Resize SD card partition on imx8qxp of Yocto
liuyonggang
Platform:imx8qxp
Environment:Yocto
   currently,I build SD image in Yocto environment.I use dd comand burn SD image into SD card.It was successful and I will found two partitions on SD card.But I have a question.I want to change previous two partition sizes and add a partition at build time.Where can I modify it.
      Tks
BRs
Johnny
joanxie
pls refer to the chapter 4.3.3 Partitioning the SD/MMC card of enclosed file
liuyonggang
Hi Xie,
      I want to change previous two partition sizes and add a partition at build time,other than using fdisk command manually.
      Tks
BRs
Johnny
joanxie
you can find your sdcard layout here, then you can set as you need,generate new class file
meta-fsl-arm/image_types_fsl.bbclass at master · Freescale/meta-fsl-arm · GitHub
liuyonggang
Hi Joan,
      Tks for your comments.
      I have solved this issue last week.
      Your advice is correct.
BRs
Johnny
