Problem with connection PCB board MIMXRT1020-EVK and MCUXpresso IDE
nbe
I have a problem with debugging PCB board MIMXRT1020_EVK
How to resolve this problem?
kerryzhou
Hi Nazarii Bezkydech,
    Thank you for your interest in NXP I.MX RT product, I would like to provide service for you.
   1. Please use the according SDK code on your side, you can download it from this link:
 https://mcuxpresso.nxp.com/en/builder
    2. Please refer to this get start to import the SDK code:
   i.MX RT1020 Evaluation Kit|NXP
    3. you can delete the .launch on the MCUXpresso IDE project
  4. Check your board back side, SW8_3 ON,then all SW8_1,SW8_2,SW8_4 OFF.
  5. Please build the project, and download it again. You can test the iled_blinky project.
    This is my test result:
Please try it again.
If you still have problem, you can set SW8_4 ON,then all SW8_1,SW8_2,SW8_3 OFF.
Then download the code, disconnect the debugger, change the SW8 back to SW8_3 ON,then all SW8_1,SW8_2,SW8_4 OFF.again, now try again.
Kerry
kerryzhou
Kerry
nbe
I found a reason why this situation happens because of pins which I use in my program response for downloading and debugging. Needs be more careful with using pins in the program.
nbe
Thanks for your advice,
It good working now.
But now if I try to stop debugging my project a have this problem again.
