fsl_romapi example for rt1052 change for qspi flash
1,157件の閲覧回数
vega_sdr
fsl_romapi sdk example for rt1052 is for HyperBus flash, I need to change the code to use it with w25q32jv qspi flash. Where can I find an example FLEXSPI_NorFlash_GetConfig function for my case ?
タグ(1)
1,140件の閲覧回数
jingpan
Hi @vega_sdr ,
There isn't examples for qspi flash. You can modify FLEXSPI_NorFlash_GetConfig() according to the data in flexspi_nor_polling_transfer demo.
Jing
