iMXRT: USB-Device, RNDIS & LwIP
1,230 次查看
Sam_ECU
I've successfully implemented a baremetal, RNDIS as a USB-Device with LwIP (UDP, standard ethernet frames).
It also has implemented iPerf and tested to 60 Mbps.  Further optimisation is possible:
If you're interested in this code, please message me privately.
1,044 次查看
guru-uvev
Hello @Sam_ECU,
I am interested in the code for reference. I have sent a DM too.
