13213board-MyStarNetworkApp with Beaconning
11,204 次查看
plapla
Hi, I've just add beacon in MyStarNetworkApp but it didn't work.
13213 SRB showed error message "Scan did not find suitable coordinator".
After Passive scan,I think the "resultListSize" is empty so it can't process this code.
Anybody please help.:smileysad:
23 回复数
808 次查看
Spell
I had the same problem and I have solved it after many and many trying...
You must have much patience and try many values :smileyhappy:
808 次查看
plapla
It means the problem's from these only values?
Could you tell me which value you use in your network?
Thank you in advance.:robotwink:
808 次查看
Spell
Sorry but now I'm not using MAC codebase anymore and beacon tree network topology.
I didn't remember which values I've used...
