CAAM for computing incremental CRC
1,593件の閲覧回数
mastupristi
Senior Contributor II
Given that I don't want to/can't use the SDK (see this post: https://community.nxp.com/t5/MCUXpresso-SDK/errors-in-code-of-SDK-for-RT1170/m-p/2328115/highlight/t...)
I can create descriptors to have CAAM calculate the correct CRC.
I have the following four functions:
  • initialize
  • update
  • finalize
  • Init/Finalize
A typical descriptor is:
InitializeUpdateFinalize
  1.  HEADER
  2.  KEY (set the polynomial)
  3.  OPERATION (init)
  4.  FIFO LOAD (load data)
  5.  STORE (context)
  6.  HALT
  1.  HEADER
  3.  OPERATION (Update)
  4. LOAD (context)
  5.  FIFO LOAD (load data)
  6.  STORE (context)
  7.  HALT
  1.  HEADER
  3.  OPERATION (Finalize)
  4. LOAD (context)
  6.  STORE (crc)
  7.  HALT
What I really can't seem to handle well is the fact that both `initialize` and `finalize` have to provide data.
There isn't a single CRC software library that has such a requirement. For example, the code generated by pycrc doesn't require data for `init` and `fin`.
That said, there are contexts in which it is practically impossible to do so (without having to buffer something, which consumes RAM and ties up the processor, thereby losing some of the advantage gained from using CAAM).
I'm referring, for example, to serialization using Protobuf (nanopb). Since we don't want to use tens of kilobytes of RAM, we'd like to work in-stream.
So I call pb_encode(), and this calls a callback of mine, passing me a portion of the serialized data to be stored incrementally in non-volatile memory, and on which I want to calculate the CRC. However, I can’t know which call will be the last one. I’ll only know that after I exit pb_encode(), but by that point I won’t have any more data to process.
So the question is:
Is there really no way to avoid having to provide data to `Initialize`, and especially to `finalize`?
best regards
Max
タグ(2)
4 返答(返信)
1,447件の閲覧回数
Kan_Li
Hi @mastupristi ,
Yes , it is possible to implement as you want to, please kindly refer to CAAM_CRC(), especially the caam_crc_schedule_input_data() for details.
Hope that helps,
Kan
1,283件の閲覧回数
mastupristi
Hi @Kan_Li
this still does not answer my question.
You are pointing me to `CAAM_CRC()` / `caam_crc_schedule_input_data()`, which is an SDK implementation choice. I am not asking how the SDK was written.
I am asking something much more specific and low-level:
Does the CAAM hardware allow a descriptor for CRC `INIT` and/or `FINALIZE` without a data FIFO LOAD command (or with a valid zero-data alternative)?
My table in the first post was meant to make exactly this point clear.
So please clarify this precise point:
  • for `OPERATION = INIT`, can the descriptor be valid without input data?
  • for `OPERATION = FINALIZE`, can the descriptor be valid without input data?
  • if yes, please show the descriptor sequence
  • if no, please state clearly that CAAM requires data for those stages
What I need is an answer about the hardware descriptor capabilities, not a reference to the SDK implementation.
Max
1,496件の閲覧回数
Kan_Li
Hi @mastupristi ,
Yes, actually it depends on how you implement, and you may refer to our SDK CAAM CRC driver code , which only requires data input for the update stage.
Kan
1,486件の閲覧回数
mastupristi
Hi @Kan_Li
What I am asking is specifically a low-level CAAM question.
I am not asking about the SDK API flow.
I want to understand whether the CAAM hardware itself allows building descriptors whose CRC OPERATION is:
  • INIT, with no input data
  • UPDATE, with input data
  • FINALIZE, with no new input data
In other words, is there a valid descriptor sequence where CAAM can start and, especially, finalize a CRC only from the previously saved context/state, without requiring a FIFO load with new external data?
That is the point I am trying to clarify.
A reference to the SDK driver does not really answer this, because my question is whether the HW/descriptor format itself supports such a flow.
If this is possible, a minimal descriptor-level example would be very helpful.
regards
Max
%3CLINGO-SUB%20id%3D%22lingo-sub-2336633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A2%97%E5%88%86CRC%E3%82%92%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AECAAM%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2336633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3ESDK%20%E3%82%92%E4%BD%BF%E3%81%84%E3%81%9F%E3%81%8F%E3%81%AA%E3%81%84%2F%E4%BD%BF%E3%81%88%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E8%80%83%E3%81%88%E3%82%8B%E3%81%A8%EF%BC%88%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E5%8F%82%E7%85%A7%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCUXpresso-SDK%2Ferrors-in-code-of-SDK-for-RT1170%2Fm-p%2F2328115%2Fhighlight%2Ftrue%23M5447%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCUXpresso-SDK%2Ferrors-in-code-of-SDK-for-RT1170%2Fmp%2F2328115%2Fhighlight%2Ftrue%23M5447%3C%2FA%3E%20%EF%BC%89%3C%2FP%3E%3CP%3ECAAM%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84CRC%E3%82%92%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E8%A8%98%E8%BF%B0%E5%AD%90%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE4%E3%81%A4%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%88%9D%E6%9C%9F%E5%8C%96%3C%2FLI%3E%3CLI%3E%E6%9B%B4%E6%96%B0%3C%2FLI%3E%3CLI%3E%E6%9C%80%E7%B5%82%E6%B1%BA%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FLI%3E%3CLI%3E%E5%88%9D%E6%9C%9F%E5%8C%96%2F%E7%B5%82%E4%BA%86%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%85%B8%E5%9E%8B%E7%9A%84%E3%81%AA%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%20%E8%A8%98%E8%BF%B0%E5%AD%90%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%20%E3%81%AF%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E6%AC%A1%E3%81%AE%20%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20class%3D%22lia-align-left%22%20border%3D%221%22%20width%3D%22100%25%22%20style%3D%22text-align%20%3A%20left%3B%22%20style%3D%22text-align%20%3A%20left%3B%22%20style%3D%22text-align%20%3A%20left%3B%22%20style%3D%22text-align%20%3A%20left%3B%22%20style%3D%22text-align%20%3A%20left%3B%22%20style%3D%22text-align%20%3A%20left%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%3E%3CSTRONG%3E%E5%88%9D%E6%9C%9F%E5%8C%96%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%3E%3CSTRONG%3E%E6%9B%B4%E6%96%B0%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%3E%3CSTRONG%3E%E6%9C%80%E7%B5%82%E6%B1%BA%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%3E%3COL%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%83%98%E3%83%83%E3%83%80%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EKEY%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%A4%9A%E9%A0%85%E5%BC%8F%20%E3%82%92%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%20%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%93%8D%E4%BD%9C%EF%BC%88%E5%88%9D%E6%9C%9F%E5%8C%96%EF%BC%89%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CFONT%20color%3D%22%23800000%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EFIFO%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%AD%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%20%E3%83%AD%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%EF%BC%89%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%82%B9%E3%83%88%E3%82%A2%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%81%9C%E6%AD%A2%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%3E%3COL%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%83%98%E3%83%83%E3%83%80%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EKEY%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%A4%9A%E9%A0%85%E5%BC%8F%20%E3%82%92%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%20%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%88%E6%9B%B4%E6%96%B0%EF%BC%89%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AD%E3%83%BC%E3%83%89%EF%BC%88%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%EF%BC%89%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EFIFO%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%AD%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%20%E3%83%AD%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%82%B9%E3%83%88%E3%82%A2%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%81%9C%E6%AD%A2%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%3E%3COL%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%83%98%E3%83%83%E3%83%80%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EKEY%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%A4%9A%E9%A0%85%E5%BC%8F%20%E3%82%92%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%20%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E6%93%8D%E4%BD%9C%EF%BC%88%E5%AE%8C%E4%BA%86%EF%BC%89%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%83%AD%E3%83%BC%E3%83%89%EF%BC%88%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%EF%BC%89%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3E%3CFONT%20color%3D%22%23800000%22%3E%3CSTRONG%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3EFIFO%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%20%E3%83%AD%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%20%E3%83%AD%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%EF%BC%89%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%82%B9%E3%83%88%E3%82%A2%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3Ecrc%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E5%81%9C%E6%AD%A2%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%8C%E3%81%A9%E3%81%86%E3%81%97%E3%81%A6%E3%82%82%E3%81%86%E3%81%BE%E3%81%8F%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%80%81%60initialize%60%E3%81%A8%60finalize%60%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%8C%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E7%82%B9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E8%A6%81%E4%BB%B6%E3%82%92%E6%8C%81%E3%81%A4CRC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AF%E4%B8%80%E3%81%A4%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81pycrc%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%60init%60%E3%81%A8%60fin%60%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A8%E3%81%AF%E3%81%84%E3%81%88%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%81%9D%E3%81%86%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%AA%E7%8A%B6%E6%B3%81%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%88%E4%BD%95%E3%81%8B%E3%82%92%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AFRAM%E3%82%92%E6%B6%88%E8%B2%BB%E3%81%97%E3%80%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%92%E5%8D%A0%E6%9C%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81CAAM%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E5%BE%97%E3%82%89%E3%82%8C%E3%82%8B%E5%88%A9%E7%82%B9%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%8C%E5%A4%B1%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81Protobuf%EF%BC%88nanopb%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%A9%E3%82%A4%E3%82%BC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%95%B0%E5%8D%81%E3%82%AD%E3%83%AD%E3%83%90%E3%82%A4%E3%83%88%E3%82%82%E3%81%AERAM%E3%82%92%E4%BD%BF%E3%81%84%E3%81%9F%E3%81%8F%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E5%86%85%E3%81%A7%E5%87%A6%E7%90%86%E3%82%92%E8%A1%8C%E3%81%84%E3%81%9F%E3%81%84%E3%80%82%3CBR%20%2F%3E%E3%81%9D%E3%81%93%E3%81%A7%E7%A7%81%E3%81%AFpb_encode()%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E9%96%A2%E6%95%B0%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%80%81%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E4%B8%80%E9%83%A8%E3%82%92%E7%A7%81%E3%81%AB%E6%B8%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E4%B8%8D%E6%8F%AE%E7%99%BA%E6%80%A7%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E6%AE%B5%E9%9A%8E%E7%9A%84%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6CRC%E3%82%92%E8%A8%88%E7%AE%97%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%A9%E3%81%AE%E9%9B%BB%E8%A9%B1%E3%81%8C%E6%9C%80%E5%BE%8C%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%8B%E3%81%AF%E7%A7%81%E3%81%AB%E3%81%AF%E5%88%86%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AFpb_encode()%E3%82%92%E7%B5%82%E4%BA%86%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%A7%E3%81%97%E3%81%8B%E5%88%86%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AF%E5%87%A6%E7%90%86%E3%81%99%E3%81%B9%E3%81%8D%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E3%82%82%E3%81%86%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A0%E3%82%8D%E3%81%86%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%93%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%A8%E3%81%AA%E3%82%8B%E3%81%AE%E3%81%AF%E6%AC%A1%E3%81%AE%E7%82%B9%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%60Initialize%60%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E7%89%B9%E3%81%AB%60finalize%60%E3%81%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%81%BF%E3%81%91%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E6%9C%80%E5%A4%A7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2339881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20for%20computing%20incremental%20CRC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E5%B0%8B%E3%81%AD%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AB%E3%81%AFCAAM%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%88%9D%E6%AD%A9%E7%9A%84%E3%81%AA%E8%B3%AA%E5%95%8F%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESDK%20API%E3%81%AE%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%B3%AA%E5%95%8F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3ECAAM%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%87%AA%E4%BD%93%E3%81%8C%E3%80%81CRC%E6%BC%94%E7%AE%97%E3%81%8C%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8B%E8%A8%98%E8%BF%B0%E5%AD%90%E3%81%AE%E6%A7%8B%E7%AF%89%E3%82%92%E8%A8%B1%E5%8F%AF%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%85%A5%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AA%E3%81%97%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3C%2FLI%3E%3CLI%3E%E6%9B%B4%E6%96%B0%E3%80%81%E5%85%A5%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF%E4%BB%98%E3%81%8D%3C%2FLI%3E%3CLI%3E%E6%9C%80%E7%B5%82%E5%87%A6%E7%90%86%EF%BC%88%E6%96%B0%E8%A6%8F%E5%85%A5%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AA%E3%81%97%EF%BC%89%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E8%A8%80%E3%81%84%E6%8F%9B%E3%81%88%E3%82%8C%E3%81%B0%E3%80%81CAAM%E3%81%8C%E6%96%B0%E3%81%97%E3%81%84%E5%A4%96%E9%83%A8%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AB%E3%82%88%E3%82%8BFIFO%E3%83%AD%E3%83%BC%E3%83%89%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%9B%E3%81%9A%E3%81%AB%E3%80%81%E4%BB%A5%E5%89%8D%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%2F%E7%8A%B6%E6%85%8B%E3%81%AE%E3%81%BF%E3%81%8B%E3%82%89CRC%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%80%81%E7%89%B9%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%A7%E3%81%8D%E3%82%8B%E6%9C%89%E5%8A%B9%E3%81%AA%E8%A8%98%E8%BF%B0%E5%AD%90%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%AF%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81%E3%81%BE%E3%81%95%E3%81%AB%E3%81%9D%E3%81%AE%E7%82%B9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESDK%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E3%81%93%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E7%AD%94%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%AA%E3%81%9C%E3%81%AA%E3%82%89%E3%80%81%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E3%80%81HW%2F%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%82%BF%E3%81%AE%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E8%87%AA%E4%BD%93%E3%81%8C%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%83%AD%E3%83%BC%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%A0%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%97%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AE%E8%A8%98%E8%BF%B0%E5%AD%90%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E4%BE%8B%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E5%A4%A7%E5%A4%89%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E5%A4%A7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2339774%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20for%20computing%20incremental%20CRC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339774%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F124967%22%20target%3D%22_blank%22%3E%40mastupristi%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E5%AE%9F%E8%A3%85%E6%96%B9%E6%B3%95%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%BC%8A%E7%A4%BE%E3%81%AESDK%20CAAM%20CRC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%81%94%E5%8F%82%E7%85%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E6%9B%B4%E6%96%B0%E6%AE%B5%E9%9A%8E%E3%81%A7%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E5%85%A5%E5%8A%9B%E3%81%AE%E3%81%BF%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%81%AFThread%E3%82%92%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E6%97%A5%E3%80%81%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E9%96%89%E3%81%98%E3%82%89%E3%82%8C%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2340908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20for%20computing%20incremental%20CRC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2340908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F124967%22%20target%3D%22_blank%22%3E%40mastupristi%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%94%E5%B8%8C%E6%9C%9B%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3CSPAN%3E%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81CAAM_CRC()%E3%80%81%E7%89%B9%E3%81%ABcaam_crc_schedule_input_data()%E3%82%92%E3%81%94%E5%8F%82%E7%85%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%81%AFThread%E3%82%92%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E6%97%A5%E3%80%81%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E9%96%89%E3%81%98%E3%82%89%E3%82%8C%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346435%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20for%20computing%20incremental%20CRC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346435%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%82%82%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%AF%E7%AD%94%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E7%A7%81%E3%81%AB%60CAAM_CRC()%60%20%2F%20%60caam_crc_schedule_input_data()%60%E3%82%92%E6%8C%87%E3%81%97%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AFSDK%E3%81%AE%E5%AE%9F%E8%A3%85%E4%B8%8A%E3%81%AE%E9%81%B8%E6%8A%9E%E8%82%A2%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFSDK%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%81%AE%E3%81%8B%E3%82%92%E5%B0%8B%E3%81%AD%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%3CSTRONG%3E%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%82%82%E3%81%A3%E3%81%A8%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%A7%E4%BD%8E%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AA%E3%81%93%E3%81%A8%E3%82%92%E5%B0%8B%E3%81%AD%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3ECAAM%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%81%E3%83%87%E3%83%BC%E3%82%BFFIFO%E3%83%AD%E3%83%BC%E3%83%89%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AA%E3%81%97%EF%BC%88%E3%81%BE%E3%81%9F%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%AA%E3%82%BC%E3%83%AD%E3%83%87%E3%83%BC%E3%82%BF%E4%BB%A3%E6%9B%BF%E3%81%82%E3%82%8A%EF%BC%89%E3%81%A7%E3%80%81CRC%E3%81%AE%E3%80%8CINIT%E3%80%8D%E3%81%8A%E3%82%88%E3%81%B3%2F%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%8CFINALIZE%E3%80%8D%E3%81%AE%E8%A8%98%E8%BF%B0%E5%AD%90%E3%82%92%E8%A8%B1%E5%8F%AF%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E5%88%9D%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7%E7%A4%BA%E3%81%97%E3%81%9F%E8%A1%A8%E3%81%AF%E3%80%81%E3%81%BE%E3%81%95%E3%81%AB%E3%81%93%E3%81%AE%E7%82%B9%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E7%82%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%94%E8%AA%AC%E6%98%8E%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%60OPERATION%20%3D%20INIT%60%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E5%85%A5%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF%3CSTRONG%3E%E3%81%8C%E3%81%AA%E3%81%8F%E3%81%A6%E3%82%82%3C%2FSTRONG%3E%E8%A8%98%E8%BF%B0%E5%AD%90%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FLI%3E%3CLI%3E%60OPERATION%20%3D%20FINALIZE%60%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E5%85%A5%E5%8A%9B%E3%83%87%E3%83%BC%E3%82%BF%3CSTRONG%3E%E3%81%8C%E3%81%AA%E3%81%8F%E3%81%A6%E3%82%82%3C%2FSTRONG%3E%E8%A8%98%E8%BF%B0%E5%AD%90%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E3%81%AF%E3%81%84%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E8%A8%98%E8%BF%B0%E5%AD%90%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FLI%3E%3CLI%3E%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81CAAM%E3%81%8C%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%AE%B5%E9%9A%8E%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E8%BF%B0%E3%81%B9%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E7%A7%81%E3%81%8C%E6%B1%82%E3%82%81%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81%3CSTRONG%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%A8%98%E8%BF%B0%E5%AD%90%E3%81%AE%E6%A9%9F%E8%83%BD%3C%2FSTRONG%3E%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%9B%9E%E7%AD%94%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81SDK%E3%81%AE%E5%AE%9F%E8%A3%85%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%8F%82%E7%85%A7%E6%83%85%E5%A0%B1%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%83%9E%E3%83%83%E3%82%AF%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E
