audio capture solution from multiple analog microphones
905 次查看
yigang
I want to design an audio capture board, which need to capture multiples channels audio (no sync requirements between channels) from microphones to high quality PCM output, in order to speed up the design, is there any simplifier solution, such as 'ADC+DSP', or 'ADC+MCU' solution available? Does NXP has the SOC products for industry applications that already integrated ADC & DSP(MCU) with algorithm together? Thanks.
0 回复数
