SoloX field upgrade through Ethernet
ScottKerstein
It's desired to get field upgrades via an Ethernet connection through a IOT website connection.  Are there any app notes might exist to doing this on a SoloX, or just i.MX6 in general?
    1. Need a way to ensure a failed upgrade does not compromise the machine and not enable it to take a subsequent upgrade
    2. Would like a way to separate out the images so the GUI application can be upgraded separately from the rootfs and kernel
    3. Would like to be able to sign and possibly encrypt the upgrade images.
Thanks, in advance.
Scott
Labels (3)
JasonMoss
Scott,
You may want to check out work done in the community by Stefano Babic at Denx (i.MX U-boot Custodian).
Updating an embedded system — Embedded Software Update Documentation 2014.07 documentation
Here is a recent presentation on the topic:
http://events.linuxfoundation.org/sites/events/files/slides/SoftwareUpdateForEmbedded.pdf
Jason
317.908.5314
jamesbone
It seems that you want to have something similar to what Google Play does, in Android which allows to upgrade the application without touching the system just the application,  I would recommend to use Android as platform, and customize it, since it is prepared to such application
