How to Enable LDO Bypass Based on i.MX6 Android ICS
Overview
i.MX6Dual/Quad supports using internal LDO or bypass internal LDO. LDO bypass is helpful to save power consumption and reduce thermal under high loading use cases because the power consumption on internal LDO can be saved. The purpose of this document is to introduce how to enable LDO bypass based on i.MX6 R13.4.1 release on i.MX6Dual/Quad SabreSD board.
Constraint
LDO Bypass solution currently can only be applied to i.MX6Dual/Quad 1GHz. LDO bypass function will force disabled on i.MX6Dual/Quad 1.2GHz, but customer can estimate this function through limit the max ARM frequency to 1GHz by command line 'arm_freq=1000' on i.MX6Dual/Quad 1.2GHz .
Hardware Voltage Settings
The following table lists the voltage settings in each working CPU frequency and VPU frequency with LDO bypass solution:
VPU FrequencyARM FrequencyVDDARM_IN (V)VDDSOC_IN (V)
0 to 352MHz996MHz1.251.25
264-> 352MHz702MHz1.151.25
0 to 264MHz792MHz1.151.175
264->352MHz396MHz0.951.25
<264MHz396MHz0.951.175
VDDARM_IN and VDDSOC_IN voltage setting should be within the voltage range, considering the ripple:
  • VDDARM_IN - ripple>VDDARM_INmin
  • VDDARM_IN + ripple<VDDARM_Inmax
For the Min/Max value, refer to the i.MX6Dual/Quad data sheet. The above list is based on SabreSD PFuse-100.
Software Changes
Please apply the patches into Android-13.4.1-LDO_BYPASS-pathes.tar.gz.gz based on R13.4.1. The change lists:
  • uboot-imx: move LDO bypass code and one PFUZE1.0 workaround code to kernel. Remove CONFIG_MX6_INTER_LDO_BYPASS in u-boot.
  • kernel: A set of patches are used to support LDO bypass enable/disable by command option.
How to Enable/Disable LDO Bypass
After applying for above patches, you can add command option into boot command line to enable or disable LDO:
  • Command option “ldo_active=off”: Enable LDO bypass mode
  • Command option “ldo_active=on”: Enable LDO active
ラベル(2)
添付
コメント
Anyone ever integrated the PF0100 into the imx6_cpufreq driver to take advantage of DVFS for LDO bypass mode?
--> e.g. 0.95V when running at 396MHz, 1.15 when running at 792MHz
Solution to use the PF0100 for DVFS: https://community.nxp.com/thread/462514#comment-954021
%3CLINGO-SUB%20id%3D%22lingo-sub-1118564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6%20Android%20ICS%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8FLDO%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-381651819%22%20id%3D%22toc-hId-1304247377%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3EOverview%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E%E7%A7%81%E3%80%82%3C%2FSPAN%3EMX6Dual%2FQuad%E3%81%AF%E3%80%81%E5%86%85%E9%83%A8LDO%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E5%86%85%E9%83%A8LDO%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82LDO%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%81%AF%E3%80%81%E5%86%85%E9%83%A8LDO%E3%81%AE%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E3%82%92%E7%AF%80%E7%B4%84%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E9%AB%98%E8%B2%A0%E8%8D%B7%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%A7%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E3%82%92%E7%AF%80%E7%B4%84%E3%81%97%E3%80%81%E7%86%B1%E3%82%92%E5%89%8A%E6%B8%9B%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%AF%E3%80%81i.MX6%20R13.4.1%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%20LDO%20%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%82%92%20i.MX6Dual%2FQuad%20SabreSD%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%B4%B9%E4%BB%8B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1425802644%22%20id%3D%22toc-hId--503207086%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E5%88%B6%E7%B4%84%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3ELDO%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%83%BB%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81%E7%8F%BE%E5%9C%A8%E3%80%81i.MX6Dual%2FQuad%201GHz%E3%81%AB%E3%81%AE%E3%81%BF%E9%81%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%3Ei.MX6Dual%2FQuad%201.2GHz%E3%81%A7%E3%81%AFLDO%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E6%A9%9F%E8%83%BD%E3%81%8C%E5%BC%B7%E5%88%B6%E7%9A%84%E3%81%AB%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81i.MX6Dual%2FQuad%201.2GHz%E3%81%A7%E3%81%AF%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%80%8Carm_freq%3D1000%E3%80%8D%E3%81%A7%E6%9C%80%E5%A4%A7ARM%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%921GHz%E3%81%AB%E5%88%B6%E9%99%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E8%A6%8B%E7%A9%8D%E3%82%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1061710189%22%20id%3D%22toc-hId-1984305747%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E9%9B%BB%E5%9C%A7%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E6%AC%A1%E3%81%AE%E8%A1%A8%E3%81%AB%E3%80%81LDO%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%90%84%E5%8B%95%E4%BD%9CCPU%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A8VPU%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AE%E9%9B%BB%E5%9C%A7%E8%A8%AD%E5%AE%9A%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20height%3D%22151%22%20style%3D%22width%3A%20569px%3B%20height%3A%20153px%3B%20border%3A%20%23000000%201px%20solid%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%3E%3CSTRONG%3EVPU%E5%91%A8%E6%B3%A2%E6%95%B0%3C%2FSTRONG%3E%3C%2FTH%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%3E%3CSTRONG%3EARM%E5%91%A8%E6%B3%A2%E6%95%B0%3C%2FSTRONG%3E%3C%2FTH%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%3E%3CSTRONG%3EVDDARM_IN(V)%3C%2FSTRONG%3E%3C%2FTH%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%3E%3CSTRONG%3EVDDSOC_IN(V)%3C%2FSTRONG%3E%3C%2FTH%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E0%20%E3%81%8B%E3%82%89%20352MHz%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E996MHz%E5%B8%AF%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E1.25%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E1.25%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E264-%26gt%3B%20352MHz%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E702MHz%E5%B8%AF%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E1.15%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E1.25%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E0%20%E3%81%8B%E3%82%89%20264MHz%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E792MHz%E5%B8%AF%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E1.15%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E1.175%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E264-%26gt%3B352MHz%E3%81%AE%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E396MHz%E3%81%AE%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E0.95%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E1.25%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%26lt%3B264MHz%E5%B8%AF%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E396MHz%E3%81%AE%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E0.95%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E1.175%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20black%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20black%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3EVDDARM_IN%E9%9B%BB%E5%9C%A7%E3%81%A8VDDSOC_IN%E9%9B%BB%E5%9C%A7%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%80%81%E3%83%AA%E3%83%83%E3%83%97%E3%83%AB%E3%82%92%E8%80%83%E6%85%AE%E3%81%97%E3%81%A6%E9%9B%BB%E5%9C%A7%E7%AF%84%E5%9B%B2%E5%86%85%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EVDDARM_IN%20-%20%E3%83%AA%E3%83%83%E3%83%97%E3%83%AB%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EVDDARM_INmin%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EVDDARM_IN%2B%E3%83%AA%E3%83%83%E3%83%97%E3%83%AB%26lt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3EVDDARM_Inmax%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E6%9C%80%E5%B0%8F%2F%E6%9C%80%E5%A4%A7%E5%80%A4%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Ei.MX6Dual%2FQuad%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AFSabreSD%20PFuse-100%E3%82%92%E5%9F%BA%E6%BA%96%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--745744274%22%20id%3D%22toc-hId-176851284%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3ER13.4.1%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8FAndroid-13.4.1-LDO_BYPASS-pathes.tar.gz.gz%E3%81%AB%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%A4%89%E6%9B%B4%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20class%3D%22mce_paste_marker%22%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3Euboot-imx%3A%20LDO%20%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%201%20%E3%81%A4%E3%81%AE%20PFUZE1.0%20%E3%82%92%E7%A7%BB%E5%8B%95%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82u-boot%E3%81%A7CONFIG_MX6_INTER_LDO_BYPASS%E3%82%92%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22mce_paste_marker%22%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3Ekernel%3A%20%E4%B8%80%E9%80%A3%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%88%E3%82%8B%20LDO%20%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%81%AE%E6%9C%89%E5%8A%B9%E5%8C%96%2F%E7%84%A1%E5%8A%B9%E5%8C%96%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1741768559%22%20id%3D%22toc-hId--1630603179%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3ELDO%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%82%92%E6%9C%89%E5%8A%B9%2F%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20color%3A%20%23000000%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%80%81LDO%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%BE%E3%81%9F%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20%22ldo_active%3Doff%22%3A%20LDO%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20%22ldo_active%3Don%22%3A%20LDO%E3%82%92%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1118564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20Android%20ICS%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8FLDO%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EPF0100%20DVFS%E7%94%A8%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3A%3CA%20_jive_internal%3D%22true%22%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F462514%23comment-954021%22%20title%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F462514%23comment-954021%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fthread%2F462514%23comment-954021%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX6%20Android%20ICS%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8FLDO%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EPF0100%E3%82%92imx6_cpufreq%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%97%E3%81%A6%E3%80%81LDO%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AEDVFS%E3%82%92%E5%88%A9%E7%94%A8%E3%81%97%E3%81%9F%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E--%26gt%3B%E4%BE%8B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E396MHz%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF0.95V%E3%80%81%3CSPAN%3E792MHz%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF1.15V%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎01-31-2013 05:43 AM
更新者:
