Example MPC5777C Single ELF multi-core Pin Toggling - S32DS Power 2017.R1
File uploaded by stanish Employee on Oct 11, 2017Last modified by stanish Employee on Feb 1, 2018
Version 2Show Document
  • View in full screen mode
This Example demonstrates an alternative way to multi-core projects. This is basically a single eclipse project that generates the single elf file for dual core MCU (MPC5777C)
See the project structure below where the sources for each core are separated into a core specific source folder:
Main core0 [e200z7_0] performs basic initialization (Clocks, ports..)
Each core initializes the interrupt controller in order to service interrupts generated by PIT (Periodic Interrupt Timer):
Core 0 (e200z7_0) services PIT channel 0 interrupts generated once per second.
Core 1 (e200z7_1) services PIT channel 2 interrupts generated once per two seconds.
