lpspi interrupt b2b master example code doesn't work iMXRT1050
4,979 次查看
michaeldkfowler
I have imported the lpspi_interrupt_b2b_master example for the MIMXRT1050-EVKB. When I changed the SPI transfer size from 64 bytes to 24, it worked. When I changed the transfer size to less than 24, like 16, it didn't work anymore. Why can't I transfer less than 24 bytes?
6 回复数
4,963 次查看
Pavel_Hernandez
I replayed this example on my own, unfortunately, I have the same issue but I tested 8, 15, and 17 transfer sizes, I hope this helps you.
Pavel
4,949 次查看
michaeldkfowler
So you will fix the SDK?
4,851 次查看
Pavel_Hernandez
I'm back with feedback this is a temporary patch, please help evaluate it.
One known limitation is, the maximum frame length is 512 bytes, and it is from LPSPI IP limitation when work in non-continuous mode.
If the issue still please let me know.
Pavel
4,932 次查看
Pavel_Hernandez
I will make a report and when I have more information I will contact you.
Pavel
4,895 次查看
Pavel_Hernandez
We are working on this issue, thanks for the report. unfortunately, I don't know how much time would take for the new release.
Pavel
1,690 次查看
Ravi07011983
Sir,
   We are working on LPSPI  polling b2b master imported SDK example code but we are unable to see the clock and data dout in oscilloscope.
 MIMXRT1170-EVK boards We are using pins are GPIO_AD_28 for LPSPI1_SCK, GPIO_AD_29 for LPSPI1_PCS0, GPIO_AD_30 for LPSPI1_SDO, GPIO_AD_31 for LPSPI1_SDI.Slave IC CC REF U27 LPSPI Flash.
 Request to provide the solution or forward to LPSPI Master full working code.
%3CLINGO-SUB%20id%3D%22lingo-sub-1493548%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Elpspi%20%E4%B8%AD%E6%96%AD%20b2b%20%E4%B8%BB%E7%AB%99%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%20iMXRT1050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1493548%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%AF%BC%E5%85%A5%E4%BA%86%20MIMXRT1050-EVKB%20%E7%9A%84%20lpspi_interrupt_b2b_master%20%E7%A4%BA%E4%BE%8B%E3%80%82%E5%BD%93%E6%88%91%E5%B0%86%20SPI%20%E4%BC%A0%E8%BE%93%E5%A4%A7%E5%B0%8F%E4%BB%8E%2064%20%E5%AD%97%E8%8A%82%E6%9B%B4%E6%94%B9%E4%B8%BA%2024%20%E5%AD%97%E8%8A%82%E6%97%B6%EF%BC%8C%E5%AE%83%E8%B5%B7%E4%BD%9C%E7%94%A8%E4%BA%86%E3%80%82%E5%BD%93%E6%88%91%E6%8A%8A%E4%BC%A0%E8%BE%93%E5%A4%A7%E5%B0%8F%E6%94%B9%E4%B8%BA%E5%B0%8F%E4%BA%8E%2024%EF%BC%8C%E6%AF%94%E5%A6%82%2016%20%E6%97%B6%EF%BC%8C%E5%AE%83%E5%B0%B1%E4%B8%8D%E5%86%8D%E5%B7%A5%E4%BD%9C%E4%BA%86%E3%80%82%E4%B8%BA%E4%BB%80%E4%B9%88%E6%88%91%E4%B8%8D%E8%83%BD%E4%BC%A0%E8%BE%93%E5%B0%91%E4%BA%8E%2024%20%E5%AD%97%E8%8A%82%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2321039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpspi%20polling%20b2b%20master%20example%20code%20doesn't%20work%20iMXRT1170%20EVK%20boards%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2321039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%85%88%E7%94%9F%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E7%A0%94%E7%A9%B6%20LPSPI%20%E8%BD%AE%E8%AF%A2%20b2b%20%E4%B8%BB%E5%AF%BC%E5%85%A5%E7%9A%84%20SDK%20%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%AC%E6%97%A0%E6%B3%95%E5%9C%A8%E7%A4%BA%E6%B3%A2%E5%99%A8%E4%B8%AD%E7%9C%8B%E5%88%B0%E6%97%B6%E9%92%9F%E5%92%8C%E6%95%B0%E6%8D%AE%E6%B3%84%E9%9C%B2%E6%83%85%E5%86%B5%E3%80%82%3C%2FP%3E%3CP%3EMIMXRT1170-EVK%20%E6%9D%BF%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E7%9A%84%E5%BC%95%E8%84%9A%E6%98%AF%E7%94%A8%E4%BA%8E%20LPSI1_SCK%20%E7%9A%84%20GPIO_AD_28%EF%BC%8C%E7%94%A8%E4%BA%8E%20LPSI1_PCS0%20%E7%9A%84%20GPIO_AD_29%EF%BC%8C%E7%94%A8%E4%BA%8E%20LPSI1_SDO%20%E7%9A%84%20GPIO_AD_30%EF%BC%8C%E7%94%A8%E4%BA%8E%20LPSI1_SDI.SLAVE%20IC%20CC%20REF%20U27%20LPSPI%20%E9%97%AA%E5%AD%98%E3%80%82%3C%2FP%3E%3CP%3E%E8%A6%81%E6%B1%82%E6%8F%90%E4%BE%9B%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E6%88%96%E5%90%91%20LPSPI%20Master%20%E6%8F%90%E4%BE%9B%E5%AE%8C%E6%95%B4%E7%9A%84%E5%B7%A5%E4%BD%9C%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1508361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpspi%20interrupt%20b2b%20master%20example%20code%20doesn't%20work%20iMXRT1050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1508361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%8F%88%E6%9C%89%E5%8F%8D%E9%A6%88%E4%BA%86%EF%BC%8C%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E4%B8%B4%E6%97%B6%E8%A1%A5%E4%B8%81%EF%BC%8C%E8%AF%B7%E5%B8%AE%E5%8A%A9%E8%AF%84%E4%BC%B0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B8%80%E4%B8%AA%E5%B7%B2%E7%9F%A5%E7%9A%84%E9%99%90%E5%88%B6%E6%98%AF%EF%BC%8C%E6%9C%80%E5%A4%A7%E5%B8%A7%E9%95%BF%E5%BA%A6%E4%B8%BA%20512%20%E5%AD%97%E8%8A%82%EF%BC%8C%E5%AE%83%E6%9D%A5%E8%87%AA%E4%BA%8E%E9%9D%9E%E8%BF%9E%E7%BB%AD%E6%A8%A1%E5%BC%8F%E4%B8%8B%E5%B7%A5%E4%BD%9C%E6%97%B6%E7%9A%84%20LPSPI%20IP%20%E9%99%90%E5%88%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E9%97%AE%E9%A2%98%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3CBR%20%2F%3E%E5%B8%95%E7%BB%B4%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1505122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpspi%20interrupt%20b2b%20master%20example%20code%20doesn't%20work%20iMXRT1050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1505122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%8A%A5%E5%91%8A%E3%80%82%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E6%96%B0%E7%89%88%E6%9C%AC%E9%9C%80%E8%A6%81%E5%A4%9A%E5%B0%91%E6%97%B6%E9%97%B4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1497561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpspi%20interrupt%20b2b%20master%20example%20code%20doesn't%20work%20iMXRT1050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1497561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BC%9A%E5%86%99%E4%B8%80%E4%BB%BD%E6%8A%A5%E5%91%8A%EF%BC%8C%E6%9C%89%E4%BA%86%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%E5%90%8E%E5%86%8D%E4%B8%8E%E6%82%A8%E8%81%94%E7%B3%BB%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1496741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpspi%20interrupt%20b2b%20master%20example%20code%20doesn't%20work%20iMXRT1050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1496741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%82%A3%E4%B9%88%E4%BD%A0%E4%BB%AC%E4%BC%9A%E4%BF%AE%E5%A4%8D%20SDK%20%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1495036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20lpspi%20interrupt%20b2b%20master%20example%20code%20doesn't%20work%20iMXRT1050%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1495036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%87%AA%E5%B7%B1%E9%87%8D%E6%94%BE%E4%BA%86%E8%BF%99%E4%B8%AA%E4%BE%8B%E5%AD%90%EF%BC%8C%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%88%91%E6%B5%8B%E8%AF%95%E4%BA%86%208%E3%80%8115%20%E5%92%8C%2017%20%E7%9A%84%E4%BC%A0%E8%BE%93%E5%A4%A7%E5%B0%8F%EF%BC%8C%E5%B8%8C%E6%9C%9B%E8%83%BD%E5%B8%AE%E5%88%B0%E4%BD%A0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E
