Hello Champs,
There is a description in i.MX50 RM Page 2284
"RECOVER_ON UNDERFLOW
Set this bit to enable the eLCDIF block to recover in the next field/frame if there was an underflow in the current field/frame."
In the OBDS, this bit is set.
What do they do this for this in OBDS?
Could you explain how the next field/frame can be recovered in underflow conditions?
For example, duplicate current frame for the next frame, etc...
Nori Shinozaki
