K60 120MHz CAN example
apanecatl
Senior Contributor II
I received a couple of requests for CAN code examples for K60_120MHz, ans it seems the KINETIS_120MHZ_SC.zip does not contain a CAN example, so I'm posting our CAN evaluation code for the board, I hope this comes useful to those interested in it.
Ivan Robles
adrianb
Hi Pedro,
I'm curios if this code will work on TWR-K70F120M, can you please tell me this? i can see in IAR that it has a K70 config?
Adrian.
sruthyuk
Hi Pedro,
I cant open the codes in flexcan-val-code.7z.zip .A WinRAR diagonistic message is coming.What may be the reason?? Could you please post the  CAN code examples for K60_120MHz once more??
Best Regards
sruthy uk
