How can i use the S32K DSP
zhanhui
Hello,I'm using S32K to do my project,and i know S32K have FPU an support DSP.
My question is how can i use the DSP  library?IS there has any AN sheet about the DSP use?
robertboys
Hello
This document has an example using the CMSIS-DSP libraries on the S32K-144.
It is a simple example but shows you how to use these libraries.
www.keil.com/appnotes/docs/apnt_299.asp
Bob
danielmartynek
We don’t have an application note for S32K and DSP.
You may refer directly to ARM CMSIS.
A brief description of FPU with DSP instruction summary can be found in Cortex-M4 Technical Reference Manual.
zhanhui
Is there anyone who can answer this question?
