Physical size of iMX6 decoupling capacitors
emil
On your Sabre SD development board you have 0201 capacitors directly under the iMX6 package for decoupling. Is it possible to use 0402 capacitors for this instead, or would that lead to insufficient decoupling?
YixingKong
Senior Contributor IV
Emil
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
YixingKong
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel
free to reply with an update to this discussion.
Yixing
weidong_sun
Hello, emil,
     Normally, we use 0201 packages. But if you wants to use 0402, you will have to reduce numbers of those capacitors. My personal advice is that you can reduce numbers to half of those on i.mx6 EVK board.
Weidong
weidong_sun
Hello,Emil,
     Did you resolve your question ? If it was ok, Please press "correct answer" or "helpful answer" button to close this post  !
Weidong
