Hello everybody,when I loading program with MDK it appears unable to find device information.PE34298
jingwang
alexandreaugust
Dear Jing Wang;
  I guess this problem is associated the missing of "Freescale Kinetis OSJTAG Drivers V1.20". So I recommed !@ you to install it, from the webpage http://www.keil.com/download/docs/408.asp
  The driver "  FslKinetisDriversV120.EXE" is necessary to be installed on your PC.
  Read and follow STEP BY STEP the procedure for those documents, they will help to correct install and setup of FRDM-KL25Z using Keil IDE.
   Keil_v5_FRDM_KL25Z_install.pdf   ( http://www.microdigitaled.com/ARM/Freescale_ARM/Tutorial/Keil_v5_FRDM_KL25Z_install.pdf )
   Keil_v5_FRDM_KL25Z_project.pdf (http://www.microdigitaled.com/ARM/Freescale_ARM/Tutorial/Keil_v5_FRDM_KL25Z_project.pdf )
  Best Regards
Alexandre Augusto
