System Controller Firmware 101
This is a series of documents that intend to help you grasp he concept of the System Controller Unit (SCU) / System Controller Firmware (SCFW).
Other Useful resources:
You can get the latest System Controller Firmware Porting kit from the i.MX Software and development webpage:
The porting kit contains documentation and allows you to build the SCFW from source and do modifications to the board dependent parts:
The API documents explain the System Controller Firmware API syntax and it has a section for introduction and general overview of the system.
The port document contains information on what each board component function does and the overall process of porting the SCFW.
Tags (2)
No ratings
Version history
Last update:
‎02-06-2019 01:04 PM
Updated by:
