Changing I2C speed from userspace
4,421件の閲覧回数
sreedevi_mohan
We are working on IMX8MMini EVK. Is there any method for changing I2C speed from user-space ? We have a requirement like changing I2C speed at run-time.
タグ(1)
3 返答(返信)
4,287件の閲覧回数
sreedevi_mohan
hi
Is it possible to do the same by dynamically Loading Device Tree Overlays into Linux Kernel?
4,287件の閲覧回数
Bio_TICFSL
Hello Sreedevi,
Sorry no. you have to modify the device tree.
4,287件の閲覧回数
radhikasomaiya
Senior Contributor II
Hi [email protected] ,
In older version of kernel is it possible to change IMX_I2C_BIT_RATE to change I2C speed (using module arguments) from userspace. But in newer version to change I2C speed we can change it from device tree.
Radhika Somaiya.
