How to emulating I2C bus slave mode by using FlexIO
385983151
About S32K1xx series MCU,I want to emulating I2C bus slave mode by using FlexIO,but I have not found the slave mode configuration method on the S32DS. And there is only the configuration mode of the master mode in the reference manual. There is no configuration description of the slave mode. I want to know can I emulating I2C bus slave mode with FlexIO? And how to emulate it?
Best regards!
jipengchao
danielmartynek
Hi 385983151@qq.com,
Yes, there is only FlexIO I2C Master SDK driver and the RM provides application information for FlexIO I2C Master only.
This is due to the FlexIO hardware limitations:
AN5133 Emulating I2C Bus Master by using FlexIO.
BR, Daniel
