iMIMXRT595 I3C DDR Mode not working at 12.5Mhz
381 次查看
sai_sudheer
<Priority>
We are experiencing data corruption in I3C HDR-DDR mode at 12.5MHz on the MIMXRT595-EVK board. The issue is specific to higher frequencies and does not occur at lower speeds.
Problem Details:
  • Hardware: MIMXRT595-EVK
  • Mode: I3C HDR-DDR
  • Frequency: 12.5MHz (EXAMPLE_I3C_PP_BAUDRATE = 12500000U)
  • Expected Data: Sequential pattern (0, 1, 2, 3)
  • same as SDK example i3c_polling_b2b_transfer/mastter, slave
  • Received Data: Corrupted pattern [1, 0, 2, 1] (tried for reduced samples as when samples increases communication handoff is not happening from slave to master)
  • Working Frequencies: 4MHz, 6.25MHz (no data corruption)
along with this, We need clarification on I3C clock frequency generation capabilities and proper configuration methods for the RT595.
Observed Behavior:
  • Only specific frequencies are achievable: <4MHz, 6.25MHz, 12.5MHz
  • Intermediate frequencies (5MHz, 7MHz, 8MHz, 10MHz) all result in 6.25MHz output
  • Clock source appears fixed regardless of EXAMPLE_I3C_PP_BAUDRATE setting
What are ALL supported I3C frequencies on RT595?
Can we configure intermediate frequencies (e.g., 8MHz, 10MHz) by changing the source clock, and if so, how?
1 回复
268 次查看
Harry_Zhang
Hi @sai_sudheer
About the  How to configure the baud rate.
I think you can refer to the void void I3C_MasterSetBaudRate(I3C_Type *base, const i3c_baudrate_hz_t *baudRate_Hz, uint32_t sourceClock_Hz) function.
This function is located in the fsl_i3c.c.
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2343391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMIMXRT595%20I3C%20DDR%20%E6%A8%A1%E5%BC%8F%E5%9C%A8%2012.5Mhz%20%E6%97%B6%E4%B8%8D%E5%B7%A5%E4%BD%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2343391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%3CPRIORITY%3E%3C%2FPRIORITY%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%9C%A8%20MIMXRT595-EVK%20%E4%B8%BB%E6%9D%BF%E4%B8%8A%EF%BC%8C%E5%9C%A8%2012.5MHz%20%E7%9A%84%20I3C%20HDR-DDR%20%E6%A8%A1%E5%BC%8F%E4%B8%8B%E9%81%87%E5%88%B0%E4%BA%86%E6%95%B0%E6%8D%AE%E6%8D%9F%E5%9D%8F%E7%9A%84%E6%83%85%E5%86%B5%E3%80%82%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E6%98%AF%E9%AB%98%E9%A2%91%E7%8E%87%E7%89%B9%E6%9C%89%E7%9A%84%EF%BC%8C%E5%9C%A8%E4%BD%8E%E9%80%9F%E6%97%B6%E4%B8%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSTRONG%3E%E9%97%AE%E9%A2%98%E8%AF%A6%E6%83%85%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%E7%A1%AC%E4%BB%B6%EF%BC%9A%3C%2FSTRONG%3EMIMXRT595-EVK%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E6%A8%A1%E5%BC%8F%3C%2FSTRONG%3EI3C%20HDR-DDR%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E9%A2%91%E7%8E%87%EF%BC%9A%3C%2FSTRONG%3E12.5MHz%EF%BC%88EXAMPLE_I3C_PP_BAUDRATE%20%3D%2012500000U%EF%BC%89%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E9%A2%84%E6%9C%9F%E6%95%B0%E6%8D%AE%EF%BC%9A%3C%2FSTRONG%3E%E9%A1%BA%E5%BA%8F%E6%A8%A1%E5%BC%8F%20(%3CFONT%20color%3D%22%23215bd6%22%3E%3CSPAN%3E%3CU%3E0%2C%201%2C%202%2C%203)%20%3C%2FU%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%3CLI%3E%3CFONT%20color%3D%22%23215bd6%22%3E%3CSPAN%3E%3CU%3E%E4%B8%8E%20SDK%20%E7%A4%BA%E4%BE%8B%20i3c_polling_b2b_transfer%2Fmastter%20%E7%9B%B8%E5%90%8C%EF%BC%8C%E4%BB%8E%E7%AB%99%20%3C%2FU%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E6%8E%A5%E6%94%B6%E5%88%B0%E7%9A%84%E6%95%B0%E6%8D%AE%EF%BC%9A%3C%2FSTRONG%3E%E6%8D%9F%E5%9D%8F%E6%A8%A1%E5%BC%8F%20%5B1%2C%200%2C%202%2C%201%5D%EF%BC%88%E5%B0%9D%E8%AF%95%E5%87%8F%E5%B0%91%E9%87%87%E6%A0%B7%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%BD%93%E9%87%87%E6%A0%B7%E5%A2%9E%E5%8A%A0%E6%97%B6%EF%BC%8C%E4%BB%8E%E7%AB%99%E5%88%B0%E4%B8%BB%E7%AB%99%E4%B9%8B%E9%97%B4%E4%B8%8D%E4%BC%9A%E5%8F%91%E7%94%9F%E9%80%9A%E4%BF%A1%E5%88%87%E6%8D%A2%EF%BC%89%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E5%B7%A5%E4%BD%9C%E9%A2%91%E7%8E%87%3C%2FSTRONG%3E4MHz%E3%80%816.25MHz%EF%BC%88%E6%97%A0%E6%95%B0%E6%8D%AE%E6%8D%9F%E5%9D%8F%EF%BC%89%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%8E%E6%AD%A4%E5%90%8C%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E6%BE%84%E6%B8%85%20I3C%20%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%E7%94%9F%E6%88%90%E5%8A%9F%E8%83%BD%E5%92%8C%20RT595%20%E7%9A%84%E6%AD%A3%E7%A1%AE%E9%85%8D%E7%BD%AE%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%A7%82%E5%AF%9F%E5%88%B0%E7%9A%84%E8%A1%8C%E4%B8%BA%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%8F%AA%E8%83%BD%E8%BE%BE%E5%88%B0%E7%89%B9%E5%AE%9A%E9%A2%91%E7%8E%87%EF%BC%9A%26lt%3B4MHz%E3%80%816.25MHz%E3%80%8112.5MHz%3C%2FLI%3E%3CLI%3E%E4%B8%AD%E9%97%B4%E9%A2%91%E7%8E%87%EF%BC%885MHz%E3%80%817MHz%E3%80%818MHz%E3%80%8110MHz%EF%BC%89%E8%BE%93%E5%87%BA%E5%9D%87%E4%B8%BA%206.25MHz%3C%2FLI%3E%3CLI%3E%E6%97%A0%E8%AE%BA%20EXAMPLE_I3C_PP_BAUDRATE%20%E8%AE%BE%E7%BD%AE%E5%A6%82%E4%BD%95%EF%BC%8C%E6%97%B6%E9%92%9F%E6%BA%90%E9%83%BD%E6%98%AF%E5%9B%BA%E5%AE%9A%E7%9A%84%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3ERT595%20%E6%94%AF%E6%8C%81%E5%93%AA%E4%BA%9B%20I3C%20%E9%A2%91%E7%8E%87%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E6%9B%B4%E6%94%B9%E6%BA%90%E6%97%B6%E9%92%9F%E6%9D%A5%E9%85%8D%E7%BD%AE%E4%B8%AD%E9%97%B4%E9%A2%91%E7%8E%87%3C%2FSTRONG%3E%EF%BC%88%E4%BE%8B%E5%A6%82%208MHz%E3%80%8110MHz%EF%BC%89%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E5%A6%82%E4%BD%95%E9%85%8D%E7%BD%AE%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMIMXRT595%20I3C%20DDR%20Mode%20not%20working%20at%2012.5Mhz%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F261258%22%20target%3D%22_blank%22%3E%40sai_sudheer%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%85%B3%E4%BA%8E%E5%A6%82%E4%BD%95%E9%85%8D%E7%BD%AE%E6%B3%A2%E7%89%B9%E7%8E%87%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%20void%20I3C_MasterSetBaudRate(I3C_Type%20*base%2C%20const%20i3c_baudrate_hz_t%20*baudRate_Hz%2C%20uint32_t%20sourceClock_Hz)%20%E5%87%BD%E6%95%B0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%A5%E5%87%BD%E6%95%B0%E4%BD%8D%E4%BA%8E%20fsl_i3c.c%20%E4%B8%AD%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
