Interfacing Depth Sensors with ROS on NXP i.MX6 boards
About this document
This document describe the setup detail for Interfacing, Installing, programming (basis) and testing depth cameras with MX6QDL based boards using the Robotic Operating System (ROS). If you are not using ROS you can also install the proper drivers and compile, in your Ubuntu system as explained on document:  https://community.freescale.com/docs/DOC-330278
1. Software & Hardware requirements
Supported NXP HW boards:
  • i.MX 6QuadPlus SABRE-SD Board and Platform
  • i.MX 6Quad SABRE-SD Board and Platform
  • i.MX 6DualLite SABRE-SD Board
  • i.MX 6Quad SABRE-AI Board
  • i.MX 6DualLite SABRE-AI Board
  • Depth sensors tested: Microsoft Kinect, ASUS Xtion.
Software:   Gcc, Ubuntu 14.04v, OpenCV, Openni, Python, ROS.
2. Installation on ROS
For installation steps of ROS on iMX6 boards in your board, please follow up:
https://community.freescale.com/docs/DOC-3301478
Before you can use ROS, you will need to initialize rosdep. It enables you to easily install system dependencies for source you want to compile and is required to run some core components in ROS.
$ sudo rosdep init
$ rosdep update
There are many different libraries and tools in ROS - not all compile fully on ARM. In this case we already have installed the ROS Base, however any other packages need to be installed individually. First install the following dependencies, which will take some time and space (~1.4 GB):
$ sudo apt-get install --no-install-recommends freeglut3-dev libfreenect-dev libusb-1.0-0-dev
 libudev-dev ros-indigo-camera-info-manager ros-indigo-dynamic-reconfigure
ros-indigo-image-transport ros-indigo-image-proc ros-indigo-depth-image-proc ros-indigo-tf
ros-indigo-openni-launch ros-indigo-freenect-* ros-indigo-depthimage-to-laserscan
ros-indigo-image-view ros-indigo-camera-info-manager ros-indigo-dynamic-reconfigure
libudev-dev doxygen graphviz openjdk-6-jdk ros-indigo-openni2-camera
ros-indigo-openni2-launch ros-indigo-rqt-common-plugins ros-indigo-rqt-graph
There is no any additional installation to run kinect with ROS, If you are using kinect you can pass to part 4. However the packages used to run the PrimeSense / Asus Xtion on the i.Mx6 are not available over apt yet, so they need to be compiled from source. To use OpenNI2 with ROS, we only need the shared OpenNI2 libraries and the Drivers.
Clone OpenNI2
$ git clone https://github.com/OpenNI/OpenNI2
$ cd OpenNI2
Edit ThirdParty/PSCommon/BuildSystem/Platform.Arm
$ nano ThirdParty/PSCommon/BuildSystem/Platform.Arm
and replace
CFLAGS += -march=armv7-a -mtune=cortex-a9 -mfpu=neon -mfloat-abi=softfp #-mcpu=cortex-a8
with
CFLAGS += -march=armv7-a -mtune=cortex-a9 -mfpu=neon -mfloat-abi=hard
Add support for pthread library:
$ nano ThirdParty/PSCommon/BuildSystem/CommonCppMakefile
Search the line 95 and add the code between the two lines:
OUTPUT_NAME = $(EXE_NAME)
    # We want the executables to look for the .so's locally first:
    LDFLAGS += -Wl,-rpath ./
+   ifneq ("$(OSTYPE)","Darwin")
+       LDFLAGS += -lpthread
+   endif
    OUTPUT_COMMAND = $(CXX) -o $(OUTPUT_FILE) $(OBJ_FILES) $(LDFLAGS)
 endif
Save the file and exit
Then run make to compile the OpenNI2 drivers and libraries
$ PLATFORM=Arm make ALLOW_WARNINGS=1
Once the compilation is done, run the linux install script
$ cd Packaging/Linux
$ sudo ./install.sh
Copy libraries and includes to the system paths
$ cd ../../
$ sudo cp -r Include /usr/include/openni2
$ sudo cp -r Bin/Arm-Release/OpenNI2 /usr/lib/
$ sudo cp Bin/Arm-Release/libOpenNI2.* /usr/lib/
Create a package config file
$ sudo nano /usr/lib/pkgconfig/libopenni2.pc
and fill it with this:
prefix=/usr
exec_prefix=${prefix}
libdir=${exec_prefix}/lib
includedir=${prefix}/include/openni2
Description: A general purpose driver for all OpenNI cameras.
Version: 2.2.0.0
Cflags: -I${includedir}
Libs: -L${libdir} -lOpenNI2 -L${libdir}/OpenNI2/Drivers -lDummyDevice -lOniFile -lPS1080.so
This will enable ubuntu to find the location of the drivers, libraries and include files. To make sure it is correctly found, run
$ pkg-config --modversion libopenni2
Which should give the same version as defined in the file above (2.2.0.0). Now the Xtion is ready to be used. Plug it in (if it is already, unplug it first), then run the sample program
$ ./Bin/Arm-Release/SimpleRead
Then create a catkin workspace as described here, and check out the following packages in the src folder of the catkin workspace:
$ cd ~/catkin_ws/src
$ git clone https://github.com/ros-drivers/openni2_camera
$ git clone https://github.com/ros-drivers/openni2_launch
$ git clone https://github.com/ros-drivers/rgbd_launch
Now the ros packages checked out above to the catkin workspace can be compiled with catkin_make
$ cd ~/catkin_ws
$ catkin_make
Once the packages are compiled, the Xtion is ready for use with ROS with
3. Testing The Installation
  1. Kinect. Open at least 3 bash terminals:
Terminal 1: Run ROS
$ roscore
Terminal 2:  launch the Freenect
$ roslaunch freenect_launch freenect.launch
Terminal 3: run the image capture
$ rosrun image_view image_view image:=camera/rgb/image_color
or:
$ rosrun image_view image_view image:=camera/rgb/image_rect_mono
or:
$ rosrun image_view disparity_view image:=camera/depth/disparity
It will open a new terminal with the rgb points, mono  and depth images  from the Kinect.
Xtion.
Terminal 1: Run ROS
$ roscore
Terminal 2:  launch Openni2
$ roslaun openi2_launch openni2.launch
Terminal 3: you can use rqt or Rviz session to visualize the sensor e.g:
$ rqt
or
$ rosrun rqt_graph rqt_graph
In the “rqt” window select “Plugins” -> “Visualization” -> “Image View“
     (optional) Install PySide, in any case you get an error with python rqt graph:
$ pip install PySide
$ cd ~/
Note: rqt and Rviz demand a lot of i.MX GPU work, so general graphic functionality will be affected. For this case is suggested to run rviz in a remote Network ROS session.
References:
-       www.ros.org
-     https://dobots.nl/2014/05/05/asus-xtion-using-openni2-and-ros-on-udoo/
%3CLINGO-SUB%20id%3D%22lingo-sub-1126147%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%20NXP%20i.MX6%20%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E5%B0%86%E6%B7%B1%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E4%B8%8E%20ROS%20%E8%BF%9E%E6%8E%A5%E8%B5%B7%E6%9D%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126147%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3E%E5%85%B3%E4%BA%8E%E6%9C%AC%E6%96%87%E6%A1%A3%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%20%E6%9C%AC%E6%96%87%E6%A1%A3%E6%8F%8F%E8%BF%B0%E4%BA%86%E4%BD%BF%E7%94%A8%E6%9C%BA%E5%99%A8%E4%BA%BA%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%20(ROS)%20%E4%B8%8E%E5%9F%BA%E4%BA%8E%20MX6QDL%20%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E8%BF%9B%E8%A1%8C%E6%8E%A5%E5%8F%A3%E3%80%81%E5%AE%89%E8%A3%85%E3%80%81%E7%BC%96%E7%A8%8B%EF%BC%88%E5%9F%BA%E7%A1%80%EF%BC%89%E5%92%8C%E6%B5%8B%E8%AF%95%E6%B7%B1%E5%BA%A6%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E8%AE%BE%E7%BD%AE%E7%BB%86%E8%8A%82%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E4%B8%8D%E4%BD%BF%E7%94%A8%20ROS%EF%BC%8C%E6%82%A8%E4%B9%9F%E5%8F%AF%E4%BB%A5%E5%9C%A8%20Ubuntu%20%E7%B3%BB%E7%BB%9F%E4%B8%AD%E5%AE%89%E8%A3%85%E9%80%82%E5%BD%93%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B9%B6%E8%BF%9B%E8%A1%8C%E7%BC%96%E8%AF%91%EF%BC%8C%E5%A6%82%E6%96%87%E6%A1%A3%E4%B8%AD%E6%89%80%E8%BF%B0%EF%BC%9A%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-330278%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-330278%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-382511855%22%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId-382511855%22%20id%3D%22toc-hId-1303209431%22%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId--1424942608%22%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId--1424942608%22%20id%3D%22toc-hId--504245032%22%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%22%3E1.%20%E8%BD%AF%E4%BB%B6%E5%92%8C%E7%A1%AC%E4%BB%B6%E8%A6%81%E6%B1%82%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Cambria%2C%20serif%3B%22%3E%E6%94%AF%E6%8C%81%E7%9A%84%20NXP%20%E7%A1%AC%E4%BB%B6%E6%9D%BF%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Cambria%2C%20serif%3B%22%3Ei.MX%206QuadPlus%20SABRE-SD%20%E5%BC%80%E5%8F%91%E6%9D%BF%E5%92%8C%E5%B9%B3%E5%8F%B0%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Cambria%2C%20serif%3B%22%3Ei.MX%206Quad%20SABRE-SD%20%E4%B8%BB%E6%9D%BF%E5%92%8C%E5%B9%B3%E5%8F%B0%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Cambria%2C%20serif%3B%22%3Ei.MX%206DualLite%20SABRE-SD%20%E4%B8%BB%E6%9D%BF%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Cambria%2C%20serif%3B%22%3Ei.MX%206Quad%20SABRE-AI%E7%94%B5%E8%B7%AF%E6%9D%BF%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Cambria%2C%20serif%3B%22%3Ei.MX%206DualLite%20SABRE-AI%20%E6%9D%BF%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20font-family%3A%20Cambria%2C%20serif%3B%22%3E%E6%B5%8B%E8%AF%95%E7%9A%84%E6%B7%B1%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%9AMicrosoft%20Kinect%E3%80%81ASUS%20Xtion%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%E8%BD%AF%E4%BB%B6%EF%BC%9AGcc%E3%80%81Ubuntu%2014.04v%E3%80%81OpenCV%E3%80%81Openni%E3%80%81Python%E3%80%81ROS%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1062570225%22%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId-1062570225%22%20id%3D%22toc-hId-1983267801%22%3E2.%20ROS%E4%B8%8A%E7%9A%84%E5%AE%89%E8%A3%85%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%E6%9C%89%E5%85%B3%E5%9C%A8%E6%82%A8%E7%9A%84%E4%B8%BB%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85%20iMX6%20%E6%9D%BF%E4%B8%8A%E7%9A%84%20ROS%20%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%8C%E8%AF%B7%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E6%93%8D%E4%BD%9C%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-3301478%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-3301478%3C%2FA%3E%3C%2FP%3E%3CP%20class%3D%22line862%22%20style%3D%22margin-bottom%3A%208.35pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%E5%9C%A8%E4%BD%BF%E7%94%A8%20ROS%20%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%20rosdep%E3%80%82%E5%AE%83%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%E4%BD%BF%E6%82%A8%E8%83%BD%E5%A4%9F%E8%BD%BB%E6%9D%BE%E5%AE%89%E8%A3%85%E8%A6%81%E7%BC%96%E8%AF%91%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%E6%89%80%E9%9C%80%E7%9A%84%E7%B3%BB%E7%BB%9F%E4%BE%9D%E8%B5%96%E9%A1%B9%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%98%AF%E8%BF%90%E8%A1%8C%20ROS%20%E4%B8%AD%E6%9F%90%E4%BA%9B%E6%A0%B8%E5%BF%83%E5%85%83%E5%99%A8%E4%BB%B6%E6%89%80%E5%BF%85%E9%9C%80%E7%9A%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14597915932386113%20jive_text_macro%22%20data-renderedposition%3D%22605.3646240234375_50.000003814697266_1158_31%22%20jivemacro_uid%3D%22_14597915932386113%22%3E%3CP%20class%3D%22Code%22%3E%24%20sudo%20rosdep%20init%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%24%20rosdep%20update%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3EROS%20%E4%B8%AD%E6%9C%89%E8%AE%B8%E5%A4%9A%E4%B8%8D%E5%90%8C%E7%9A%84%E5%BA%93%E5%92%8C%E5%B7%A5%E5%85%B7%EF%BC%8C%E5%B9%B6%E9%9D%9E%E6%89%80%E6%9C%89%E5%BA%93%E5%92%8C%E5%B7%A5%E5%85%B7%E9%83%BD%E8%83%BD%E5%9C%A8%20ARM%20%E4%B8%8A%E5%AE%8C%E5%85%A8%E7%BC%96%E8%AF%91%E3%80%82%E5%9C%A8%E6%9C%AC%E4%BE%8B%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B7%B2%E7%BB%8F%E5%AE%89%E8%A3%85%E4%BA%86%20ROS%20Base%EF%BC%8C%E4%BD%86%E5%85%B6%E4%BB%96%E4%BB%BB%E4%BD%95%E8%BD%AF%E4%BB%B6%E5%8C%85%E9%83%BD%E9%9C%80%E8%A6%81%E5%8D%95%E7%8B%AC%E5%AE%89%E8%A3%85%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%E9%A6%96%E5%85%88%E5%AE%89%E8%A3%85%E4%BB%A5%E4%B8%8B%E4%BE%9D%E8%B5%96%E9%A1%B9%EF%BC%8C%E8%BF%99%E5%B0%86%E5%8D%A0%E7%94%A8%E4%B8%80%E4%BA%9B%E6%97%B6%E9%97%B4%E5%92%8C%E7%A9%BA%E9%97%B4%EF%BC%88%E7%BA%A6%201.4%20GB%EF%BC%89%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14597916194098491%20jive_text_macro%22%20data-renderedposition%3D%22699.5833740234375_50.000003814697266_1158_181%22%20jivemacro_uid%3D%22_14597916194098491%22%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%24%20%3C%2FSPAN%3E%3C%2FCODE%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3Esudo%20apt-get%20install%20--no-install-recommends%20freeglut3-dev%20%3C%2FSPAN%3E%3C%2FCODE%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3Elibfreenect-dev%3C%2FSPAN%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%20libusb-1.0-0-dev%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%20libudev-dev%20ros-indigo-camera-info-manager%20ros-indigo-dynamic-reconfigure%20%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3Eros-indigo-image-transport%20ros-indigo-image-proc%20ros-indigo-depth-image-proc%20ros-indigo-tf%20%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3Eros-indigo-openni-launch%20%3C%2FSPAN%3E%3C%2FCODE%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3Eros-indigo-freenect-*%20ros-indigo-%E6%B7%B1%E5%BA%A6%E5%9B%BE%E5%83%8F%E5%88%B0%E6%BF%80%E5%85%89%E6%89%AB%E6%8F%8F%20%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3Eros-indigo-%E5%9B%BE%E5%83%8F%E8%A7%86%E5%9B%BE%20ros-indigo-%E7%9B%B8%E6%9C%BA%E4%BF%A1%E6%81%AF%E7%AE%A1%E7%90%86%E5%99%A8%20ros-indigo-%E5%8A%A8%E6%80%81%E9%87%8D%E6%96%B0%E9%85%8D%E7%BD%AE%20%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3Elibudev-dev%20%3C%2FSPAN%3E%3C%2FCODE%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3Edoxygen%20graphviz%20openjdk-6-jdk%20ros-indigo-openni2-%E7%9B%B8%E6%9C%BA%20%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3Eros-indigo-openni2-%E5%90%AF%E5%8A%A8%20ros-indigo-rqt-%E9%80%9A%E7%94%A8%E6%8F%92%E4%BB%B6%20ros-indigo-rqt-graph%3C%2FSPAN%3E%3C%2FPRE%3E%3C%2FPRE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%E4%BD%BF%E7%94%A8%20ROS%20%E8%BF%90%E8%A1%8C%20Kinect%20%E6%97%A0%E9%9C%80%E4%BB%BB%E4%BD%95%E9%A2%9D%E5%A4%96%E5%AE%89%E8%A3%85%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20Kinect%EF%BC%8C%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%E8%B7%B3%E5%88%B0%E7%AC%AC%204%20%E9%83%A8%E5%88%86%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%E7%94%A8%E4%BA%8E%E5%9C%A8%20i.Mx6%20%E4%B8%8A%E8%BF%90%E8%A1%8C%20PrimeSense%20%2F%20Asus%20Xtion%20%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%9B%AE%E5%89%8D%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87%20apt%20%E8%8E%B7%E5%8F%96%EF%BC%8C%E5%9B%A0%E6%AD%A4%E9%9C%80%E8%A6%81%E4%BB%8E%E6%BA%90%E4%BB%A3%E7%A0%81%E8%BF%9B%E8%A1%8C%E7%BC%96%E8%AF%91%E3%80%82%3CSPAN%20style%3D%22background-position%3A%20initial%3B%22%3E%E8%A6%81%E5%B0%86%20OpenNI2%20%E4%B8%8E%20ROS%20%E7%BB%93%E5%90%88%E4%BD%BF%E7%94%A8%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AA%E9%9C%80%E8%A6%81%E5%85%B1%E4%BA%AB%E7%9A%84%20OpenNI2%20%E5%BA%93%E5%92%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%85%8B%E9%9A%86%20OpenNI2%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14597917753434463%22%20data-renderedposition%3D%221005.7813110351562_50.000003814697266_1158_46%22%20jivemacro_uid%3D%22_14597917753434463%22%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%3CSPAN%3E%24%20git%20clone%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fgithub.com%252FOpenNI%252FOpenNI2%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FOpenNI%2FOpenNI2%3C%2FA%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%24%20cd%20OpenNI2%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2012pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E7%BC%96%E8%BE%91%20ThirdParty%2FPSCommon%2FBuildSystem%2FPlatform.Arm%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14597918000184696%20jive_text_macro%22%20data-renderedposition%3D%221098.6632080078125_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14597918000184696%22%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%24%20nano%20ThirdParty%2FPSCommon%2FBuildSystem%2FPlatform.Arm%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%E5%B9%B6%E6%9B%BF%E6%8D%A2%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14597918643139907%22%20data-renderedposition%3D%221161.7708740234375_50.000003814697266_1158_87%22%20jivemacro_uid%3D%22_14597918643139907%22%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3ECFLAGS%20%2B%3D%20-march%3Darmv7-a%20-mtune%3Dcortex-a9%20-mfpu%3Dneon%20-mfloat-abi%3Dsoftfp%20%23-mcpu%3Dcortex-a8%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%20style%3D%22margin-bottom%3A%2022.5pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%EF%BC%88%E5%B8%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%2022.5pt%3B%20background%3A%20white%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3ECFLAGS%20%2B%3D%20-march%3Darmv7-a%20-mtune%3Dcortex-a9%20-mfpu%3Dneon%20-mfloat-abi%3Dhard%20%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23444444%3B%20background%3A%20white%3B%22%3E%E6%B7%BB%E5%8A%A0%E5%AF%B9%20pthread%20%E5%BA%93%E7%9A%84%E6%94%AF%E6%8C%81%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14597921273262658%20jive_text_macro%22%20data-renderedposition%3D%221303.9931640625_50.000003814697266_1158_363%22%20jivemacro_uid%3D%22_14597921273262658%22%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%24%20nano%20ThirdParty%2FPSCommon%2FBuildSystem%2FCommonCppMakefile%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23444444%3B%20background%3A%20white%3B%20font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20line-height%3A%2026px%3B%22%3E%E6%90%9C%E7%B4%A2%E7%AC%AC95%E8%A1%8C%EF%BC%8C%E5%B9%B6%E5%9C%A8%E4%B8%A4%E8%A1%8C%E4%B9%8B%E9%97%B4%E6%B7%BB%E5%8A%A0%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3EOUTPUT_NAME%20%3D%20%24(EXE_NAME)%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FP%3E%3CPRE%20style%3D%22background%3A%20%23F7F7F7%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23%20We%20want%20the%20executables%20to%20look%20for%20the%20.so's%20locally%20first%3A%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22background%3A%20%23F7F7F7%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20LDFLAGS%20%2B%3D%20-Wl%2C-rpath%20.%2F%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22background%3A%20%23F7F7F7%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%20%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22background%3A%20%23F7F7F7%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%2B%26nbsp%3B%26nbsp%3B%20ifneq%20(%22%24(OSTYPE)%22%2C%22Darwin%22)%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22background%3A%20%23F7F7F7%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20LDFLAGS%20%2B%3D%20-lpthread%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22background%3A%20%23F7F7F7%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%2B%26nbsp%3B%26nbsp%3B%20endif%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22background%3A%20%23F7F7F7%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%20%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22background%3A%20%23F7F7F7%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20OUTPUT_COMMAND%20%3D%20%24(CXX)%20-o%20%24(OUTPUT_FILE)%20%24(OBJ_FILES)%20%24(LDFLAGS)%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22background%3A%20%23F7F7F7%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%20endif%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20style%3D%22margin-bottom%3A%2022.5pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23444444%3B%22%3E%E4%BF%9D%E5%AD%98%E6%96%87%E4%BB%B6%E5%B9%B6%E9%80%80%E5%87%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%2022.5pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%E7%84%B6%E5%90%8E%E8%BF%90%E8%A1%8C%20make%20%E6%9D%A5%E7%BC%96%E8%AF%91%20OpenNI2%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%92%8C%E5%BA%93%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_145979221052968%22%20data-renderedposition%3D%221778.40283203125_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_145979221052968%22%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%24%20PLATFORM%3DArm%20make%20ALLOW_WARNINGS%3D1%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E7%BC%96%E8%AF%91%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%8C%E8%BF%90%E8%A1%8CLinux%E5%AE%89%E8%A3%85%E8%84%9A%E6%9C%AC%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14597922349866091%20jive_text_macro%22%20data-renderedposition%3D%221867.0660400390625_50.000003814697266_1158_43%22%20jivemacro_uid%3D%22_14597922349866091%22%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%24%20cd%20Packaging%2FLinux%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%24%20sudo%20.%2Finstall.sh%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%B0%86%E5%BA%93%E5%92%8C%E5%8C%85%E5%90%AB%E5%A4%8D%E5%88%B6%E5%88%B0%E7%B3%BB%E7%BB%9F%E8%B7%AF%E5%BE%84%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14597922609837380%22%20data-renderedposition%3D%221983.2813720703125_50.000003814697266_1158_98%22%20jivemacro_uid%3D%22_14597922609837380%22%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%24%20cd%20..%2F..%2F%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%24%20sudo%20cp%20-r%20Include%20%2Fusr%2Finclude%2Fopenni2%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%24%20sudo%20cp%20-r%20Bin%2FArm-Release%2FOpenNI2%20%2Fusr%2Flib%2F%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%24%20sudo%20cp%20Bin%2FArm-Release%2FlibOpenNI2.*%20%2Fusr%2Flib%2F%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%E5%88%9B%E5%BB%BA%E5%8C%85%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14597922873338089%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%222154.600830078125_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14597922873338089%22%3E%3CPRE%20style%3D%22margin-bottom%3A%206.25pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%24%20sudo%20nano%20%2Fusr%2Flib%2Fpkgconfig%2Flibopenni2.pc%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%B9%B6%E5%A1%AB%E5%86%99%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14597923063864099%20jive_text_macro%22%20data-renderedposition%3D%222216.041748046875_50.000003814697266_1158_264%22%20jivemacro_uid%3D%22_14597923063864099%22%3E%3CPRE%20style%3D%22margin-bottom%3A%206.25pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3Eprefix%3D%2Fusr%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%206.25pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3Eexec_prefix%3D%24%7Bprefix%7D%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%206.25pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3Elibdir%3D%24%7Bexec_prefix%7D%2Flib%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%206.25pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3Eincludedir%3D%24%7Bprefix%7D%2Finclude%2Fopenni2%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%206.25pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%20%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%206.25pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3EName%3A%20OpenNI2%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%206.25pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3EDescription%3A%20A%20general%20purpose%20driver%20for%20all%20OpenNI%20cameras.%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%206.25pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3EVersion%3A%202.2.0.0%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%206.25pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3ECflags%3A%20-I%24%7Bincludedir%7D%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%206.25pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3ELibs%3A%20-L%24%7Blibdir%7D%20-lOpenNI2%20-L%24%7Blibdir%7D%2FOpenNI2%2FDrivers%20-lDummyDevice%20-lOniFile%20-lPS1080.so%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%E8%BF%99%E5%B0%86%E4%BD%BF%20ubuntu%20%E8%83%BD%E5%A4%9F%E6%89%BE%E5%88%B0%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%81%E5%BA%93%E5%92%8C%E5%8C%85%E5%90%AB%E6%96%87%E4%BB%B6%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82%E4%B8%BA%E4%BA%86%E7%A1%AE%E4%BF%9D%E6%AD%A3%E7%A1%AE%E6%89%BE%E5%88%B0%E5%AE%83%EF%BC%8C%E8%AF%B7%E8%BF%90%E8%A1%8C%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14597923328724752%20jive_text_macro%22%20data-renderedposition%3D%222551.007080078125_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14597923328724752%22%3E%3CPRE%20style%3D%22margin-bottom%3A%206.25pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%24%20pkg-config%20--modversion%20libopenni2%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%AE%83%E5%BA%94%E8%AF%A5%E7%BB%99%E5%87%BA%E4%B8%8E%E4%B8%8A%E9%9D%A2%E7%9A%84%E6%96%87%E4%BB%B6%E4%B8%AD%E5%AE%9A%E4%B9%89%E7%9A%84%E7%9B%B8%E5%90%8C%E7%9A%84%E7%89%88%E6%9C%AC%EF%BC%882.2.0.0%EF%BC%89%E3%80%82%E7%8E%B0%E5%9C%A8%20Xtion%20%E5%B7%B2%E5%8F%AF%E4%BE%9B%E4%BD%BF%E7%94%A8%E3%80%82%E6%8F%92%E5%85%A5%E7%94%B5%E6%BA%90%EF%BC%88%E5%A6%82%E6%9E%9C%E5%B7%B2%E7%BB%8F%E6%8F%92%E5%85%A5%EF%BC%8C%E8%AF%B7%E5%85%88%E6%8B%94%E6%8E%89%EF%BC%89%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BF%90%E8%A1%8C%E7%A4%BA%E4%BE%8B%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14597923605768971%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%222612.447998046875_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14597923605768971%22%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%24%20.%2FBin%2FArm-Release%2FSimpleRead%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%E7%84%B6%E5%90%8E%E6%8C%89%E7%85%A7%20%E6%AD%A4%E5%A4%84%E7%9A%84%20%E8%AF%B4%E6%98%8E%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%20catkin%20%E5%B7%A5%E4%BD%9C%E5%8C%BA%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-330148%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23337ab7%3B%22%3E%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%EF%BC%8C%E5%B9%B6%E5%9C%A8%20catkin%20%E5%B7%A5%E4%BD%9C%E5%8C%BA%E7%9A%84%20src%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E6%A3%80%E5%87%BA%E4%BB%A5%E4%B8%8B%E5%8C%85%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14597924094684859%22%20data-renderedposition%3D%222675.5556640625_50.000003814697266_1158_104%22%20jivemacro_uid%3D%22_14597924094684859%22%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%24%20cd%20~%2Fcatkin_ws%2Fsrc%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%3CSPAN%3E%24%20git%20clone%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fgithub.com%252Fros-drivers%252Fopenni2_camera%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fros-drivers%2Fopenni2_camera%3C%2FA%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%3CSPAN%3E%24%20git%20clone%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fgithub.com%252Fros-drivers%252Fopenni2_launch%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fros-drivers%2Fopenni2_launch%3C%2FA%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%3CSPAN%3E%24%20git%20clone%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fgithub.com%252Fros-drivers%252Frgbd_launch%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fros-drivers%2Frgbd_launch%3C%2FA%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20catkin_make%20%E7%BC%96%E8%AF%91%E4%B8%8A%E9%9D%A2%E7%AD%BE%E5%87%BA%E7%9A%84%20ros%20%E5%8C%85%E5%88%B0%20catkin%20%E5%B7%A5%E4%BD%9C%E5%8C%BA%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14597924310947105%20jive_text_macro%22%20data-renderedposition%3D%222879.097412109375_50.000003814697266_1158_43%22%20jivemacro_uid%3D%22_14597924310947105%22%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%24%20cd%20~%2Fcatkin_ws%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%24%20catkin_make%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%E4%B8%80%E6%97%A6%E8%BD%AF%E4%BB%B6%E5%8C%85%E7%BC%96%E8%AF%91%E5%AE%8C%E6%88%90%EF%BC%8CXtion%20%E5%B0%B1%E5%8F%AF%E4%BB%A5%E4%B8%8E%20ROS%20%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%E4%BA%86%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--744884238%22%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId--744884238%22%20id%3D%22toc-hId-175813338%22%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId-1742628595%22%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId-1742628595%22%20id%3D%22toc-hId--1631641125%22%3E3.%20%E6%B5%8B%E8%AF%95%E5%AE%89%E8%A3%85%3C%2FH1%3E%3COL%20style%3D%22list-style-type%3A%20upper-alpha%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3EKinect%E3%80%82%E6%89%93%E5%BC%80%E8%87%B3%E5%B0%913%E4%B8%AAbash%E7%BB%88%E7%AB%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Helvetica'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%E7%BB%88%E7%AB%AF%201%EF%BC%9A%E8%BF%90%E8%A1%8C%20ROS%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14597924914819495%20jive_text_macro%22%20data-renderedposition%3D%223065.955078125_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14597924914819495%22%3E%3CP%3E%24%20roscore%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E2%20%E5%8F%B7%E8%88%AA%E7%AB%99%E6%A5%BC%EF%BC%9A%E5%90%AF%E5%8A%A8%20Freenect%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14597925208563533%20jive_text_macro%22%20data-renderedposition%3D%223132.62158203125_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14597925208563533%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%23333333%3B%22%3E%24%20roslaunch%20freenect_launch%20freenect.launch%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%208.35pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%E7%BB%88%E7%AB%AF%203%EF%BC%9A%E8%BF%90%E8%A1%8C%E5%9B%BE%E5%83%8F%E6%8D%95%E8%8E%B7%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14597925528714802%22%20data-renderedposition%3D%223200.729248046875_50.000003814697266_1158_126%22%20jivemacro_uid%3D%22_14597925528714802%22%3E%3CPRE%20style%3D%22margin-bottom%3A%208.35pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%23333333%3B%22%3E%24%20rosrun%20image_view%20image_view%20%E5%9B%BE%E5%83%8F%EF%BC%9A%3D%E7%9B%B8%E6%9C%BA%2Frgb%2F%E5%9B%BE%E5%83%8F%E9%A2%9C%E8%89%B2%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%208.35pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%23333333%3B%22%3E%E6%88%96%E8%80%85%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%EF%BC%9A%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%208.35pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%23333333%3B%22%3E%24%20rosrun%20image_view%20image_view%20%E5%9B%BE%E5%83%8F%EF%BC%9A%3D%E7%9B%B8%E6%9C%BA%2Frgb%2Fimage_rect_mono%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%208.35pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%23333333%3B%22%3E%E6%88%96%E8%80%85%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%20%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%208.35pt%3B%20background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%23333333%3B%22%3E%24%20rosrun%20image_view%20disparity_view%20%E5%9B%BE%E5%83%8F%EF%BC%9A%3D%E7%9B%B8%E6%9C%BA%2F%E6%B7%B1%E5%BA%A6%2F%E8%A7%86%E5%B7%AE%3C%2FSPAN%3E%3C%2FPRE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%E5%AE%83%E5%B0%86%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E7%BB%88%E7%AB%AF%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%8C%85%E5%90%AB%E6%9D%A5%E8%87%AA%20Kinect%20%E7%9A%84%20rgb%20%E7%82%B9%E3%80%81%E5%8D%95%E8%89%B2%E5%92%8C%E6%B7%B1%E5%BA%A6%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_73.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_73.png%22%20style%3D%22width%3A%20628px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F27774i34D7102C1AC6D650%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_73.png%22%20alt%3D%22pastedImage_73.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3EXtion%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20Helvetica%2C%20sans-serif%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%E7%BB%88%E7%AB%AF%201%EF%BC%9A%E8%BF%90%E8%A1%8C%20ROS%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14597926481666945%22%20data-renderedposition%3D%223675.538330078125_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14597926481666945%22%3E%3CP%3E%24%20roscore%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E2%E5%8F%B7%E8%88%AA%E7%AB%99%E6%A5%BC%EF%BC%9A%E5%90%AF%E5%8A%A8Openni2%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14597926481356620%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%223742.205078125_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14597926481356620%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%23333333%3B%22%3E%24%20roslaun%20openi2_launch%20openni2.launch%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E7%BB%88%E7%AB%AF%203%EF%BC%9A%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20rqt%20%E6%88%96%20Rviz%20%E4%BC%9A%E8%AF%9D%E6%9D%A5%E5%8F%AF%E8%A7%86%E5%8C%96%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14597926987739665%20jive_text_macro%22%20data-renderedposition%3D%223808.871826171875_50.000003814697266_1158_93%22%20jivemacro_uid%3D%22_14597926987739665%22%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%24%20rqt%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E6%88%96%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20Calibri%2C%20sans-serif%3B%20font-size%3A%2012pt%3B%20line-height%3A%2012pt%3B%22%3E%24%20rosrun%20rqt_graph%20rqt_graph%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23444444%3B%20font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%9C%A8%E2%80%9Crqt%E2%80%9D%E7%AA%97%E5%8F%A3%E4%B8%AD%E9%80%89%E6%8B%A9%E2%80%9C%E6%8F%92%E4%BB%B6%E2%80%9D-%26gt%3B%E2%80%9C%E5%8F%AF%E8%A7%86%E5%8C%96%E2%80%9D-%26gt%3B%E2%80%9C%E5%9B%BE%E5%83%8F%E8%A7%86%E5%9B%BE%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_88.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_88.png%22%20style%3D%22width%3A%20323px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F27951i9C4E6F29EE506D83%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_88.png%22%20alt%3D%22pastedImage_88.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_89.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_89.png%22%20style%3D%22width%3A%20330px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F27720i9ECD515A49C7DD35%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_89.png%22%20alt%3D%22pastedImage_89.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%EF%BC%88%E5%8F%AF%E9%80%89%EF%BC%89%E5%AE%89%E8%A3%85%20PySide%EF%BC%8C%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8C%E6%82%A8%E9%83%BD%E4%BC%9A%E6%94%B6%E5%88%B0%20python%20rqt%20graph%20%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14597927789855513%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%224304.20166015625_50.000003814697266_1158_43%22%20jivemacro_uid%3D%22_14597927789855513%22%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%24%20pip%20install%20PySide%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22margin-bottom%3A%207.5pt%3B%20background-position%3A%20initial%3B%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23333333%3B%22%3E%24%20cd%20~%2F%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9Arqt%20%E5%92%8C%20Rviz%20%E9%9C%80%E8%A6%81%E5%A4%A7%E9%87%8F%20i.MX%20GPU%20%E5%B7%A5%E4%BD%9C%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%B8%80%E8%88%AC%E5%9B%BE%E5%BD%A2%E5%8A%9F%E8%83%BD%E4%BC%9A%E5%8F%97%E5%88%B0%E5%BD%B1%E5%93%8D%E3%80%82%E5%AF%B9%E4%BA%8E%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%EF%BC%8C%E5%BB%BA%E8%AE%AE%E5%9C%A8%E8%BF%9C%E7%A8%8B%E7%BD%91%E7%BB%9C%20ROS%20%E4%BC%9A%E8%AF%9D%E4%B8%AD%E8%BF%90%E8%A1%8C%20rviz%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E5%8F%82%E8%80%83%E8%B5%84%E6%96%99%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E-%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.ros.org%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fwww.ros.org%22%20target%3D%22test_blank%22%3Ewww.ros.org%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E-%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fdobots.nl%2F2014%2F05%2F05%2Fasus-xtion-using-openni2-and-ros-on-udoo%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fdobots.nl%2F2014%2F05%2F05%2Fasus-xtion-using-openni2-and-ros-on-udoo%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttps%3A%2F%2Fdobots.nl%2F2014%2F05%2F05%2Fasus-xtion-using-openni2-and-ros-on-udoo%2F%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-10-2020 03:08 AM
更新人:
