imxRT1021 bootloader issue
kar1
I am trying to Flash code into FLASH, seems to work by FlashLoader, but facing issue when finishing the flash and resetting the Demo board:
I need to launch again debugger and use by Mcuxpresso flash debug to get control again on a new session (after reset).
Does it exist an other way to get control of the Dos terminal by "Blhost" by including in the flash code a part of RS232 code to get the control of the Bootloader session and restart without debug on Mcuxpresso?
Help would be welcome for this isssue?
Omar_Anguiano
To use blhost you will need to use the flashloader to communicate through blhost.
You may use sdphost when the device is on serial download, there it is controlled through UART/USB.
Omar
