Recognition model for microcontroller use
In the SDK_2.7.0_EVKB-IMXRT1050, it contains some eIQ machine learning demo projects, there's the tensorflow_lite_kws among them.
It's a keyword spotting example that is based on Keyword spotting for Microcontrollers and it deploys a deepwise separable convolutional neural network called MobileNet in this demo project. It can classify a one-second audio clip as either silence, an unknown word, "yes", "no", "up", "down", "left", "right", "on", "off", "stop", or "go".
Figure 1 shows the components that comprise it.
Fig 1
Training Our New Model
The model we are using is trained with the TensorFlow script which is designed to demonstrate how to build and train a model for audio recognition using TensorFlow.
The script makes it very easy to train an audio recognition model. Among other things, it allows us to do the following:
  1. Download a dataset with audio featuring 20 spoken words.
  2. Choose which subset of words to train the model on.
  3. Specify what type of preprocessing to use on the audio.
  4. Choose from several different types of the model architecture.
  5. Optimize the model for microcontrollers using quantization.
When we run the script, it downloads the dataset, trains a model, and outputs a file representing the trained model. We then use some other tools to convert this file into the correct form for TensorFlow Lite.
Training in virtual machine (VM)
Preparation
Make sure the TensorFlow has been installed, and since the script downloads over 2GB of training data, it'll need a good internet connection and enough free space on the machine.
Note that: The training process itself can take several hours, be patient.
Training
To begin the training process, use the following commands to clone ML-KWS-for-MCU.
git clone https://github.com/ARM-software/ML-KWS-for-MCU.git‍‍‍‍‍
The training scripts are configured via a bunch of command-line flags that control everything from the model’s architecture to the words it will be trained to classify.
The following command runs the script that begins training. You can see that it has a lot of command-line arguments:
python ML-KWS-for-MCU/train.py --model_architecture ds_cnn --model_size_info 5 64 10 4 2 2 64 3 3 1 1 64 3 3 1 1 64 3 3 1 1 64 3 3 1 1 \
--wanted_words=zero, one, two, three, four, five, six, seven, eight, nine \
--dct_coefficient_count 10 --window_size_ms 40 \
--window_stride_ms 20 --learning_rate 0.0005,0.0001,0.00002 \
--how_many_training_steps 10000,10000,10000 \
--data_dir=./speech_dataset --summaries_dir ./retrain_logs --train_dir ./speech_commands_train ‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Some of these, like --wanted_words=zero, one, two, three, four, five, six, seven, eight, nine. By default, the selected words are yes, no, up, down, left, right, on, off, stop, go, but we can provide any combination of the following words, all of which appear in our dataset:
  • Common commands: yes, no, up, down, left, right, on, off, stop, go, backward, forward, follow, learn
  • Digits zero through nine: zero, one, two, three, four, five, six, seven, eight, nine
  • Random words: bed, bird, cat, dog, happy, house, Marvin, Sheila, tree, wow
Others set up the output of the script, such as --train_dir=/content/speech_commands_train, which defines where the trained model will be saved. Leave the arguments as they are, and run it. The script will start off by downloading the Speech Commands dataset (Figure 2), which consists of over 105,000 WAVE audio files of people saying thirty different words. This data was collected by Google and released under a CC BY license, and you can help improve it by contributing five minutes of your own voice. The archive is over 2GB, so this part may take a while, but you should see progress logs, and once it's been downloaded once you won't need to do this step again. You can find more information about this dataset in this Speech Commands paper.
Fig 2
Once the downloading has completed, some more output will appear. There might be some warnings, which you can ignore as long as the command continues running. Later, you'll see logging information that looks like this (Figure 3).
Fig 3
This shows that the initialization process is done and the training loop has begun. You'll see that it outputs information for every training step. Here's a break down of what it means:
  • Step shows that we're on the step of the training loop. In this case, there are going to be 30,000 steps in total, so you can look at the step number to get an idea of how close it is to finishing.
  • rate is the learning rate that's controlling the speed of the network's weight updates. Early on this is a comparatively high number (0.0005), but for later training cycles it will be reduced 5x, to 0.0001, then to 0.00002 at last.
  • accuracy is how many classes were correctly predicted on this training step. This value will often fluctuate a lot, but should increase on average as training progresses. The model outputs an array of numbers, one for each label, and each number is the predicted likelihood of the input being that class. The predicted label is picked by choosing the entry with the highest score. The scores are always between zero and one, with higher values representing more confidence in the result.
  • cross-entropy is the result of the loss function that we're using to guide the training process. This is a score that's obtained by comparing the vector of scores from the current training run to the correct labels, and this should trend downwards during training.
  • checkpoint
    After a hundred steps, you should see a line like this:
    This is saving out the current trained weights to a checkpoint file (Figure 4). If your training script gets interrupted, you can look for the last saved checkpoint and then restart the script with --start_checkpoint=/tmp/speech_commands_train/best/ds_cnn_xxxx.ckpt-400 as a command line argument to start from that point .
Fig 4
  • Confusion Matrix
    After four hundred steps, this information will be logged:
    The first section is a confusion matrix. To understand what it means, you first need to know the labels being used, which in this case are "silence", "unknown", "zero", "one", "two", "three", "four", "five", "six", "seven", "eight", and "nine". Each column represents a set of samples that were predicted to be each label, so the first column represents all the clips that were predicted to be silence, the second all those that were predicted to be unknown words, the third "zero", and so on.
    Each row represents clips by their correct, ground truth labels. The first row is all the clips that were silence, the second clips that were unknown words, the third "zero", etc.
    This matrix can be more useful than just a single accuracy score because it gives a good summary of what mistakes the network is making. In this example you can see that all of the entries in the first row are zero (Figure 5), apart from the initial one. Because the first row is all the clips that are actually silence, this means that none of them were mistakenly labeled as words, so we have no false negatives for silence. This shows the network is already getting pretty good at distinguishing silence from words.
    If we look down the first column though, we see a lot of non-zero values. The column represents all the clips that were predicted to be silence, so positive numbers outside of the first cell are errors. This means that some clips of real spoken words are actually being predicted to be silence, so we do have quite a few false positives.
    A perfect model would produce a confusion matrix where all of the entries were zero apart from a diagonal line through the center. Spotting deviations from that pattern can help you figure out how the model is most easily confused, and once you've identified the problems you can address them by adding more data or cleaning up categories.
                                                           Fig 5
  • Validation
    After the confusion matrix, you should see a line like Figure 5 shows.
    It's good practice to separate your data set into three categories. The largest (in this case roughly 80% of the data) is used for training the network, a smaller set (10% here, known as "validation") is reserved for evaluation of the accuracy during training, and another set (the last 10%, "testing") is used to evaluate the accuracy once after the training is complete.
    The reason for this split is that there's always a danger that networks will start memorizing their inputs during training. By keeping the validation set separate, you can ensure that the model works with data it's never seen before. The testing set is an additional safeguard to make sure that you haven't just been tweaking your model in a way that happens to work for both the training and validation sets, but not a broader range of inputs.
    The training script automatically separates the data set into these three categories, and the logging line above shows the accuracy of model when run on the validation set. Ideally, this should stick fairly close to the training accuracy. If the training accuracy increases but the validation doesn't, that's a sign that overfitting is occurring, and your model is only learning things about the training clips, not broader patterns that generalize
Training Finished
In general, training is the process of iteratively tweaking a model’s weights and biases until it produces useful predictions. The training script writes these weights and biases to checkpoint files (Figure 6).
Fig 6
A TensorFlow model consists of two main things:
  • The weights and biases resulting from training
  • A graph of operations that combine the model’s input with these weights and biases to produce the model’s output
At this juncture, our model’s operations are defined in the Python scripts, and its trained weights and biases are in the most recent checkpoint file. We need to unite the two into a single model file with a specific format, which we can use to run inference. The process of creating this model file is called freezing—we’re creating a static representation of the graph with the weights frozen into it.
To freeze our model, we run a script that is called as follows:
python ML-KWS-for-MCU/freeze.py --model_architecture ds_cnn --model_size_info 5 64 10 4 2 2 64 3 3 1 1 64 3 3 1 1 64 3 3 1 1 64 3 3 1 1 \
--window_stride_ms 20 --checkpoint ./speech_commands_train/best/ds_cnn_9490.ckpt-21600 \
--output_file=./ds_cnn.pb‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
To point the script toward the correct graph of operations to freeze, we pass some of the same arguments we used in training. We also pass a path to the final checkpoint file, which is the one whose filename ends with the total number of training steps.
The frozen graph will be output to a file named ds_cnn.pb. This file is the fully trained TensorFlow model. It can be loaded by TensorFlow and used to run inference. That’s great, but it’s still in the format used by regular TensorFlow, not TensorFlow Lite.
Convert to TensorFlow Lite
Conversion is a easy step: we just need to run a single command. Now that we have a frozen graph file to work with, we’ll be using toco, the command-line interface for the TensorFlow Lite converter.
toco --graph_def_file=./ds_cnn.pb --output_file=./ds_cnn.tflite \
--input_shapes=1,49,10,1 --input_arrays=Reshape_1 --output_arrays='labels_softmax' \
--inference_type=QUANTIZED_UINT8 --mean_values=227 --std_dev_values=1 \
--change_concat_input_ranges=false \
--default_ranges_min=-6 --default_ranges_max =6‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
In the arguments, we specify the model that we want to convert, the output location for the TensorFlow Lite model file, and some other values that depend on the model architecture. we also provide some arguments (inference_type, mean_values, and std_dev_values) that instruct the converter how to map its low-precision values into real numbers.
The converted model will be written to ds_cnn.tflite, this a fully formed TensorFlow Lite model!
Create a C array
We’ll use the xxd command to convert a TensorFlow Lite model into a C array in the following.
xxd -i ./ds_cnn.tflite > ./ds_cnn.h
cat ./ds_cnn.h‍‍‍‍‍‍
The final part of the output is the file’s contents, which are a C array and an integer holding its length, as follows:
Fig 7
Next, we’ll integrate this newly trained model with the tensorflow_lite_kws project.
Using the Model in tensorflow_lite_kws Project
To use the new model, we need to do two things:
  1. In source/ds_cnn_s_model.h, replace the original model data with our new model.
  2. Update the label names in source/kws.cpp with our new ''zero'', ''one'', ''two'', ''three'', ''four'', ''five'', ''six'', ''seven'', ''eight'' and ''nine'' labels.
const std::string labels[] = {"Silence", "Unknown","zero", "one", "two", "three","four", "five", "six", "seven","eight", "nine"};‍‍
Before running the model in the EVKB-IMXRT1050 board (Figure 8), please refer to the readme.txt to do the preparation, in further, the file also demonstrates the steps of testing, please follow them.
Fig 8
Figure 9 shows the testing I did, I've attached the model file, please give a try by yourself.
Fig 9
ラベル(2)
添付
コメント
@jeremyzhou, First of all thanks for this example. I bought the board and followed the instructions to add KSW to IMXRT1050 board. I am stuck at final stage at section:
I cant find source/ds_cnn_s_model.h to replace the trained ds_cnn.h. I have searched online and in downloaded SDK_2.7.0_EVKB-IMXRT1050. There is no kws_tensorflow_lite example nor directory in it.
Appreciate your quick help here.
Hi ,
In the MCUXpreeso, expand the source fold on the Workspace window, you can see the ds_cnn_s_mode.h, as below shows.
BR,
Jeremy
Thanks jeremyzhou for your quick response. My problem is that I cant find the project kws_tensorflow_lite. Your screen shot shows only the source folder. Not sure how you got the source folder in your IDE? Which project is it? Can you please share the link to that?
I have searched the downloaded MCUExpresso IDE workspace folder (C:\Users\B2F\Documents\MCUXpressoIDE_11.1.1_3241\workspace) which came with all examples, but no luck. Is there some kind of version mismatch?
As I point out at the beginning of this article, the tensorflow_lite_kws demo is from the SDK_2.7.0_EVKB-IMXRT1050, and you can download this SDK library via the below link. Then install the SDK library in the MCUXpreeso IDE, after that, you can load the  tensorflow_lite_kws demo.
So please give a try.
https://mcuxpresso.nxp.com/en/welcome
BR,
Jeremy
jeremyzhou‌, turns out I had followed all the steps but never selected eiq while building the SDK and hence it was missing.
Now that I have it, I cant import any of eiq examples including tensorflow_lite_kws
"tensorflow_lite_kws] The project 'tensorflow_lite_kws' refers to the external XML file, but it cannot be found!"
On eiq
Thanks for your reply.
It seems a bit weird, I've not encountered it before.pastedImage_1.pngird,
So I'd like to suggest you delete the installed SDK library and clean-up the projects in the workspace directory, then build a complete new SDK library (as below shows), then install it to the MCUXpresso IDE.
After doing that, reimport the eIQ demos again.
BR,
Jeremy
Yes Only selecting eid with tensorflow_lite_kws worked great. I am able to test deault Keywords and the 0 to 9. Just that the recognition is not very accurate.
Also do you know if I can increase the label size from 12 to 20? Where I can add numbers to existing buffer, combining both models data? I tried but didnt work.
Do you have any project where you used the display in your picture above based on KSW? I am trying to display the output on the screen rather than on Tera Term.
Hi ,
1) Do you know if I can increase the label size from 12 to 20?
-- Yes, you can, however, it needs to train a completely new model for that, and the article has already demonstrated the training procedure.
2) Do you have any project where you used the display in your picture above based on KSW?
-- In the SDK library, there're some GUI demos, maybe you can refer to them.
BR,
Jeremy
%3CLINGO-SUB%20id%3D%22lingo-sub-1103364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%9E%E3%82%A4%E3%82%B3%E3%83%B3%E7%94%A8%E8%AA%8D%E8%AD%98%E3%83%A2%E3%83%87%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3ESDK_2.7.0_EVKB-IMXRT1050%E3%81%AB%E3%81%AF%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AEeIQ%E6%A9%9F%E6%A2%B0%E5%AD%A6%E7%BF%92%E3%83%87%E3%83%A2%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%E4%B8%AD%E3%81%AB%E3%81%AF%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSTRONG%20class%3D%22%22%3Etensorflow_lite_kws%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Farxiv.org%2Fpdf%2F1711.07128.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AE%E3%82%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%89%E3%82%B9%E3%83%9D%E3%83%83%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%3C%2FA%3E%20%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E3%82%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%89%E3%82%B9%E3%83%9D%E3%83%83%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E3%83%87%E3%83%A2%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%AFMobileNet%E3%81%A8%E5%91%BC%E3%81%B0%E3%82%8C%E3%82%8B%E6%B7%B1%E3%81%8F%E5%88%86%E9%9B%A2%E5%8F%AF%E8%83%BD%E3%81%AA%E7%95%B3%E3%81%BF%E8%BE%BC%E3%81%BF%E3%83%8B%E3%83%A5%E3%83%BC%E3%83%A9%E3%83%AB%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%92%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%821%20%E7%A7%92%E9%96%93%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%20%E3%82%AF%E3%83%AA%E3%83%83%E3%83%97%E3%82%92%E3%80%81%E7%84%A1%E9%9F%B3%E3%80%81%E4%B8%8D%E6%98%8E%E3%81%AA%E5%8D%98%E8%AA%9E%E3%80%81%22%E3%81%AF%E3%81%84%22%E3%80%81%22%E3%81%84%E3%81%84%E3%81%88%22%E3%80%81%22%E4%B8%8A%22%E3%80%81%22%E4%B8%8B%22%E3%80%81%22%E5%B7%A6%22%E3%80%81%22%E5%8F%B3%22%E3%80%81%22%E3%82%AA%E3%83%B3%22%E3%80%81%22%E3%82%AA%E3%83%95%22%E3%80%81%22%E5%81%9C%E6%AD%A2%22%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%20%22%E5%AE%9F%E8%A1%8C%22%20%E3%81%AB%E5%88%86%E9%A1%9E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%9B%B3%201%20%E3%81%AB%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.jpg%22%20style%3D%22width%3A%20839px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F97314i659F7052ABD670C1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.jpg%22%20alt%3D%22pastedImage_1.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E5%9B%B31%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20class%3D%22%22%20id%3D%22toc-hId-380577421%22%20style%3D%22font-weight%3A%20bold%3B%20text-rendering%3A%20optimizelegibility%3B%20font-size%3A%202rem%3B%20margin%3A%200.8em%200px%200.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20id%3D%22toc-hId-380577421%22%20id%3D%22toc-hId-1304185962%22%3E%3CSPAN%20class%3D%22%22%3E%E6%96%B0%E3%81%97%E3%81%84%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AF%E3%80%81TensorFlow%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E9%9F%B3%E5%A3%B0%E8%AA%8D%E8%AD%98%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%8A%E3%82%88%E3%81%B3%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E9%9F%B3%E5%A3%B0%E8%AA%8D%E8%AD%98%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%8C%E9%9D%9E%E5%B8%B8%E3%81%AB%E7%B0%A1%E5%8D%98%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%A8%E3%82%8A%E3%82%8F%E3%81%91%E3%80%81%E6%AC%A1%E3%81%AE%E3%81%93%E3%81%A8%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3COL%20class%3D%22%22%20style%3D%22padding%3A%200px%3B%20margin%3A%201.1em%200px%201.1em%203em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E20%20%E3%81%AE%E8%A9%B1%E3%81%97%E8%A8%80%E8%91%89%E3%82%92%E7%89%B9%E5%BE%B4%E3%81%A8%E3%81%99%E3%82%8B%E9%9F%B3%E5%A3%B0%E3%82%92%E5%90%AB%E3%82%80%E3%83%87%E3%83%BC%E3%82%BF%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%8D%98%E8%AA%9E%E3%81%AE%E3%82%B5%E3%83%96%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%89%8D%E5%87%A6%E7%90%86%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%81%8B%E3%82%89%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%E9%87%8F%E5%AD%90%E5%8C%96%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E3%81%8C%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%80%81%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E8%A1%A8%E3%81%99%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81%E4%BB%96%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%20TensorFlow%20Lite%20%E3%81%AE%E6%AD%A3%E3%81%97%E3%81%84%E5%BD%A2%E5%BC%8F%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH1%20class%3D%22%22%20id%3D%22toc-hId--1426877042%22%20style%3D%22font-weight%3A%20bold%3B%20text-rendering%3A%20optimizelegibility%3B%20font-size%3A%202rem%3B%20margin%3A%200.8em%200px%200.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20id%3D%22toc-hId--1426877042%22%20id%3D%22toc-hId--503268501%22%3E%3CSPAN%20class%3D%22%22%3E%E4%BB%AE%E6%83%B3%E3%83%9E%E3%82%B7%E3%83%B3%20(VM)%20%E3%81%A7%E3%81%AE%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FH1%3E%3CDIV%20class%3D%22%22%20style%3D%22overflow%3A%20hidden%3B%20float%3A%20right%3B%22%3E%3CA%20id%3D%22preparation_3%22%20name%3D%22preparation_3%22%20style%3D%22color%3A%20%230088cc%3B%20text-decoration%3A%20none%3B%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CA%20style%3D%22color%3A%20%230088cc%3B%20text-decoration%3A%20none%3B%20float%3A%20right%3B%20width%3A%201px%3B%20height%3A%200px%3B%20visibility%3A%20hidden%3B%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CA%20id%3D%22preparation%22%20name%3D%22preparation%22%20style%3D%22color%3A%20%230088cc%3B%20text-decoration%3A%20none%3B%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3CA%20style%3D%22color%3A%20%230088cc%3B%20text-decoration%3A%20none%3B%20float%3A%20right%3B%20width%3A%201px%3B%20height%3A%200px%3B%20visibility%3A%20hidden%3B%22%20target%3D%22_blank%22%3E%3C%2FA%3E%3C%2FDIV%3E%3CH2%20class%3D%22%22%20id%3D%22toc-hId--736315568%22%20style%3D%22font-weight%3A%20bold%3B%20text-rendering%3A%20optimizelegibility%3B%20font-size%3A%201.8rem%3B%20margin%3A%200.7em%200px%200.5em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20id%3D%22toc-hId--736315568%22%20id%3D%22toc-hId-187292973%22%3E%3CSPAN%20class%3D%22%22%3E%E6%BA%96%E5%82%99%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3ETensorFlow%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AF2GB%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E8%89%AF%E5%A5%BD%E3%81%AA%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%8D%E3%83%83%E3%83%88%E6%8E%A5%E7%B6%9A%E3%81%A8%E3%83%9E%E3%82%B7%E3%83%B3%E4%B8%8A%E3%81%AE%E5%8D%81%E5%88%86%E3%81%AA%E7%A9%BA%E3%81%8D%E5%AE%B9%E9%87%8F%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%82%B9%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%20%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E8%87%AA%E4%BD%93%E3%81%AF%E6%95%B0%E6%99%82%E9%96%93%E3%81%8B%E3%81%8B%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%81%97%E3%81%B0%E3%82%89%E3%81%8F%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CH2%20class%3D%22%22%20id%3D%22toc-hId-1751197265%22%20style%3D%22font-weight%3A%20bold%3B%20text-rendering%3A%20optimizelegibility%3B%20font-size%3A%201.8rem%3B%20margin%3A%200.7em%200px%200.5em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20id%3D%22toc-hId-1751197265%22%20id%3D%22toc-hId--1620161490%22%3E%3CSPAN%20class%3D%22%22%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20ML-KWS-for-MCU%20%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3Egit%20clone%20https%3CSPAN%20class%3D%22punctuation%20token%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%2F%3C%2FSPAN%3Egithub%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ecom%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3EARM%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esoftware%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3EML%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3EKWS%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22keyword%20token%22%3Efor%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3EMCU%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Egit%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AF%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%81%8B%E3%82%89%E5%88%86%E9%A1%9E%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%82%8B%E5%8D%98%E8%AA%9E%E3%81%BE%E3%81%A7%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%99%E3%82%8B%E4%B8%80%E9%80%A3%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%E3%83%A9%E3%82%A4%E3%83%B3%20%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E3%80%81%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E5%BC%95%E6%95%B0%E3%81%8C%E5%A4%9A%E6%95%B0%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3Epython%20ML%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3EKWS%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22keyword%20token%22%3Efor%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3EMCU%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Etrain%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Epy%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Emodel_architecture%20ds_cnn%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Emodel_size_info%20%3CSPAN%20class%3D%22number%20token%22%3E5%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E10%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E4%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ewanted_words%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3Ezero%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20one%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20two%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20three%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20four%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20five%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20six%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20seven%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20eight%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20nine%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edct_coefficient_count%20%3CSPAN%20class%3D%22number%20token%22%3E10%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ewindow_size_ms%20%3CSPAN%20class%3D%22number%20token%22%3E40%3C%2FSPAN%3E%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ewindow_stride_ms%20%3CSPAN%20class%3D%22number%20token%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Elearning_rate%20%3CSPAN%20class%3D%22number%20token%22%3E0.0005%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0.0001%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E0.00002%3C%2FSPAN%3E%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ehow_many_training_steps%20%3CSPAN%20class%3D%22number%20token%22%3E10000%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E10000%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E10000%3C%2FSPAN%3E%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edata_dir%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Espeech_dataset%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Esummaries_dir%20%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eretrain_logs%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Etrain_dir%20%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Espeech_commands_train%20%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AF%E3%80%81%E4%BE%8B%E3%81%88%E3%81%B0%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3E--wanted_words%3D%E3%82%BC%E3%83%AD%E3%80%811%E3%80%812%E3%80%813%E3%80%814%E3%80%815%E3%80%816%E3%80%817%E3%80%818%E3%80%819%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%E5%8D%98%E8%AA%9E%E3%81%AF%E3%80%8C%E3%81%AF%E3%81%84%E3%80%8D%E3%80%81%E3%80%8C%E3%81%84%E3%81%84%E3%81%88%E3%80%8D%E3%80%81%E3%80%8C%E4%B8%8A%E3%80%8D%E3%80%81%E3%80%8C%E4%B8%8B%E3%80%8D%E3%80%81%E3%80%8C%E5%B7%A6%E3%80%8D%E3%80%81%E3%80%8C%E5%8F%B3%E3%80%8D%E3%80%81%E3%80%8C%E3%82%AA%E3%83%B3%E3%80%8D%E3%80%81%E3%80%8C%E3%82%AA%E3%83%95%E3%80%8D%E3%80%81%E3%80%8C%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%80%8D%E3%80%81%E3%80%8C%E3%82%B4%E3%83%BC%E3%80%8D%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%82%BB%E3%83%83%E3%83%88%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E6%AC%A1%E3%81%AE%E5%8D%98%E8%AA%9E%E3%81%AE%E4%BB%BB%E6%84%8F%E3%81%AE%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%20class%3D%22%22%20style%3D%22padding%3A%200px%3B%20margin%3A%201.1em%200px%201.1em%203em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3E%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3C%2FSTRONG%3E%3C%2FSPAN%3E%3A%E3%81%AF%E3%81%84%E3%80%81%E3%81%84%E3%81%84%E3%81%88%E3%80%81%E4%B8%8A%E3%80%81%E4%B8%8B%E3%80%81%E5%B7%A6%E3%80%81%E5%8F%B3%E3%80%81%E3%82%AA%E3%83%B3%E3%80%81%E3%82%AA%E3%83%95%E3%80%81%E5%81%9C%E6%AD%A2%E3%80%81%E7%A7%BB%E5%8B%95%E3%80%81%E5%BE%8C%E9%80%80%E3%80%81%E5%89%8D%E9%80%B2%E3%80%81%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%80%81%E5%AD%A6%E7%BF%92%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3E0%20%E3%81%8B%E3%82%89%209%20%E3%81%BE%E3%81%A7%E3%81%AE%E6%95%B0%E5%AD%97%3C%2FSTRONG%3E%3C%2FSPAN%3E%3A%200%E3%80%811%E3%80%812%E3%80%813%E3%80%814%E3%80%815%E3%80%816%E3%80%817%E3%80%818%E3%80%819%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3E%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%81%AA%E5%8D%98%E8%AA%9E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3A%E3%83%99%E3%83%83%E3%83%89%E3%80%81%E9%B3%A5%E3%80%81%E7%8C%AB%E3%80%81%E7%8A%AC%E3%80%81%E5%B9%B8%E3%81%9B%E3%80%81%E5%AE%B6%E3%80%81%E3%83%9E%E3%83%BC%E3%83%93%E3%83%B3%E3%80%81%E3%82%B7%E3%83%BC%E3%83%A9%E3%80%81%E6%9C%A8%E3%80%81%E3%81%99%E3%81%94%E3%81%84%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BE%8B%E3%81%88%E3%81%B0%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3E--train_dir%3D%2Fcontent%2Fspeech_commands_train%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%81%AF%E3%80%81%E8%A8%93%E7%B7%B4%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A2%E3%83%87%E3%83%AB%E3%81%8C%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%82%8B%E5%A0%B4%E6%89%80%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%BC%95%E6%95%B0%E3%81%AF%E3%81%9D%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AF%E3%80%81%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%8A%E3%81%BE%E3%81%99%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fstorage.cloud.google.com%2Fdownload.tensorflow.org%2Fdata%2Fspeech_commands_v0.02.tar.gz%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22color%3A%20%230088cc%3B%20text-decoration%3A%20none%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%22%20target%3D%22_blank%22%3E%20Speech%20Commands%E3%83%87%E3%83%BC%E3%82%BF%E3%82%BB%E3%83%83%E3%83%88(%E5%9B%B32)%E3%81%AF%E3%80%8130%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E5%8D%98%E8%AA%9E%E3%82%92%E8%A9%B1%E3%81%99%E4%BA%BA%E3%80%85%E3%81%AE105%2C000%E3%82%92%E8%B6%85%E3%81%88%E3%82%8BWAVE%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%3CSPAN%3E%3C%2FSPAN%3E%20Google%20%E3%81%8C%E5%8F%8E%E9%9B%86%E3%81%97%E3%80%81CC%20BY%20%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AE%E4%B8%8B%E3%81%A7%E5%85%AC%E9%96%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E8%87%AA%E5%88%86%E3%81%AE%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Faiyprojects.withgoogle.com%2Fopen_speech_recording%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22color%3A%20%230088cc%3B%20text-decoration%3A%20none%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%22%20target%3D%22_blank%22%3E%20%E5%A3%B0%E3%82%92%205%20%E5%88%86%E9%96%93%E6%8A%95%E7%A8%BF%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%20%E3%81%93%E3%81%A8%E3%81%A7%20%E6%94%B9%E5%96%84%E3%81%AB%E8%B2%A2%E7%8C%AE%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%20%E3%80%82%E3%82%A2%E3%83%BC%E3%82%AB%E3%82%A4%E3%83%96%E3%81%AF2GB%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%AE%E9%83%A8%E5%88%86%E3%81%AB%E3%81%AF%E6%99%82%E9%96%93%E3%81%8C%E3%81%8B%E3%81%8B%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E9%80%B2%E8%A1%8C%E7%8A%B6%E6%B3%81%E3%83%AD%E3%82%B0%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E4%B8%80%E5%BA%A6%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E5%86%8D%E5%BA%A6%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%BB%E3%83%83%E3%83%88%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%20Speech%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Farxiv.org%2Fabs%2F1804.03209%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20Commands%E3%81%AE%E8%AB%96%E6%96%87%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F97882i3BCEC497EC888AF9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_5.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20text-align%3A%20center%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E5%9B%B32%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%95%E3%82%89%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E8%AD%A6%E5%91%8A%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81%E7%84%A1%E8%A6%96%E3%81%97%E3%81%A6%E3%81%8B%E3%81%BE%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%BE%8C%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%AD%E3%82%B0%E6%83%85%E5%A0%B1%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%20(%E5%9B%B3%203)%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F97982iFEF96213CAE542E6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_13.png%22%20alt%3D%22pastedImage_13.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_13.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E5%9B%B33%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E5%88%9D%E6%9C%9F%E5%8C%96%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%80%81%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%8C%E4%BD%95%E3%82%92%E6%84%8F%E5%91%B3%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8B%E3%81%AE%E5%86%85%E8%A8%B3%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20class%3D%22%22%20style%3D%22padding%3A%200px%3B%20margin%3A%201.1em%200px%201.1em%203em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CLI%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%AF%E3%80%81%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E4%B8%8A%E3%81%AB%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E5%90%88%E8%A8%88%E3%81%A730%2C000%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E7%95%AA%E5%8F%B7%E3%82%92%E8%A6%8B%E3%81%A6%E3%80%81%E3%83%95%E3%82%A3%E3%83%8B%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E3%81%A9%E3%82%8C%E3%81%A0%E3%81%91%E8%BF%91%E3%81%84%E3%81%8B%E3%82%92%E6%8A%8A%E6%8F%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3E%E6%96%99%E9%87%91%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%AF%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E9%87%8D%E3%81%BF%E6%9B%B4%E6%96%B0%E3%81%AE%E9%80%9F%E5%BA%A6%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%AD%A6%E7%BF%92%E7%8E%87%E3%81%A7%E3%81%99%E3%80%82%E5%88%9D%E6%9C%9F%E3%81%AE%E6%AE%B5%E9%9A%8E%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E6%AF%94%E8%BC%83%E7%9A%84%E9%AB%98%E3%81%84%E6%95%B0%E5%80%A4(0.0005)%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%BE%8C%E3%81%AE%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%A7%E3%81%AF5%E5%80%8D%E3%81%AE0.0001%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AB%E3%81%AF0.00002%E3%81%AB%E6%B8%9B%E5%B0%91%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3E%E7%B2%BE%E5%BA%A6%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%E6%AD%A3%E3%81%97%E3%81%8F%E4%BA%88%E6%B8%AC%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%A9%E3%82%B9%E3%81%AE%E6%95%B0%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%80%A4%E3%81%AF%E5%A4%9A%E3%81%8F%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E5%A4%A7%E3%81%8D%E3%81%8F%E5%A4%89%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%8C%E9%80%B2%E3%82%80%E3%81%AB%E3%81%A4%E3%82%8C%E3%81%A6%E5%B9%B3%E5%9D%87%E3%81%97%E3%81%A6%E5%A2%97%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AF%E3%80%81%E3%83%A9%E3%83%99%E3%83%AB%E3%81%94%E3%81%A8%E3%81%AB%201%20%E3%81%A4%E3%81%9A%E3%81%A4%E3%80%81%E6%95%B0%E5%80%A4%E3%81%AE%E9%85%8D%E5%88%97%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%97%E3%80%81%E5%90%84%E6%95%B0%E5%80%A4%E3%81%AF%E3%80%81%E5%85%A5%E5%8A%9B%E3%81%8C%E3%81%9D%E3%81%AE%E3%82%AF%E3%83%A9%E3%82%B9%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AE%E4%BA%88%E6%B8%AC%E5%80%A4%E3%81%A7%E3%81%99%E3%80%82%E4%BA%88%E6%B8%AC%E3%83%A9%E3%83%99%E3%83%AB%E3%81%AF%E3%80%81%E3%82%B9%E3%82%B3%E3%82%A2%E3%81%8C%E6%9C%80%E3%82%82%E9%AB%98%E3%81%84%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%82%B3%E3%82%A2%E3%81%AF%E5%B8%B8%E3%81%AB%200%20%E3%81%8B%E3%82%89%201%20%E3%81%AE%E9%96%93%E3%81%A7%E3%80%81%E5%80%A4%E3%81%8C%E5%A4%A7%E3%81%8D%E3%81%84%E3%81%BB%E3%81%A9%E7%B5%90%E6%9E%9C%E3%81%AE%E4%BF%A1%E9%A0%BC%E6%80%A7%E3%81%8C%E9%AB%98%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3E%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AD%E3%83%94%E3%83%BC%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%AF%E3%80%81%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E3%82%AC%E3%82%A4%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E6%90%8D%E5%A4%B1%E9%96%A2%E6%95%B0%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E5%AE%9F%E8%A1%8C%E3%81%AE%E3%82%B9%E3%82%B3%E3%82%A2%E3%81%AE%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E3%82%92%E6%AD%A3%E3%81%97%E3%81%84%E3%83%A9%E3%83%99%E3%83%AB%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%BE%97%E3%82%89%E3%82%8C%E3%82%8B%E3%82%B9%E3%82%B3%E3%82%A2%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E4%B8%AD%E3%81%AB%E4%B8%8B%E9%99%8D%E5%82%BE%E5%90%91%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3E%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E100%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E9%80%B2%E3%82%80%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E8%A1%8C%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AE%E5%AD%A6%E7%BF%92%E6%B8%88%E3%81%BF%E9%87%8D%E3%81%BF%E3%81%8C%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99(%E5%9B%B34)%E3%80%82%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%8C%E4%B8%AD%E6%96%AD%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%9C%80%E5%BE%8C%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%9F%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E5%BC%95%E6%95%B0%E3%81%A8%E3%81%97%E3%81%A6%20--start_checkpoint%3D%2Ftmp%2Fspeech_commands_train%2Fbest%2Fds_cnn_xxxx.ckpt-400%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%8B%E3%82%89%E9%96%8B%E5%A7%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F98663i9D2F03283C331648%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%E5%9B%B34%3C%2FP%3E%3CUL%3E%3CLI%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSTRONG%20class%3D%22%22%3E%E6%B7%B7%E5%90%8C%E8%A1%8C%E5%88%97%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E400%20%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%92%E8%B8%8F%E3%82%80%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%8C%E8%A8%98%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%81%A7%E3%81%99%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fen.wikipedia.org%2Fwiki%2FConfusion_matrix%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22color%3A%20%230088cc%3B%20text-decoration%3A%20none%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%22%20target%3D%22_blank%22%3E%E6%B7%B7%E5%90%8C%E8%A1%8C%E5%88%97%E3%80%82%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E3%81%9D%E3%82%8C%E3%81%8C%E4%BD%95%E3%82%92%E6%84%8F%E5%91%B3%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%BE%E3%81%9A%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A9%E3%83%99%E3%83%AB%E3%80%81%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%8C%E6%B2%88%E9%BB%99%E3%80%8D%E3%80%81%E3%80%8C%E4%B8%8D%E6%98%8E%E3%80%8D%E3%80%81%E3%80%8C%E3%82%BC%E3%83%AD%E3%80%8D%E3%80%81%E3%80%8C1%E3%80%8D%E3%80%81%E3%80%8C2%E3%80%8D%E3%80%81%E3%80%8C3%E3%80%8D%E3%80%81%E3%80%8C4%E3%80%8D%E3%80%81%E3%80%8C5%E3%80%8D%E3%80%81%E3%80%8C6%E3%80%8D%E3%80%81%E3%80%8C7%E3%80%8D%E3%80%81%E3%80%8C8%E3%80%8D%E3%80%81%E3%80%8C9%E3%80%8D%E3%82%92%E7%9F%A5%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E5%90%84%E5%88%97%E3%81%AF%E3%80%81%E5%90%84%E3%83%A9%E3%83%99%E3%83%AB%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E4%BA%88%E6%B8%AC%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E8%A1%A8%E3%81%99%E3%81%9F%E3%82%81%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E5%88%97%E3%81%AF%E7%84%A1%E9%9F%B3%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E4%BA%88%E6%B8%AC%E3%81%95%E3%82%8C%E3%81%9F%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AF%E3%83%AA%E3%83%83%E3%83%97%E3%82%92%E8%A1%A8%E3%81%97%E3%80%812%20%E7%95%AA%E7%9B%AE%E3%81%AE%E5%88%97%E3%81%AF%E4%B8%8D%E6%98%8E%E3%81%AA%E5%8D%98%E8%AA%9E%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E4%BA%88%E6%B8%AC%E3%81%95%E3%82%8C%E3%81%9F%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AF%E3%83%AA%E3%83%83%E3%83%97%E3%82%92%E8%A1%A8%E3%81%97%E3%80%813%20%E7%95%AA%E7%9B%AE%E3%81%AE%E5%88%97%E3%81%AF%20%22%E3%82%BC%E3%83%AD%22%20%E3%81%A8%E3%81%84%E3%81%86%E3%82%88%E3%81%86%E3%81%AB%E7%B6%9A%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E5%90%84%E8%A1%8C%E3%81%AF%E3%80%81%E3%82%AF%E3%83%AA%E3%83%83%E3%83%97%E3%82%92%E6%AD%A3%E3%81%97%E3%81%84%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%20%E3%83%88%E3%82%A5%E3%83%AB%E3%83%BC%E3%82%B9%20%E3%83%A9%E3%83%99%E3%83%AB%E3%81%A7%E8%A1%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%88%9D%E3%81%AE%E8%A1%8C%E3%81%AF%E7%84%A1%E9%9F%B3%E3%81%A0%E3%81%A3%E3%81%9F%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AF%E3%83%AA%E3%83%83%E3%83%97%E3%80%812%20%E7%95%AA%E7%9B%AE%E3%81%AE%E3%82%AF%E3%83%AA%E3%83%83%E3%83%97%E3%81%AF%E4%B8%8D%E6%98%8E%E3%81%AA%E5%8D%98%E8%AA%9E%E3%80%813%20%E7%95%AA%E7%9B%AE%E3%81%AE%E3%80%8C%E3%82%BC%E3%83%AD%E3%80%8D%E3%81%AA%E3%81%A9%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E3%81%93%E3%81%AE%E8%A1%8C%E5%88%97%E3%81%AF%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E9%96%93%E9%81%95%E3%81%84%E3%82%92%E7%8A%AF%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%92%E3%81%86%E3%81%BE%E3%81%8F%E3%81%BE%E3%81%A8%E3%82%81%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%8D%98%E4%B8%80%E3%81%AE%E7%B2%BE%E5%BA%A6%E3%82%B9%E3%82%B3%E3%82%A2%E3%82%88%E3%82%8A%E3%82%82%E6%9C%89%E7%94%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E8%A1%8C%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%81%8C%E3%82%BC%E3%83%AD%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99(%E5%9B%B35)%E3%80%82%E6%9C%80%E5%88%9D%E3%81%AE%E8%A1%8C%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AB%E7%84%A1%E9%9F%B3%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AF%E3%83%AA%E3%83%83%E3%83%97%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E8%AA%A4%E3%81%A3%E3%81%A6%E5%8D%98%E8%AA%9E%E3%81%A8%E3%81%97%E3%81%A6%E3%83%A9%E3%83%99%E3%83%AB%E4%BB%98%E3%81%91%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%AA%E3%83%83%E3%83%97%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E7%84%A1%E9%9F%B3%E3%81%AE%E5%81%BD%E9%99%B0%E6%80%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%8C%E3%81%99%E3%81%A7%E3%81%AB%E6%B2%88%E9%BB%99%E3%81%A8%E8%A8%80%E8%91%89%E3%82%92%E5%8C%BA%E5%88%A5%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E3%81%8B%E3%81%AA%E3%82%8A%E5%84%AA%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E5%88%97%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%81%E3%82%BC%E3%83%AD%E4%BB%A5%E5%A4%96%E3%81%AE%E5%80%A4%E3%81%8C%E3%81%9F%E3%81%8F%E3%81%95%E3%82%93%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%88%97%E3%81%AF%E3%80%81%E7%84%A1%E9%9F%B3%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E4%BA%88%E6%B8%AC%E3%81%95%E3%82%8C%E3%81%9F%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AF%E3%83%AA%E3%83%83%E3%83%97%E3%82%92%E8%A1%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%BB%E3%83%AB%E3%81%AE%E5%A4%96%E5%81%B4%E3%81%AB%E3%81%82%E3%82%8B%E6%AD%A3%E3%81%AE%E6%95%B0%E5%80%A4%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB%E8%A9%B1%E3%81%95%E3%82%8C%E3%81%9F%E8%A8%80%E8%91%89%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%AE%E3%82%AF%E3%83%AA%E3%83%83%E3%83%97%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E6%B2%88%E9%BB%99%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E4%BA%88%E6%B8%AC%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%8B%E3%81%AA%E3%82%8A%E3%81%AE%E6%95%B0%E3%81%AE%E8%AA%A4%E6%A4%9C%E7%9F%A5%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81%E4%B8%AD%E5%BF%83%E3%82%92%E9%80%9A%E3%82%8B%E5%AF%BE%E8%A7%92%E7%B7%9A%E3%82%92%E9%99%A4%E3%81%84%E3%81%A6%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%81%8C%E3%82%BC%E3%83%AD%E3%81%A7%E3%81%82%E3%82%8B%E6%B7%B7%E5%90%8C%E8%A1%8C%E5%88%97%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%83%91%E3%82%BF%E3%83%BC%E3%83%B3%E3%81%8B%E3%82%89%E3%81%AE%E9%80%B8%E8%84%B1%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E3%81%8C%E6%9C%80%E3%82%82%E6%B7%B7%E4%B9%B1%E3%81%97%E3%82%84%E3%81%99%E3%81%84%E6%96%B9%E6%B3%95%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%80%81%E5%95%8F%E9%A1%8C%E3%82%92%E7%89%B9%E5%AE%9A%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%82%8A%E3%80%81%E3%82%AB%E3%83%86%E3%82%B4%E3%83%AA%E3%82%92%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%9F%E3%82%8A%E3%81%97%E3%81%A6%E5%AF%BE%E5%87%A6%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%20style%3D%22width%3A%20725px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F99321i966B3F04207F8247%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_12.png%22%20alt%3D%22pastedImage_12.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_12.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E5%9B%B35%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20class%3D%22%22%20style%3D%22padding%3A%200px%3B%20margin%3A%201.1em%200px%201.1em%203em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSTRONG%20class%3D%22%22%3E%E6%A4%9C%E8%A8%BC%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E6%B7%B7%E5%90%8C%E8%A1%8C%E5%88%97%E3%81%AE%E5%BE%8C%E3%81%AB%E3%80%81%E5%9B%B3%205%20%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%B7%9A%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%203%20%E3%81%A4%E3%81%AE%E3%82%AB%E3%83%86%E3%82%B4%E3%83%AA%E3%81%AB%E5%88%86%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%A4%A7%E3%81%AE%E3%82%82%E3%81%AE(%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E7%B4%8480%25)%E3%81%8C%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E5%AD%A6%E7%BF%92%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%80%81%E5%B0%8F%E3%81%95%E3%81%AA%E3%82%BB%E3%83%83%E3%83%88(%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF10%25%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%8C%E6%A4%9C%E8%A8%BC%E3%80%8D%E3%81%A8%E5%91%BC%E3%81%B0%E3%82%8C%E3%81%BE%E3%81%99)%E3%81%8C%E5%AD%A6%E7%BF%92%E4%B8%AD%E3%81%AE%E7%B2%BE%E5%BA%A6%E3%81%AE%E8%A9%95%E4%BE%A1%E7%94%A8%E3%81%AB%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%80%81%E5%88%A5%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88(%E6%9C%80%E5%BE%8C%E3%81%AE10%25%E3%80%81%E3%80%8C%E3%83%86%E3%82%B9%E3%83%88%E3%80%8D)%E3%81%AF%E5%AD%A6%E7%BF%92%E3%81%AE%E5%AE%8C%E4%BA%86%E5%BE%8C%E3%81%AB%E4%B8%80%E5%BA%A6%E7%B2%BE%E5%BA%A6%E3%82%92%E8%A9%95%E4%BE%A1%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E3%81%93%E3%81%AE%E5%88%86%E5%89%B2%E3%81%AE%E7%90%86%E7%94%B1%E3%81%AF%E3%80%81%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E4%B8%AD%E3%81%AB%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%8C%E5%85%A5%E5%8A%9B%E3%82%92%E8%A8%98%E6%86%B6%E3%81%97%E5%A7%8B%E3%82%81%E3%82%8B%E5%8D%B1%E9%99%BA%E6%80%A7%E3%81%8C%E5%B8%B8%E3%81%AB%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%E6%A4%9C%E8%A8%BC%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E5%88%86%E9%9B%A2%E3%81%97%E3%81%A6%E3%81%8A%E3%81%8F%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E3%81%8C%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E3%81%AB%E8%A6%8B%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AE%E3%81%AA%E3%81%84%E3%83%87%E3%83%BC%E3%82%BF%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%83%86%E3%82%B9%E3%83%88%20%E3%82%BB%E3%83%83%E3%83%88%E3%81%AF%E3%80%81%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%20%E3%82%BB%E3%83%83%E3%83%88%E3%81%A8%E6%A4%9C%E8%A8%BC%E3%82%BB%E3%83%83%E3%83%88%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%A7%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E5%BE%AE%E8%AA%BF%E6%95%B4%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AA%E3%81%8F%E3%80%81%E3%82%88%E3%82%8A%E5%BA%83%E7%AF%84%E3%81%AA%E5%85%A5%E5%8A%9B%E3%81%A7%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E5%BE%AE%E8%AA%BF%E6%95%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E8%BF%BD%E5%8A%A0%E3%81%AE%E4%BF%9D%E8%AD%B7%E6%89%8B%E6%AE%B5%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AF%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E3%81%93%E3%82%8C%E3%82%89%203%20%E3%81%A4%E3%81%AE%E3%82%AB%E3%83%86%E3%82%B4%E3%83%AA%E3%81%AB%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E5%88%86%E9%A1%9E%E3%81%97%E3%80%81%E4%B8%8A%E3%81%AE%E3%83%AD%E3%82%B0%E8%A1%8C%E3%81%AF%E3%80%81%E6%A4%9C%E8%A8%BC%E3%82%BB%E3%83%83%E3%83%88%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E7%B2%BE%E5%BA%A6%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%90%86%E6%83%B3%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%AE%E7%B2%BE%E5%BA%A6%E3%81%AB%E3%81%8B%E3%81%AA%E3%82%8A%E8%BF%91%E3%81%84%E3%82%82%E3%81%AE%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%AE%E7%B2%BE%E5%BA%A6%E3%81%8C%E5%90%91%E4%B8%8A%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E3%80%81%E6%A4%9C%E8%A8%BC%E3%81%AE%E7%B2%BE%E5%BA%A6%E3%81%8C%E5%90%91%E4%B8%8A%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%95%E3%82%A3%E3%83%83%E3%83%88%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%85%86%E5%80%99%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AF%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%20%E3%82%AF%E3%83%AA%E3%83%83%E3%83%97%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E3%81%BF%E5%AD%A6%E7%BF%92%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E4%B8%80%E8%88%AC%E5%8C%96%E3%81%99%E3%82%8B%E5%BA%83%E7%AF%84%E3%81%AA%E3%83%91%E3%82%BF%E3%83%BC%E3%83%B3%E3%82%92%E5%AD%A6%E7%BF%92%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CH2%20class%3D%22%22%20id%3D%22toc-hId--56257198%22%20style%3D%22font-weight%3A%20bold%3B%20text-rendering%3A%20optimizelegibility%3B%20font-size%3A%201.8rem%3B%20margin%3A%200.7em%200px%200.5em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20id%3D%22toc-hId--56257198%22%20id%3D%22toc-hId-867351343%22%3E%3CSPAN%20class%3D%22%22%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%E4%B8%80%E8%88%AC%E3%81%AB%E3%80%81%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%A8%E3%81%AF%E3%80%81%E6%9C%89%E7%94%A8%E3%81%AA%E4%BA%88%E6%B8%AC%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%82%8B%E3%81%BE%E3%81%A7%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E9%87%8D%E3%81%BF%E3%81%A8%E3%83%90%E3%82%A4%E3%82%A2%E3%82%B9%E3%82%92%E7%B9%B0%E3%82%8A%E8%BF%94%E3%81%97%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E9%87%8D%E3%81%BF%E3%81%A8%E3%83%90%E3%82%A4%E3%82%A2%E3%82%B9%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%20(%E5%9B%B3%206)%E3%80%82%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20664px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F99323i8CA980C3337257F9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20text-align%3A%20center%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%E5%9B%B36%3C%2FP%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3ETensorFlow%20%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AF%E3%80%81%E4%B8%BB%E3%81%AB%202%20%E3%81%A4%E3%81%AE%E8%A6%81%E7%B4%A0%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%20class%3D%22%22%20style%3D%22padding%3A%200px%3B%20margin%3A%201.1em%200px%201.1em%203em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%8B%E3%82%89%E7%94%9F%E3%81%98%E3%82%8B%E9%87%8D%E3%81%BF%E3%81%A8%E3%83%90%E3%82%A4%E3%82%A2%E3%82%B9%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E5%85%A5%E5%8A%9B%E3%81%A8%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E9%87%8D%E3%81%BF%E3%81%8A%E3%82%88%E3%81%B3%E3%83%90%E3%82%A4%E3%82%A2%E3%82%B9%E3%82%92%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E6%BC%94%E7%AE%97%E3%81%AE%E3%82%B0%E3%83%A9%E3%83%95%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%E3%81%93%E3%81%AE%E6%99%82%E7%82%B9%E3%81%A7%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E6%93%8D%E4%BD%9C%E3%81%AF%20Python%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%9F%E9%87%8D%E3%81%BF%E3%81%A8%E3%83%90%E3%82%A4%E3%82%A2%E3%82%B9%E3%81%AF%E6%9C%80%E6%96%B0%E3%81%AE%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%202%20%E3%81%A4%E3%82%92%E7%89%B9%E5%AE%9A%E3%81%AE%E5%BD%A2%E5%BC%8F%E3%81%AE%201%20%E3%81%A4%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%97%E3%80%81%E6%8E%A8%E8%AB%96%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AF%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3E%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3E%E3%81%A8%E5%91%BC%E3%81%B0%E3%82%8C%E3%80%81%E9%87%8D%E3%81%BF%20%E5%87%8D%E7%B5%90%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%20%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B0%E3%83%A9%E3%83%95%E3%81%AE%E9%9D%99%E7%9A%84%E8%A1%A8%E7%8F%BE%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3Epython%20ML%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3EKWS%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22keyword%20token%22%3Efor%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3EMCU%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Efreeze%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Epy%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Emodel_architecture%20ds_cnn%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Emodel_size_info%20%3CSPAN%20class%3D%22number%20token%22%3E5%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E10%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E4%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E2%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E3%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ewanted_words%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3Ezero%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20one%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20two%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20three%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20four%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20five%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20six%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20seven%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20eight%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20nine%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edct_coefficient_count%20%3CSPAN%20class%3D%22number%20token%22%3E10%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ewindow_size_ms%20%3CSPAN%20class%3D%22number%20token%22%3E40%3C%2FSPAN%3E%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ewindow_stride_ms%20%3CSPAN%20class%3D%22number%20token%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Echeckpoint%20%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Espeech_commands_train%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebest%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eds_cnn_9490%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eckpt%3CSPAN%20class%3D%22number%20token%22%3E-21600%3C%2FSPAN%3E%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eoutput_file%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eds_cnn%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Epb%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%99%E3%82%8B%E6%93%8D%E4%BD%9C%E3%81%AE%E6%AD%A3%E3%81%97%E3%81%84%E3%82%B0%E3%83%A9%E3%83%95%E3%82%92%E6%8C%87%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A8%E5%90%8C%E3%81%98%E5%BC%95%E6%95%B0%E3%81%AE%E4%B8%80%E9%83%A8%E3%82%92%E6%B8%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%E3%81%8C%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AE%E5%90%88%E8%A8%88%E6%95%B0%E3%81%A7%E7%B5%82%E3%82%8F%E3%82%8B%E6%9C%80%E7%B5%82%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%B8%E3%81%AE%E3%83%91%E3%82%B9%E3%82%82%E6%B8%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%97%E3%81%9F%E3%82%B0%E3%83%A9%E3%83%95%E3%81%AF%E3%80%81ds_cnn.pb%20%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%E5%AE%8C%E5%85%A8%E3%81%AB%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%9F%20TensorFlow%20%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82TensorFlow%20%E3%81%A7%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%80%81%E6%8E%A8%E8%AB%96%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%20TensorFlow%20Lite%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AE%20TensorFlow%20%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20class%3D%22%22%20id%3D%22toc-hId--66760302%22%20style%3D%22font-weight%3A%20bold%3B%20text-rendering%3A%20optimizelegibility%3B%20font-size%3A%202rem%3B%20margin%3A%200.8em%200px%200.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20id%3D%22toc-hId--66760302%22%20id%3D%22toc-hId-856848239%22%3E%3CSPAN%20class%3D%22%22%3ETensorFlow%20Lite%20%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FH1%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%E5%A4%89%E6%8F%9B%E3%81%AF%E7%B0%A1%E5%8D%98%E3%81%AA%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%E3%81%99%3A%E5%8D%98%E4%B8%80%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%97%E3%81%9F%E3%82%B0%E3%83%A9%E3%83%95%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81TensorFlow%20Lite%20%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%82%E3%82%8B%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSTRONG%20class%3D%22%22%3Etoco%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3Etoco%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Egraph_def_file%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eds_cnn%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Epb%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eoutput_file%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eds_cnn%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Etflite%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Einput_shapes%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E49%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E10%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Einput_arrays%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3EReshape_1%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eoutput_arrays%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E'labels_softmax'%3C%2FSPAN%3E%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Einference_type%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3EQUANTIZED_UINT8%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Emean_values%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E227%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Estd_dev_values%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E1%3C%2FSPAN%3E%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Echange_concat_input_ranges%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3Efalse%20%5C%0A%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edefault_ranges_min%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E6%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Edefault_ranges_max%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22number%20token%22%3E6%3C%2FSPAN%3E%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E5%BC%95%E6%95%B0%E3%81%A7%E3%81%AF%E3%80%81%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E3%83%A2%E3%83%87%E3%83%AB%E3%80%81TensorFlow%20Lite%20%E3%83%A2%E3%83%87%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%87%BA%E5%8A%9B%E5%A0%B4%E6%89%80%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%A2%E3%83%87%E3%83%AB%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%99%E3%82%8B%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E5%80%A4%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%BC%95%E6%95%B0%20(inference_type%E3%80%81mean_values%E3%80%81std_dev_values)%20%E3%82%82%E7%94%A8%E6%84%8F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%81%AB%E4%BD%8E%E7%B2%BE%E5%BA%A6%E3%81%AE%E5%80%A4%E3%82%92%E5%AE%9F%E6%95%B0%E3%81%AB%E3%83%9E%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%8C%87%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E5%A4%89%E6%8F%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSTRONG%20class%3D%22%22%3Eds_cnn.tflite%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E5%AE%8C%E5%85%A8%E3%81%AB%E5%BD%A2%E6%88%90%E3%81%95%E3%82%8C%E3%81%9FTensorFlowLite%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20class%3D%22%22%20id%3D%22toc-hId-623801172%22%20style%3D%22font-weight%3A%20bold%3B%20text-rendering%3A%20optimizelegibility%3B%20font-size%3A%201.8rem%3B%20margin%3A%200.7em%200px%200.5em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20id%3D%22toc-hId-623801172%22%20id%3D%22toc-hId-1547409713%22%3E%3CSPAN%20class%3D%22%22%3EC%20%E9%85%8D%E5%88%97%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20class%3D%22%22%20style%3D%22margin%3A%201.1em%200px%201.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%E4%BB%A5%E4%B8%8B%E3%81%A7%E3%81%AF%E3%80%81%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CSTRONG%20class%3D%22%22%3Exxd%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20TensorFlow%20Lite%20%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%20C%20%E9%85%8D%E5%88%97%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22language-python%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3Exxd%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Ei%20%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eds_cnn%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Etflite%20%3CSPAN%20class%3D%22operator%20token%22%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eds_cnn%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eh%0Acat%20%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Eds_cnn%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Eh%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E5%87%BA%E5%8A%9B%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E9%83%A8%E5%88%86%E3%81%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%20C%20%E9%85%8D%E5%88%97%E3%81%A8%E3%81%9D%E3%81%AE%E9%95%B7%E3%81%95%E3%82%92%E4%BF%9D%E6%8C%81%E3%81%99%E3%82%8B%E6%95%B4%E6%95%B0%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20667px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F98022i2319213B6B5879C7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E5%9B%B37%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E6%96%B0%E3%81%97%E3%81%8F%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%20tensorflow_lite_kws%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A8%E7%B5%B1%E5%90%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20class%3D%22%22%20id%3D%22toc-hId-613298068%22%20style%3D%22font-weight%3A%20bold%3B%20text-rendering%3A%20optimizelegibility%3B%20font-size%3A%202rem%3B%20margin%3A%200.8em%200px%200.6em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%20id%3D%22toc-hId-613298068%22%20id%3D%22toc-hId-1536906609%22%3E%3CSPAN%20class%3D%22%22%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E4%BD%BF%E7%94%A8%20tensorflow_lite_kws%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E6%96%B0%E3%81%97%E3%81%84%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%202%20%E3%81%A4%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3COL%20class%3D%22%22%20style%3D%22padding%3A%200px%3B%20margin%3A%201.1em%200px%201.1em%203em%3B%20color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%3CLI%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3Esource%2Fds_cnn_s_model.h%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%E3%81%A7%E3%80%81%E5%85%83%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%96%B0%E3%81%97%E3%81%84%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%E3%83%A9%E3%83%99%E3%83%AB%E5%90%8D%E3%82%92%20%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%20class%3D%22%22%3Esource%2Fkws.cpp%3C%2FSTRONG%3E%20%E3%81%A7%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%96%B0%E3%81%97%E3%81%84%20''zero''%2C%20''one''%2C%20''two''%2C%20''three''%2C%20''four''%2C%20''five''%2C%20''six''%2C%20''seven''%2C%20''eight''%2C%20''nine''%20%E3%83%A9%E3%83%99%E3%83%AB%E3%82%92%E4%BB%98%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CPRE%20class%3D%22language-cpp%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22keyword%20token%22%3Econst%3C%2FSPAN%3E%20std%3CSPAN%20class%3D%22operator%20token%22%3E%3A%3A%3C%2FSPAN%3Estring%20labels%3CSPAN%20class%3D%22punctuation%20token%22%3E%5B%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%5D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22Silence%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22Unknown%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22zero%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22one%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22two%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22three%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22four%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22five%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22six%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22seven%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22eight%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%2C%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22string%20token%22%3E%22nine%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3EEVKB-IMXRT1050%E3%83%9C%E3%83%BC%E3%83%89(%E5%9B%B38)%E3%81%A7%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81%E6%BA%96%E5%82%99%E3%82%92%E8%A1%8C%E3%81%86%E3%81%9F%E3%82%81%E3%81%AEreadme.txt%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%83%86%E3%82%B9%E3%83%88%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%82%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F98282i6A2913C5EAFC5CD7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.jpg%22%20alt%3D%22pastedImage_6.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_6.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E5%9B%B38%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E5%9B%B39%E3%81%AF%E7%A7%81%E3%81%8C%E8%A1%8C%E3%81%A3%E3%81%9F%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%81%94%E8%87%AA%E8%BA%AB%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20697px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F97939i1898215A432AFE52%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%232f2f2f%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Tahoma%2C%20Arial%2C%20'Hiragino%20Sans%20GB'%2C%20STHeiti%2C%20'Microsoft%20YaHei'%2C%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%2C%20'WenQuanYi%20Micro%20Hei'%2C%20STXihei%2C%20%E5%8D%8E%E6%96%87%E7%BB%86%E9%BB%91%2C%20Heiti%2C%20%E9%BB%91%E4%BD%93%2C%20SimSun%2C%20%E5%AE%8B%E4%BD%93%2C%20Song%2C%20sans-serif%3B%20font-size%3A%2016px%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20background-color%3A%20%23f7f7f7%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%20display%3A%20inline%20!important%3B%20float%3A%20none%3B%22%3E%E5%9B%B39%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1103364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MXRT%20105%E5%80%8D%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MXRT%20106%E5%80%8D%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%83%9E%E3%82%A4%E3%82%B3%E3%83%B3%E7%94%A8%E8%AA%8D%E8%AD%98%E3%83%A2%E3%83%87%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103372%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%2C%3C%2FP%3E%3CP%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E1)%E3%83%A9%E3%83%99%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%9212%E3%81%8B%E3%82%8920%E3%81%AB%E5%A2%97%E3%82%84%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E--%20%E3%81%AF%E3%81%84%E3%80%81%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E6%96%B0%E3%81%97%E3%81%84%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%A7%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E6%89%8B%E9%A0%86%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E2)%E4%B8%8A%E3%81%AE%E5%86%99%E7%9C%9F%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92KSW%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E--%20SDK%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AB%E3%81%AF%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AEGUI%E3%83%87%E3%83%A2%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E5%8F%82%E8%80%83%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3EBR%2C%3C%2FP%3E%3CP%3EJeremy%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103371%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%83%9E%E3%82%A4%E3%82%B3%E3%83%B3%E7%94%A8%E8%AA%8D%E8%AD%98%E3%83%A2%E3%83%87%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103371%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%82%A4%E3%83%BC%E3%83%89%E3%82%92tensorflow_lite_kws%E3%81%A7%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82deault%E3%82%AD%E3%83%BC%E3%83%AF%E3%83%BC%E3%83%89%E3%81%A80%E3%81%8B%E3%82%899%E3%81%BE%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E8%AA%8D%E8%AD%98%E3%81%8C%E3%81%82%E3%81%BE%E3%82%8A%E6%AD%A3%E7%A2%BA%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%83%A9%E3%83%99%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%9212%E3%81%8B%E3%82%8920%E3%81%AB%E5%A2%97%E3%82%84%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E6%97%A2%E5%AD%98%E3%81%AE%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AB%E6%95%B0%E5%80%A4%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%80%81%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E5%A0%B4%E6%89%80%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E3%81%99%E3%81%8B%3F%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E4%B8%8A%E3%81%AE%E5%86%99%E7%9C%9F%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92KSW%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E5%87%BA%E5%8A%9B%E3%82%92Tera%20Term%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E7%94%BB%E9%9D%A2%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%83%9E%E3%82%A4%E3%82%B3%E3%83%B3%E7%94%A8%E8%AA%8D%E8%AD%98%E3%83%A2%E3%83%87%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%A1%E3%82%87%E3%81%A3%E3%81%A8%E5%A4%89%E3%81%AA%E6%84%9F%E3%81%98%E3%81%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%E4%BB%8A%E3%81%BE%E3%81%A7%E5%87%BA%E4%BC%9A%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F113133i72442911719A92CC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3EIRD%E3%81%AE%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BSDK%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%80%81%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%86%85%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81%E5%AE%8C%E5%85%A8%E3%81%AA%E6%96%B0%E3%81%97%E3%81%84SDK%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA(%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB)%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81MCUXpresso%20IDE%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20969px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F113134i1AC8E326B3383BC9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81eIQ%E3%83%87%E3%83%A2%E3%82%92%E5%86%8D%E5%BA%A6%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBR%2C%3C%2FP%3E%3CP%3EJeremy%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%83%9E%E3%82%A4%E3%82%B3%E3%83%B3%E7%94%A8%E8%AA%8D%E8%AD%98%E3%83%A2%E3%83%87%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjeremyzhou%22%20target%3D%22_blank%22%3Ejeremyzhou%3C%2FA%3E%20%E3%80%81%E7%A7%81%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%9F%E3%81%8C%E3%80%81SDK%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E4%B8%AD%E3%81%ABeiq%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E5%88%A4%E6%98%8E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E7%A7%81%E3%81%8C%E3%81%9D%E3%82%8C%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E7%A7%81%E3%81%AFtensorflow_lite_kws%E3%82%92%E5%90%AB%E3%82%80eiq%E3%81%AE%E4%BE%8B%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%80%8Ctensorflow_lite_kws%5D%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20'tensorflow_lite_kws'%20%E3%81%AF%E5%A4%96%E9%83%A8%20XML%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93!%E3%80%8D%3CBR%20%2F%3Eeiq%E3%81%A7%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F113088iB9DE2F78CD26AEAF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%83%9E%E3%82%A4%E3%82%B3%E3%83%B3%E7%94%A8%E8%AA%8D%E8%AD%98%E3%83%A2%E3%83%87%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%AE%E5%86%92%E9%A0%AD%E3%81%A7%E6%8C%87%E6%91%98%E3%81%97%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81tensorflow_lite_kws%E3%83%87%E3%83%A2%E3%81%AF%20SDK_2.7.0_EVKB-IMXRT1050%20%E3%81%8B%E3%82%89%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%20SDK%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AF%E6%AC%A1%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81SDK%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92MCUXpreeso%20IDE%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81tensorflow_lite_kws%E3%83%87%E3%83%A2%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%20%3CBR%20%2F%3E%E3%81%9C%E3%81%B2%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fen%2Fwelcome%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fmcuxpresso.nxp.com%2Fen%2Fwelcome%3C%2FA%3E%3C%2FP%3E%3CP%3EBR%2C%3C%2FP%3E%3CP%3EJeremy%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%83%9E%E3%82%A4%E3%82%B3%E3%83%B3%E7%94%A8%E8%AA%8D%E8%AD%98%E3%83%A2%E3%83%87%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjeremyzhou%22%20target%3D%22_blank%22%3Ejeremyzhou%3C%2FA%3E%E3%81%95%E3%82%93%E3%80%81%E8%BF%85%E9%80%9F%E3%81%AA%E5%AF%BE%E5%BF%9C%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88kws_tensorflow_lite%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%AB%E3%81%AF%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AE%E3%81%BF%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82IDE%E3%81%A7%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%A9%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3CBR%20%2F%3E%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9FMCUExpresso%20IDE%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80(C%3A%5CUsers%5CB2F%5CDocuments%5CMCUXpressoIDE_11.1.1_3241%5Cworkspace)%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E4%BE%8B%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E9%81%8B%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%83%9E%E3%82%A4%E3%82%B3%E3%83%B3%E7%94%A8%E8%AA%8D%E8%AD%98%E3%83%A2%E3%83%87%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%2C%3C%2FP%3E%3CP%3EMCUXpreeso%E3%81%A7%E3%80%81%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%89%E3%82%92%E5%B1%95%E9%96%8B%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%ABds_cnn_s_mode.h%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20383px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F112724iEEA538B90C01FD80%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EBR%2C%3C%2FP%3E%3CP%3EJeremy%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%83%9E%E3%82%A4%E3%82%B3%E3%83%B3%E7%94%A8%E8%AA%8D%E8%AD%98%E3%83%A2%E3%83%87%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%40%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20data-userid%3D%22213424%22%20data-username%3D%22jeremyzhou%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjeremyzhou%22%20style%3D%22color%3A%20%2353aaea%3B%20background-color%3A%20%23181a1b%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20text-decoration%3A%20none%3B%20font-size%3A%2011.9994px%3B%22%20target%3D%22_blank%22%3E%E3%82%B8%E3%82%A7%E3%83%AC%E3%83%9F%E3%83%BC%E3%82%B8%E3%83%A7%E3%82%A6%3C%2FA%3E%3CSPAN%20style%3D%22background-color%3A%20%23181a1b%3B%20color%3A%20%23c4c0b7%3B%22%3E%E3%80%81%E3%81%BE%E3%81%9A%E6%9C%80%E5%88%9D%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B3%BC%E5%85%A5%E3%81%97%E3%80%81%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6KSW%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E8%BF%BD%E5%8A%A0IMXRT1050%E3%80%82%E7%A7%81%E3%81%AF%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E6%9C%80%E7%B5%82%E6%AE%B5%E9%9A%8E%E3%81%A7%E7%AB%8B%E3%81%A1%E5%BE%80%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20class%3D%22%22%20data-darkreader-inline-bgcolor%3D%22%22%20data-darkreader-inline-color%3D%22%22%20style%3D%22color%3A%20%232f2f2f%3B%20background-color%3A%20%23f7f7f7%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%202rem%3B%20margin%3A%200.8em%200px%200.6em%3B%22%20id%3D%22toc-hId-380577422%22%20id%3D%22toc-hId--270547854%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2028px%3B%22%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E4%BD%BF%E7%94%A8%20tensorflow_lite_kws%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23181a1b%3B%20color%3A%20%23c4c0b7%3B%22%3E%3CSTRONG%20class%3D%22%22%20style%3D%22color%3A%20%23d7d4ce%3B%20background-color%3A%20%231b1c1d%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2016px%3B%22%3E%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%9Fds_cnn.h%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%8Bsource%20%2F%20ds_cnn_s_model.h%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AF%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E6%A4%9C%E7%B4%A2%E3%81%97%E3%80%81%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CSPAN%20style%3D%22font-weight%3A%20400%3B%22%3ESDK_2.7.0_EVKB-IMXRT1050%20%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E4%B8%AD%E3%81%ABkws_tensorflow_lite%E4%BE%8B%E3%82%82%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%BF%85%E9%80%9F%E3%81%AA%E5%8A%A9%E3%81%91%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 01:48 AM
更新者:
