i can import ,sample codes of ksdk for mk22f in kds3.0,it shows Program "make" not found in PATH      error..
dhanalakshmisre
ivadorazinova
Hi ,
Please, go to File -> Import in KDS (or right click in Project Explorer)
And compile first library (ksdk_platform_lib_K22F51212) and then project.wsd_6.png
I hope this helps you,
Iva
dhanalakshmisre
Thank u for ur reply..I import the library file also shows same error
ivadorazinova
yes, I see your question.
Please do you have correctly installed KSDK into KDS?
The procedure is described here http://cache.freescale.com/files/microcontrollers/doc/user_guide/KDSUG.pdf?fsrch=1 page 62.
Thank you,
Iva
