iMX6SL
phamhuynh
hi, good day, iMX6SL have support MIPI DBI interface?
Yuri
  Strictly speaking, IMX6 SL does not support MIPI display.
The following are supported :
• EPDC (electrophoretic display controller): display controller for E-INK EPD panel
• SPDC (SiPix display controller): display controller for SiPix EPD panel
• LCDIF (LCD interface): 24-bit parallel RGB LCD interface
  Nevertheless, it makes sense to analyze datasheets of i.MX6 and display in more
details for different mode using and timing parameters, perhaps LCDIF of the i.MX6 SL
in MPU mode may be applied with MIPI DBI (parallel).
Yuri
Yuri
Yuri
phamhuynh
thank for help :smileyhappy:
