CW5.2 request license
hcnull
i want a licese for CW5.2 ,thank you !
stanish
I'd recommend you to download and install Evaluation edition of CodeWarrior for HCs12 v5.2.
If you already installed you might not be able to extend the license again (there is a limit 3 evaluation extensions across all CodeWarior products).
I attached is the 30-day evaluation license for your convenience
Hope it helps.
Stan
