S12X PLL (Filter) Calculator
Document created by iggi Employee on Mar 5, 2015Last modified by ebiz_ws_prod on Dec 13, 2017
Version 8Show Document
  • View in full screen mode
Here are the two utilities which can be used to calculate the following:
- PLL filter component values on HCS12 devices such as MC9S12DP256
- PLL register values on S12(X) devices such as S12XE, S12XF, S12XS, S12P and S12HY.
Both utilities come with appropriate user manuals in PDF.
Original Attachment has been moved to: HCS12-PLL-Filter.exe
Original Attachment has been moved to: S12XE_iPLL_Calc_103.exe
1 person found this helpful
Outcomes
