where can I find the IO config table for MPC5748G
weimin_li
From NXP website, I download MPC5748GRM.pdf, and in Chapter 4, I find below words:
But within the pdf file, I really can't find any attached excel file.
So, where can I get the IO Signal Description Table?
Thanks.
weimin_li
Thanks david.
Figure out the root course. The application I used to open the pdf, filter the attached file. After I change the pdf reader, then it comes.
Cheers.
davidtosenovjan
You may find it as embedded attachment within reference manual. See screenshot below:
