Adeneo Embedded: Building Qt 5.1 for Freescale i.MX6 – A white paper by Cuong Chou
Introduction
Required Software
Build procedure:
-no-c++11 \
make install
/home/trainee/BSP/L3.0.35_4.0.0_130424_source/ltib/rootfs/
10 years, Adeneo Embedded has helped clients, in all stages of development; create profitable, feature-rich products that incorporate software and hardware solutions based on Android, Embedded Linux, Windows Embedded or Windows Mobile operating systems. Close working partnerships with industry-leading silicon and software vendors allow Adeneo Embedded to apply its experience to a wide range
of embedded solutions for the automotive, industrial, medical, multi-media, navigation, networking, mobile and wireless markets. Adeneo Embedded has a global sales and support network backed by engineering offices in North America and Europe.
For more information about Adeneo Embedded competences, products and services around Windows Embedded technologies:
- Mark as Read
- Mark as New
- Bookmark
- Permalink
- Report Inappropriate Content
Hello:
thanks for your share ,but follow your steps above,there is no error ,but when I run the demo
$ ./hellogl_es |
it appear
QIconvCodec::convertFromUnicode: using Latin-1 for conversion, iconv_open failed
QIconvCodec::convertToUnicode: using Latin-1 for conversion, iconv_open failed
Segmentation fault
i don't know why ,can u help me
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Thanks for looking at the paper.
I could see there are 2 potential causes to the problem you're seeing:
1. The galcore module is not installed or not installed properly.
2. The version of your kernel doesn't match the version of the Vivante GPU libraries. For example, if you are using a Linux 3.0.35 4.1.0, you need to have the Vivante GPU libraries 4.1.0 and not the version 4.0.0.
Hope this helps.
- Mark as Read
- Mark as New
- Bookmark
- Permalink
thanks for you replay,and last week ,I used 4.00 ltib ,and have no error!
- Mark as Read
- Mark as New
- Bookmark
- Permalink
Hello all,
Can you provide me LTIB 4.0.0 for imx6 Sabre?
I'm interesting to following this tutorial, but freescale only have available the latest version on your website.
Cheers
