rt1021 usb2serial driver problem
low_stack
Hi, i program a custom board with mimxrt1021 M7 processor. My os is windows 10. I want to connect custom board from mini usb port as a serial com port. I searched driver for windows and found USB2SERA10 driver. But it doesnt work, usb device is not recognized. Is there any solution for me? Does anyone  know that USB2SERA10 driver support windows 10?
low_stack
Hi @jingpan , first thank you for your quick reponse. On my custom board there is a signal processing algorithm running on freertos os with multitasking configuration. And my purpose is to send some debug data to windows machine via virtual com port while my tasks are working. I am using Mcuxpresso ide.
jingpan
Hi @low_stack ,
There is dev_cdc_vcom_freertos demo in SDK. You can merge this demo to your code.
Jing
low_stack
Ok i will add it, so there is no need to load any driver to windows part?
jingpan
Hi @low_stack ,
Win10 should needn't.
Jing
jingpan
Hi @low_stack ,
The problem is what is running on your board? Is it a USB VCOM project? If it isn't, then you can download RT1021 SDK. It has a USB VCOM demo. After you download the project, there isn't other USB to serial driver needed.
Jing
