CAAM secure (tagged) keys with openssl
4,950 次查看
tmayr
we set up an iMX6 board with secure boot and CAAM support enabled, and also configured file-system encryption using CAAM and secure keys (tagged keys).
Now we'd like to use tagged keys with openssl (AES) as well. We managed to configure CAAM as engine for openssl, using cryptodev. However, only non-tagged-key algorithms (e.g. aes-256-cbc) are available in openssl.
How can we tell openssl about the tagged key algorithms?
I found this document about how to use black keys with openssl for asymmetric crypto operations, but has anything similar already been done for AES (e.g. aes-256-cbc-tk)?
Tobias
7 回复数
3,699 次查看
Fabien_M
Hello @igorpadykov ,
I would also like to use AES openssl with black keys.
May I also get the procedure and patch please ?
Note : I use 5.15.52 BSP on iMX8mp.
Fabien
4,811 次查看
igorpadykov
Hi Tobias
from team:
Please tell me your BSP version. I think this need to be done by adding some custom code to link the tagged key transform. It can't be selected autonomously. Please share test code or patch to reproduce on our side.
4,794 次查看
tmayr
Hi Igor,
This is the BSP we are using: https://github.com/varigit/variscite-bsp-platform/tree/dunfell
I'm not sure what the team means by "code or patch to reproduce on our side", but I would like to do something like
openssl enc -e -engine cryptodev -in plainfile -out cryptofile aes-256-cbc-tk -K blackkey
to encrypt a plainfile using the provided blackkey (note the -tk in the cipher, which obviously openssl doesn't know about), through the CAAM (e.g. with cryptodev).
This doesn't work out of the box, and it would be cool to know what's missing.
Tobias
4,677 次查看
igorpadykov
procedure and verification patch were sent via mail.
292 次查看
RajuH
Hi Igor,
Can you also share the procedure and verification patches. We are also trying to integrate this soultion
1,774 次查看
jborregos
Can i get the path for the -tk solution?
Thanks!!!
3,508 次查看
ahightower
Has this been mainlined in the past year?  What was the resolution of this?
