13213board-MyStarNetworkApp with Beaconning
plapla
Hi, I've just add beacon in MyStarNetworkApp but it didn't work.
13213 SRB showed error message "Scan did not find suitable coordinator".
After Passive scan,I think the "resultListSize" is empty so it can't process this code.
Anybody please help.:smileysad:
Spell
I had the same problem and I have solved it after many and many trying...
You must have much patience and try many values :smileyhappy:
plapla
It means the problem's from these only values?
Could you tell me which value you use in your network?
Thank you in advance.:robotwink:
Spell
Sorry but now I'm not using MAC codebase anymore and beacon tree network topology.
I didn't remember which values I've used...
