Let´s start with FreeMASTER!
Document created by Iva Susnova Employee on Apr 28, 2016Last modified by Diana Torres on Feb 28, 2017
Version 6Show Document
  • View in full screen mode
What is it FreeMASTER?
FreeMASTER is a tool with variety GUIs in one offered free. FreeMASTER is a user-friendly real-time debug monitor and data visualization tool
GUI can be easily extend by multimedia content (charts) and user-modified content (possible mix user´s data with default values)
offers access to target variables, symbols and data types
access over UART, CAN or USB with target-side driver and over BDM
possibility to direct control via variable modifications
addresses parsed from ELF file or provided by target (TSA)
scope graphs with real-time data in [ms] resolution
recorder visualization transitions close to 10[us] resolution
FreeMASTER features
Real Time Monitor
-Displaying variable values in various formats (Text, Real-Time waveforms, High-speed recorded data)
Control Panel
- Direct variable value settings and variable stimulation, scribtable in JScript or VBScript
Demonstration Platform
- Demostration embedded app by HTML pages, display simultaneous real-time data monitoring
Easy Project Deployment
- Entire project saved to a single file
FreeMASTER communication
There are two types of communication. It is possible to communicate via Direct RS232 or selected Plug-in Module.
In short:
SCI, UART
USB – CDC – Kinetis, ColdFire V2
CAN
JTAG (56F8xxx only)
BDM – Kinetis, PowerPC, ColdFire, HCS with Segger, P&E Micro, CMSIS-DAP…
FreeMASTER usage
Real-time debugging - FreeMASTER allows users to debug applications in true real-time through its ability to watch variables. Moreover, it allows debugging at the algorithm level, which helps to shorten the development phase
Diagnostic tool - FreeMASTER remote control capability allows it to be used as a diagnostic tool for debugging customer applications remotely across a network
Demonstrations - FreeMASTER is an outstanding tool for demonstrating algorithm or application execution and variable outputs.
Education - FreeMASTER may be used for educational purposes. Its application control features allow students to play with the application in demonstration mode, learning how to control program execution.
FreeMASTER description of the environment
The FreeMASTER window is divided into 4 parts - Project Tree, Detail View Pane, Commands and Variable Watch Grid.
Project Tree is the project, New Block is a root of the project, New Scope is similar to classical Oscilloscope. Scope periodically reads variable values and plots them in real-time. It is limited by the serial communication speed. The recorder is also monitoring and visualising variable values, but the change is much faster. The recorder is running on target board and variable values are sampled into memory buffer on the board and then these sampled data are downloaded from the board to FreeMASTER.
Detail View Area is dynamically changes depending on content which is selected in Project Tree. Detail View Tab can be control page, algorithm block description, scope, recorder or another HTML document whose URL is defined in the Scope or Recorder properties.
Commands window is list of commands to send, Variable Stimulus - is the list of defined variables for the defined time.
In Variable Watch Grid contains the list of watched variables.
Supported devices
FreeMASTER download and support
The installation package you can download from the Official website:
FreeMASTER Official website
www.nxp.com/freemaster
You can ask us on Community or you can create new SR according to https://community.freescale.com/docs/DOC-329745
More about FreeMASTER
FreeMASTER Official Website
https://www.nxp.com/freemaster
Using FreeMASTER
https://cache.freescale.com/files/microcontrollers/doc/reports_presentations/FREEMASTERPRESENT.pdf
FREEMASTER:  Remote Server Tutorial
https://community.freescale.com/docs/DOC-103293
Tutorial: FreeMASTER Visualization and Run-Time Debugging
https://mcuoneclipse.com/2013/08/24/tutorial-freemaster-visualization-and-run-time-debugging
Let´s continue with reading! Let´s start with KSDK!
6 people found this helpful
    Outcomes
