Support CANFD controller
jiayinguo
Hi everyone,
 Whether SJA1000 support CANFD with S32K144 ?if not,I want to use s32k144, which canfd controller is my best choose.
Jia Yin
Tags (3)
lukaszadrapa
FlexCAN module which supports CAN FD is already implemented in S32K144. So you do not need external standalone CAN controller like SJA1000. All you need is CAN FD transceiver. You can check this selector guide to select the right one:
http://www.nxp.com/documents/line_card/75017381.pdf
Lukas
jiayinguo
Hi Lukas,
 thank you for me killing  this trouble , I want to buy  "S32K144 BLDCRD: 3-phase Sensorless BLDC Motor Control Reference Design Based on S32K144 MCUs" ,like this:3-phase Sensorless BLDC Motor Control RD|NXP ,But I can't find it . Could you tell me what should I do ?
many many thanks ~
Jia Yin
lukaszadrapa
I just talked with engineer who is working on this. There will be reference design (including SW application) based on S32K144EVB + DEVKIT-MOTORGD. It's not ready yet, I'm still not sure about the release date.
Lukas
