I have a problem with debugging PCB board MIMXRT1020_EVK
How to resolve this problem?
解決済! 解決策の投稿を見る。
Hi Nazarii Bezkydech,
Thank you for your interest in NXP I.MX RT product, I would like to provide service for you.
1. Please use the according SDK code on your side, you can download it from this link:
https://mcuxpresso.nxp.com/en/builder
2. Please refer to this get start to import the SDK code:
i.MX RT1020 Evaluation Kit|NXP
3. you can delete the .launch on the MCUXpresso IDE project
4. Check your board back side, SW8_3 ON,then all SW8_1,SW8_2,SW8_4 OFF.
5. Please build the project, and download it again. You can test the iled_blinky project.
This is my test result:
Please try it again.
If you still have problem, you can set SW8_4 ON,then all SW8_1,SW8_2,SW8_3 OFF.
Then download the code, disconnect the debugger, change the SW8 back to SW8_3 ON,then all SW8_1,SW8_2,SW8_4 OFF.again, now try again.
Kerry
Kerry
I found a reason why this situation happens because of pins which I use in my program response for downloading and debugging. Needs be more careful with using pins in the program.
Thanks for your advice,
It good working now.
But now if I try to stop debugging my project a have this problem again.
