Is there any document that explains what these pad types mean?
I've searched the Reference Manual and the Datasheet and the I/O spreadsheet. They all mention them, but I am not seeing an explanation of what they really mean.
e.g. the RM says:
"NOTE: Supported input levels vary according to pad types. Pad type "pad_sr_hv" supports only the
CMOS input level, while pad type "pad_isatww_st_hv" supports TTL and CMOS levels. Refer to
the attached IO spreadsheet for the pad type of each pin."
A web search just led me to the 5746R docs I already have.
Any ideas?
James
Hi, for "pad_isatww_st_hv" pads you may choose whether they have TTL or CMOS characteristics as defined in the table below (datasheet screenshot). "pad_sr_hv" pads just have only CMOS characteristics. That's the difference and there is no document for public that would describe it in more details.
OK,
thanks for the reply, I'd gleaned as much already.
I was rather expecting that a public document might explain the rather cryptic pad names more explicitly !
James
