i3c_dma driver SDK support
jpopp24
  We are developing low latency/overhead i3c processing from a sensor and need I3C DMA support on the RT6XX.  When will the next SDK be released that supports i3c_dma?
 Thx!
kerryzhou
Hi @jpopp24 ,
  I checked internally, and get the information, we have the plan to add the I3C DMA driver to the new SDK version, but the detail time is not determined, as I know, normally, the SDK will updated in half-year.
Now, the situation is, we also don't have that I3C dma driver.
Wish it helps you!
Kerry
