with selected information that we expect will be of value to you as you search for answers to your questions.
Posted: Thu Apr 14, 2005 8:42 am
I'm looking for some advice with my emulator question. I'm emulating the GZ60 with the MMDS/EML08GZ combination. Everything works OK, but I want to CHANGE VREFH.
The emulation daughter card simply connects VRFH to VDDA via a 38R ferrite bead. I have my own reference voltage on the target, and wonder how to configure the EML board to accept my reference. My Vref is < VDDA.
I'd appreciate any advice.
Posted: Thu Apr 14, 2005 12:45 pm
I see your concern, but VREFH shares its pin with VDDAD (analogue supply). Sad
As VDDAD should be at same level as VDD, I don't advise you to change its level.
You could choose another MCU with VREFH separated, like AZ60A...
0 回复数
