A problem with JN5169 about ZIGBEE network rejoin
2,417 次查看
qingshuzhuang
Hello!
I have a problem with JN5169 about ZIGBEE network rejoin.I hope to get your help.
First I had creaded a network on a coordination,and added a device to this ZIGBEE network,then I exited the device form the network.I hardly kenw I can never add the device to the ZIGBEE network again.
How can I rejoin after exting the network?
标签 (1)
2 回复数
1,912 次查看
mario_castaneda
You have been working on SDK V1518, you have to update the SDK V1745.
Mario
1,912 次查看
qingshuzhuang
Hi:
Thank you for your help!
I solved that problem by upgrading the SDK.
I have another problem: End Devices cannot join the network!
My solution is:
1. Add a key, refer to:https://community.nxp.com/message/985916
2 Modify the code of the old project
     1)Delete the ZPS_vDefaultKeyInit() function.
     2)Add the ZPS_eAplAibSetApsUseExtendedPanId() function, reference: https://community.nxp.com/message/999868
     3)Then refer to the following documentation:
         https://www.nxp.com/docs/en/supporting-information/JN-RN-0059.pdf
         Or
         https://community.nxp.com/docs/DOC-340127
qingshu
