S32 DS for ARM and S32K116
hanisamara
i have installed the S32DS 2.0 and 2018 but i can not find in the create new Project wizard under the S32K1xx the S32K116 Controller?
should i install some extra packages or something else?
thank you in advance,
H. Samara
Tags (2)
jiri_kral
did you install updates?
Jiri
kwakd_y
Hello
Google 번역
I called the sample code S32116 by executing it in the way you suggested.
However, the following error persists. How can it be solved?
