What is the best way to learn how program Graphics on LCD
danieljackmorle
I am looking for a development Kit to run a small video in an LCD window.  I am mostly a hardware engineer and it has been 6 years since I developed code.   I am thinking the K70 is where I am starting.  The demo online does what I want.  I also want a USB peripheral.  The question is what is the best way to learn how to do this large task.  I am also looking into Easy GUI or embedded wizard.
LuisCasado
danieljackmorle
Hi Luis
I looked at both K70 and the MX6 and I decided to go with the MCIMX6UL mostly on your recommendation and the fact that the chip cost less than the K70.  I want to . use the following kits to get started
LCD8000-43T
i.MX6UltraLite Evaluation Kit (EVK)
What kind of compiler does this require
I would like to follow a path that is well explored.   You mentioned an embedded Linux solution.   Would that have some sample software that I could use?
My goal is to use the kits to get more familiar with the processes.
danieljackmorle
Does the MQX require an operating system?   I like the prices on this part better.
LuisCasado
MQX is an operating system.  www.nxp.com/mqx
eGUI is the graphic library. www.nxp.com/egui
eGUI doesn't need an Operating system.
Luis
LuisCasado
Hi Daniel Morley ,
We don't have a video player solution for the K70. It is possible with some limitations to play videos. Cortex M4 doesn't have enough performance for running video decoders.
https://www.youtube.com/watch?v=n-asY6CR6nk
You can check with Motomic. A  better solution would be the MCIMX6UL running Linux.
Luis
LuisCasado
You can also check the LPC based solution:
https://www.lpcware.com/content/blog/frame-video-player-lpc1788
Luis
danieljackmorle
I decided to ax the video. Sounds too complicated.  Do you offer a LCD color display interface solution.   Defiantly trying to work with out an operating system.
LuisCasado
You can use eGUI with MQX or bare metal.  Use the latest sources:
https://github.com/Gargy007/eGUI
Check also this: https://community.freescale.com/docs/DOC-330064
Luis
