how to integrate the external Wi-Fi BT module on the IMX8QuadMax MEK
K_Varun
Dear Community,
I have installed the following Wi-Fi BT module in the slot of my i.MX8QM MEK board and flashed Auto 13 OS.
Wi -Fi BT module link : https://in.element14.com/laird/st60-2230c-u/bt-wifi-module-2-4-2-495-5-15/dp/3407266
I am facing some issues and need guidance:
  1. I cannot see any local wi-fi or Bluetooth devices on the settings page after flashing the OS.
  2. How can I check if the module is functioning correctly?
  3. Is this module compatible with the IMX8QM-MEK board?
  4. What changes are required to make the module work?
Your support on this matter would be greatly appreciated.
K. Varun
K_Varun
Dear Community,
Can someone please reply on this query. It helps me a lot.
K Varun
