microSD card data line pull-up resistor in RT1052
已解决
跳至解决方案
1,895 次查看
deega_jung
Hello NXP community,
Inquiry of the microSD card data line pull-up resistor,
According to AN10911, MicroSD CARD's DAT0/1/2 line has recommended the pull-up resistor. However, the EV-Kit reference circuit of RT105x uses only DAT0 pull-up, and DAT1/2 does not have pull-up.
What's the reason?
Deega
标签 (1)
1 解答
1,886 次查看
jeremyzhou
1) What's the reason?
-- The alternative method is to enable the internal pull-up resistor, in another word, the external resistor is not definitely necessary.
TIC
在原帖中查看解决方案
2 回复数
1,887 次查看
jeremyzhou
TIC
1,870 次查看
deega_jung
Hi TIC,
Thank you for your comments.
Deega
